Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 693 - JeepForum.com
 28Likes
post #10381 of 13402 Old 05-22-2013, 09:43 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by hewesyourdaddy View Post
Any idea on when (or if) the lead-free tints will be available?
We did some work on them but not finished yet
Which color specifically you interested in?
There is a good chance that some, if not all of the lead free yellows/oranges are going to need white primer base coat
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10382 of 13402 Old 05-22-2013, 10:46 AM
pods8
Originally Posted by DNFJ View Post
I used a new roller per coat. Since I got the extra rollers I switched to a new one about half way through or so, depending on how ripped up it was getting. The first coat puts the most strain on the roller.
First coat for me was no issue, my surface is flat/easy though. I just ran into issue doing wet on wet 2nd/3rd coats to use the product. I will be doing three separate going forward.
pods8 is offline
post #10383 of 13402 Old 05-22-2013, 08:33 PM
hewesyourdaddy
2011 JK Wrangler
I'm interested in Urine Trouble. What role does the lead play in the make-up of the mix? A tinting agent?
hewesyourdaddy is offline
post #10384 of 13402 Old 05-22-2013, 08:56 PM
Cuder
Anyone else notice the words ballsack and ***** in the tags section of this thread?
My Build Thread:
Cuder is offline
post #10385 of 13402 Old 05-22-2013, 09:21 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I do now
How does that happen?
Connect with us on:
post #10386 of 13402 Old 05-22-2013, 09:23 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Can anyone edit tags on a thread? or only the OP?
Connect with us on:
post #10387 of 13402 Old 05-23-2013, 12:02 AM
04WJny
1987 YJ Wrangler
Stopped by Magnet Paints yesterday to check out some Monstaliner for the YJ and for a part at work and dont know what color to choose... stuck between Medium Quartz Grey and Pyroclastic
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
post #10388 of 13402 Old 05-23-2013, 06:11 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
What have people been doing about the sealer on the inside of tubs? Wire wheel it away or paint over it?
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #10389 of 13402 Old 05-23-2013, 06:33 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I don't think that stuff wire wheels without gumming up badly. Chiseling is needed and the mysterious dry ice method which someone claimed will just make it pop off
Connect with us on:
post #10390 of 13402 Old 05-23-2013, 06:37 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Most people just coat over it
Connect with us on:
post #10391 of 13402 Old 05-23-2013, 06:52 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Just straight onto should be fine?
Previous:
DNFJ is offline
post #10392 of 13402 Old 05-23-2013, 07:12 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Yes, just scuff it well. That stuff is already painted so you're just lining over paint like the rest of the tub
Connect with us on:
post #10393 of 13402 Old 05-23-2013, 07:40 AM
JeepComanche89
1989 MJ Comanche
Its there for a reason, dont remove it
JeepComanche89 is offline
post #10394 of 13402 Old 05-23-2013, 08:10 AM
Cuder
I used a die grinder with a red scotchbrite disc to take some of the high spots down. Those union employees did a fine job slopping that sealer.
My Build Thread:
Cuder is offline
post #10395 of 13402 Old 05-23-2013, 08:43 AM
Loomie
any word on the release dates of the new colors?
Loomie is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
