Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 678 - JeepForum.com
 29Likes
post #10156 of 13469 Old 04-26-2013, 11:30 PM
pods8
Originally Posted by smcutter View Post
It's funny you should say that. I thought I was paying $100 for something more than paint.
It is a uerathane coating, it is not powder coat or polyurea ( line-x type stuff) they are completely different, it's been clarified. Also as noted your application failed to the primer (that isn't a monsta failure) and it was noted from the go that epoxy is the BEST over bare steel, you opted for the easier route but wanted top performance under unrealistic conditions. This is a thick, durable DIY paint/coating, undestand the capabilities.
pods8 is offline
post #10157 of 13469 Old 04-27-2013, 06:16 AM
JeepComanche89
1989 MJ Comanche
Mine chipped when i was putting the bumper on. I had to tap it in with a piece of 2x4 and a 2lb sledge. I hit the d ring mount and the top corner flaked off. I let it cure in a 78 degree heated garage for over 24 hours. But it appears to be fairly tough otherwise. I can just barley make a indent it in with my finger, hasn't quite been a week yet and seems to be getting harder. Maybe it was just too soon to tap it in, ill place the blame on me for now as i haven't really tested it otherwise.
JeepComanche89 is offline
post #10158 of 13469 Old 04-27-2013, 02:58 PM
legend2
How would this hold up on an outboard which lives in saltwater? Need to repaint my lower unit
legend2 is offline
post #10159 of 13469 Old 04-28-2013, 04:45 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Magnetman,
Looking at lining my XJ interior but curious - would the 1 gallon kit suffice?
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #10160 of 13469 Old 04-28-2013, 04:59 PM
Tanimal
Originally Posted by magnetman View Post
Don't need a whole quart for touchup. We have small black repair kit that covers appx 3.5 sq ft
Can you show me a pic of what is happening? What caused it to come off?
If you cant post pic here send to email
info@monstaliner.com
or to my phone
516.313.7865
Hey sorry this took me a bit but I finally got around to snapping some photos.
Hinges chipped and the seats only been out once since I installed but I expected something like this:
Spotty coverage:
Big chip that I filled in with some Duplicolor until I can touch it up ( You can see some spotty coverage also)
Small chip from I believe a stone under my mats on my drivers side (right where the damn flash is)
Learning as I go and it's worth every penny!
Tanimal is offline
post #10161 of 13469 Old 04-29-2013, 06:17 AM
DNFJ
Magnetman, will MEK have any adverse effects to cured ML?
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #10162 of 13469 Old 04-29-2013, 07:56 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
It could dull the surface and would probably soften the coating if left to sit or if you kept wiping it on. Coating would return to normal hardness afterwards.
MEK is the laboratory standard for testing solvent resistance in the paint industry
What are you doing?
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10163 of 13469 Old 04-29-2013, 07:57 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Magnetman,
Probably need extra quart. How much longer is XJ tub than 2 dr Wrangler?
Connect with us on:
post #10164 of 13469 Old 04-29-2013, 07:59 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I don't know. Someone posted on FB yesterday that he did a boat bottom 3 yrs ago and all is well but this was fresh water, intermittent use
Connect with us on:
post #10165 of 13469 Old 04-29-2013, 08:03 AM
DNFJ
What are you doing?
I have scoops coming in the mail that I plan debating on painting as they come black. Not sure how they would look black on the hood. So maybe I should order just a quart of blue later and paint the scoops before I put them on.
Previous:
DNFJ is offline
post #10166 of 13469 Old 04-29-2013, 08:32 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by Cuder View Post
Is it a Bren cutter? I have been using one for 20 years and it still cuts like it's new. Pm me if you need any help with it or the program.
GCC Expert24
I looked up Bren.. those are expensive unless there is lower cost models I missed. I cut some samples and it worked well printing direct from AI CS5
I will def have to pick your brain some, thanks!
Are you in the sign business?
Connect with us on:
post #10167 of 13469 Old 04-29-2013, 08:36 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
First test... weeding these things is going to be a chore
Cutting the www is not working.. letters too small
Connect with us on:
post #10168 of 13469 Old 04-29-2013, 09:45 AM
Tanimal
Got the pictures requested in post 10160......
Tanimal is offline
post #10169 of 13469 Old 04-29-2013, 10:01 AM
rodgers3
Monsta just arrived
Taken a few hood shots when i get home!
I need to get craken on the body work. Just need to pull out the corner and prep the entire body.
So excited to tackle this project.
Thanks agin!!! Your probly going to get sick of me saying thank you... Lol
rodgers3 is offline
post #10170 of 13469 Old 04-29-2013, 10:09 AM
pods8
Fairing coat skimmed on:
Sanded out:
Fill coat of raw epoxy to fill pin holes and seal up the surface:
Next up is scuffing up the raw epoxy to prepare it for the magnapoxy. Magnetman, couple last minute questions:
1) Plan is to do the sides in monsta first, wait the recommended 24hrs and then scuff up the overlapping area and monsta the top. Is it okay to magnapoxy the overlap area after scuffing up the monsta that was already down or will that seal it in and affect the final curing of the portion under it? (Trying to decide about waiting to prime the top till just before that coat goes down see below).
2) On the sides the plan was to put down the monsta 3-4hrs after the magnapoxy. For the top I need to wait 24hrs to scuff up the overlap line so if I primed it all at once instead of waiting to prime the top per above that primer would be a day or two old by the time its coated depending on timing. Light scuff maybe if we put it all down at once to ensure a good bond?
Basically with the task at hand what combo of application would you suggest to ensure the BEST adhesion. I'm not trying to cut corners here, I want it done once/right.
pods8 is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
