Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 697 - JeepForum.com
 28Likes
post #10441 of 13412 Old 05-26-2013, 01:30 PM
M34NTL
Originally Posted by magnetman View Post
Show it to me
I sent you a facebook message. Couldn't quite figure out how to get photos on here. Thanks!
M34NTL is offline
post #10442 of 13412 Old 05-26-2013, 03:04 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by M34NTL View Post
Hey magnetman!
Trying to do a Meyers Tow'd buggy frame in chassis saver than coat over the top with monstaliner. Any idea how much chassis saver you think I'll need?
This would only use a quart of Chassis Saver but considering how much clean metal you have here I would think about using epoxy primer instead followed by ML
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10443 of 13412 Old 05-26-2013, 04:28 PM
M34NTL
Well I actually placed my order this morning. I ordered the smurfadelic and predator green with the white primer like is recommended for the predator green ML. Will epoxy primer work with those colors? I'm guessing I should order the 2 gallon kit of magnapoxy so that I can do the body of the buggy as well as the roll cage?
M34NTL is offline
post #10444 of 13412 Old 05-26-2013, 06:21 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Can you show me the rest of this project and tell what colors are going where
Connect with us on:
post #10445 of 13412 Old 05-27-2013, 12:27 PM
kc_joe
What is the finish like on the chassis saver? wondering what it would look like on front and rear bumper (both in good shape but showing some surface rust.
kc_joe is offline
post #10446 of 13412 Old 05-27-2013, 12:51 PM
rodgers3
any recommendations or special procedure before i start? all prepwork is done but Im going over everything with the skuff pad again and wiping with mek.
to do the windshield frame, should i drop the windshield, do the inside then put it back up and do the outside?
rodgers3 is offline
post #10447 of 13412 Old 05-27-2013, 02:01 PM
M34NTL
Sorry this took a bit magnetman! Hope you are having a fantastic memorial day. I can't post the actual pictures until I've been a forum member for more than a month with 25 posts or more. Anyone who can re post the pictures is welcome to share them.
The frame will be primarily predator except for the big rod sticking out and steering rod, those will be smurfadelic. The body and hood will be primarily predator with smurfadelic accents.
The wheels are 15 inches and those will be primarily smurfadelic with predator accents.
https://www.facebook.com/photo.php?f...type=3&theater
M34NTL is offline
post #10448 of 13412 Old 05-27-2013, 03:07 PM
bedwards24676
I didn't drop my winshield. Cut out 2 4x4's 8inches long screwed them to saw horses. Taped off the seals and windshield and. Painted it first then moved on to the rest of the jeep. Made it back around to 2nd coat right before I finished 1st on everything else. Do the inside 1st. Then do outside of frame. As soon as you get through with 2n coat pull tape ASAP. Mine turned out great.
bedwards24676 is offline
post #10449 of 13412 Old 05-27-2013, 03:48 PM
travisstutler
love this stuff and will being doing the inside of my xj with the chassis saver first then the liner same thing for my garbage trailer sound doable to everyone
travisstutler is offline
post #10450 of 13412 Old 05-27-2013, 03:53 PM
rodgers3
i ment droping the frame not the actual glass.
rodgers3 is offline
post #10451 of 13412 Old 05-27-2013, 04:31 PM
bedwards24676
Oh yeah take it off for sure.
post #10452 of 13412 Old 05-27-2013, 09:21 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
It's a hard smooth finish, either glossy or satin. Do you realize that CS is not UV stable? It's really not meant to be left alone without a topcoat if you want it to stay looking nice
Connect with us on:
post #10453 of 13412 Old 05-27-2013, 09:24 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Thanks
These links don't go anywhere. Send the pics to me directly on FB
You can get away putting Predator over a light gray primer I would just make sure to roll it a little heavy so you don't see show through of the gray
Connect with us on:
post #10454 of 13412 Old 05-27-2013, 09:32 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by hewesyourdaddy View Post
I'm interested in Urine Trouble. What role does the lead play in the make-up of the mix? A tinting agent?
Sorry I missed this Q
Yes the lead is the pigment itself, either yellow or orange. It started as a dry material and was ground up in a liquid so it can be added to the coating.
The issues with going lead free is that the lead free pigments are transparent so either more is needed in the gallon of liner to cover or more coats are needed to get coverage. The catch 22 is that these pigments are always 3 to 5 times more costly but there's nothing we can do about it if we're going to offer certain shades.
Urine Trouble is going to be an easy one to get the lead out of with not so bad coverage as a lead free item. We are working on it
The oranges are going to be a *****
Connect with us on:
post #10455 of 13412 Old 05-27-2013, 10:31 PM
M34NTL
Thanks
Alright, sorry about that. I sent the message on FB. I'll give you a shout tomorrow too so we can finalize that order I made and make sure I get exactly what you recommend.
M34NTL is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
