Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 680 - JeepForum.com
 34Likes
post #10186 of 13504 Old 04-29-2013, 09:46 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I'm on it.. thinking
Originally Posted by pods8 View Post
Magnapoxy! Coats and looks awesome! (Eric, just shot you an email, in a bit of a scramble planning to do the grey sides tomorrow early, wondering about trying to cut in the white top at the end of tomorrow, weather window is closing for a few days...).
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10187 of 13504 Old 04-29-2013, 10:04 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by Tanimal View Post
Why it didn't adhere properly and if I can just lay the quart of Monstaliner that I bought right over the top of it after cleaning it or should I scuff it up with some sandpaper. Also do you send out touchup kits because I had this problem or no? Thanks
Adhesion on the floor hooks is questionable and it looks like they were bare metal before coating?
A rock under the mat getting ground down under there is not good for any coating
To recoat you need to scuff first and then solvent clean. Don't need to scuff like you first did when doing the job but you need to dull it down some.
We have so few problems with Monstaliner I'm not even interested in debating these things.. If you want a repair kit no charge PM me a shipping address
SMcutter.. send me your address too for a free repair kit and a custom piece of 2x4 with a groove in it for your next jacking experience ..
Connect with us on:
post #10188 of 13504 Old 04-29-2013, 10:23 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
pods8.. I sent you an email.. I gotta go to sleep
[QUOTE=pods8;15366596]Magnapoxy! Coats and looks awesome! (Eric, just shot you an email, in a bit of a scramble planning to do the grey sides tomorrow early, wondering about trying to cut in the white top at the end of tomorrow, weather window is closing for a few days...).
Connect with us on:
post #10189 of 13504 Old 04-29-2013, 10:26 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Here we go
Connect with us on:
post #10190 of 13504 Old 04-29-2013, 10:34 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Next week I will publish a Monstaliner "Mix By Weight" chart for BLACK and all the COLORS. This will enable mixing any quantity
out of a gallon or quart so the rest can be saved for future use. A gram scale is need to do this mixing and I've
flagged 2 items on Amazon that will work great. Both scales sell for less than $10.00 - #1 has a capacity of 650 grams,
other has capacity of 1000 grams
Ac-650 Digital Pocket Gram Scale.jpg   Am Weigh Pocket Scale 1000 by 0.1 G.jpg
Connect with us on:
post #10191 of 13504 Old 04-29-2013, 10:48 PM
Tanimal
Thanks appreciate it and will be PMing address
Learning as I go and it's worth every penny!
Tanimal is offline
post #10192 of 13504 Old 04-29-2013, 10:57 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by rodgers3 View Post
Monsta just arrived
Taken a few hood shots when i get home!
I need to get craken on the body work. Just need to pull out the corner and prep the entire body.
So excited to tackle this project.
Thanks agin!!! Your probly going to get sick of me saying thank you... Lol
rodgers3 you were in the right place at the right time and it was cool because I don't think you had any idea what was was going on
Do a good job!
Connect with us on:
post #10193 of 13504 Old 04-30-2013, 03:57 AM
DNFJ
Got my paint yesterday. I was outside smoking a cigarette and the UPS guy was just like "More stuff for the Jeep huh?" lol.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #10194 of 13504 Old 04-30-2013, 06:26 AM
jetboat
1987 YJ Wrangler
Im wanting to do my entire yj in liner. I want to do the interior and all exterior except the hood and cowl in 1 color and hood and cowl in another... Any idea how much Ill need of each?
jetboat is offline
post #10195 of 13504 Old 04-30-2013, 06:43 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
That's the deck only without any sides,,, but the XJ prob has less side surface area than a Wrangler.. correct?
Not sure about vertical surface area between the two. Aside from the tunnel and the rear wells, I am only wanting to cover the deck.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is online now
post #10196 of 13504 Old 04-30-2013, 06:50 AM
rodgers3
Do a good job!
Put my hood shot on fb
And i had no idea i had fallen down on my forum surfin
I defently hope to do a good job im probly going to end up spending a week or more makeing sure everything is prepd and i have everything in order to start haha.
Is there any thing you recomend i buy that wasnt inlcluded in the box of awsome? Lol
Should i take the hood off to paint it?
Also my dad has this stuff at work called desocleen? Somethn like that.. Anyway its main ingreedeant is mek and they use it to prep airplane parts before powder coating.
would this work or should i just go buy mek sub?
And any tips and tricks you recommend?
thank you again!!!
rodgers3 is offline
post #10197 of 13504 Old 04-30-2013, 07:47 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
It's hard got me to fig this in my brain without standing next to the jeep
Not sure if 1 gal on exterior will be enough to do all without hood and cowl and then how much needed for just hood and cowl
Connect with us on:
post #10198 of 13504 Old 04-30-2013, 08:42 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You can probably do this with 1 gal just make sure to roll 1st coat thin and save more than 1/2 for 2nd coat
Connect with us on:
post #10199 of 13504 Old 04-30-2013, 09:17 AM
HoofHarted
When you get a chance, could you please DM me a copy of your mix by weight chart? Just made my order this morning. Thanks!!
HoofHarted is offline
post #10200 of 13504 Old 04-30-2013, 09:27 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Chart is not ready, what color are you doing?
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
