Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 698 - JeepForum.com
 28Likes
post #10456 of 13416 Old 05-27-2013, 11:23 PM
Therios
I am getting ready to prepare for the pan. There are some spots like in the upper rear corners that have a soft material that is under the paint. It feels like silicone. The factory paint is on the silicone as well and seems to adhere well. Do I need to trim this when I am scuffing or just paint over it? Would be nice if it were flush. They did a horrible job of trimming it and it looks like a sloppy paint job because of this. It is my jeep and I don't really care in the long run but just don't want a stupid soft spot to ruin the tub liner finish if I can fix it during prep.
Therios Pendragon aka Ken Johnson
2003 maroon Jeep Wrangler SE - Soft top
Hard half doors
-New Bestop replacement
-Orfab front bumper (DONE)
-CRS rear bumper
-CRS rear bumper tire mount swing arm.
-led third light mods that sit in the two spare tire lug holes.
-because of above - removed ugly third light tower completely
-smitty top end grab handles
-20" LED light bar 10 degree spot (installed now and blindingly operational)
-50" LED light bar 20 degree flood ( changed to 30" in center 3 tabs, installed but not wired)
-windshield mount light bar (done)
-winch 8000# smitty
-Monstaliner complete pan in red head(as soon as they deliver it) (done)
-Carpet removed
-corbeau RS reclining seats
-corbeau water proof seat covers
-corbeau seat mount replacements (removes tilt forward passenger seat)
-AXD 430 receiver
-hood hinge mount for my hi lift jack
-Headlight replacements
-tremendous mt 31.5/10.5 15s on nice alloy rims
-Everything else is stock... For now
-next items
Led dash replacements
Led square lights for 6 free mounting tabs
Led backup lights
Therios is offline
post #10457 of 13416 Old 05-28-2013, 08:48 PM
TJ_Tim
Interwebz Specialists
TJ_Tim's Avatar
Showing off my lines around the door jambs and the top rail.
1969 Mercury Cougar 351w
1998 Jeep Wrangler Sport 4.0
2009 Yamaha V Star 950
2006 Jeep Commander 4.7 Base
TJ_Tim is offline
post #10458 of 13416 Old 05-28-2013, 08:55 PM
eduardostewart
nice. take the tape off right away or after cured?
eduardostewart is offline
post #10459 of 13416 Old 05-28-2013, 09:07 PM
TJ_Tim
TJ_Tim's Avatar
What the topcoat cure for about an hour
Sent from Teletran 1
TJ_Tim is offline
post #10460 of 13416 Old 05-28-2013, 09:08 PM
Therios
Awesome job. I only hope mine will be half as good. Did you use tape?
Hard half doors
-CRS rear bumper
-winch 8000# smitty
-Carpet removed
-AXD 430 receiver
-next items
Led backup lights
Therios is offline
post #10461 of 13416 Old 05-28-2013, 09:23 PM
TJ_Tim
TJ_Tim's Avatar
Stripped out the old Herculiner, scuffed, sanded, primed bare spots, taped and rolled. It's ALL in the prep work.
TJ_Tim is offline
post #10462 of 13416 Old 05-28-2013, 09:50 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Nice job, do you have any before pics of what the Herculiner looked like?
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10463 of 13416 Old 05-28-2013, 09:52 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Are you talking about the OEM seam sealer used in the factory?
Connect with us on:
post #10464 of 13416 Old 05-28-2013, 09:59 PM
TJ_Tim
TJ_Tim's Avatar
Other than awful? Ill have to look Eric. I've got some somewhere on my laptop I think.
TJ_Tim is offline
post #10465 of 13416 Old 05-28-2013, 10:02 PM
Therios
I am not sure but if it matches the description that I included then yes. I really do think that is what it is. I did not know what to call it bit worried me that it was so flexible though. So do I need to worry about it?
Hard half doors
-CRS rear bumper
-winch 8000# smitty
-Carpet removed
-AXD 430 receiver
-next items
Led backup lights
Therios is offline
post #10466 of 13416 Old 05-28-2013, 10:08 PM
rodgers3
have to post pictures later. from my computer.
but i finally bit the bullet and did the monsta! it looks sweet!
magnetman i rolled one gallon on.
it got 2 coats with great coverage.
would you recommend using the second gallon and coating again?
Im not sure if it needs it but i want it too look awesome (it does!!) And stay that way.
rodgers3 is offline
post #10467 of 13416 Old 05-28-2013, 10:21 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Keep in mind that if you wait more than 8 hours you need to let it go to 24 hrs to cure better and then scuff before recoating
If you happy with it stop now and save the other gallon.
Connect with us on:
post #10468 of 13416 Old 05-28-2013, 10:23 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
If factory paint was put over that stuff all you need to do is scuff it like the rest of tub and coat over it
This is not in areas that really gets used or abused.. correct?
Connect with us on:
post #10469 of 13416 Old 05-28-2013, 10:24 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
OK if you find them it's always cool to compare side by side to sandpaper
Connect with us on:
post #10470 of 13416 Old 05-28-2013, 10:27 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You're always best off pulling tape immediately after 2nd coat is done. You never know what can happen where you can't get back to it soon enough and then pull tape too late and screw it up. If you waited overnight you would be cursing with what happens
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
