Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 677 - JeepForum.com
 25Likes
post #10141 of 13379 Old 04-26-2013, 10:11 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Drooping suspension? Sounds like something on an old woman
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10142 of 13379 Old 04-26-2013, 10:11 AM
geiman
Originally Posted by DNFJ View Post
I have to use my hi-lift if I want to get my suspension to completely droop. Though I've only had to do it like once or twice.
Some bigger jack stands and a real floor jack would fix that. With a 4" suspension lift I can easily put the frame on jackstands and droop the suspension. That's without tires of course, which I can't see why you would need them on in that situation anyway.
But to each his own.
geiman is offline
post #10143 of 13379 Old 04-26-2013, 10:19 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Uh, even with 6 ton jack/stands I still have to crank it most of the way before it even starts lifting. From the ground to my "frame" rail it's about 24 inches.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #10144 of 13379 Old 04-26-2013, 10:21 AM
geiman
Pretty sure my jackstands are 6 ton as well, and I'm somewhere over 20 couple inches at the frame. Lifting from the axles and placing the jack stands under the frame just behind/in front of the control arm brackets I can let both axles droop as far as they can go. But that's on a TJ, YMMV with an XJ; I have no idea.
Regardless, I wouldn't use a widow maker anytime I don't have to.
geiman is offline
post #10145 of 13379 Old 04-26-2013, 10:26 AM
Holm-z
Holm-z's Avatar
Originally Posted by magnetman
Holm-z how long has that spray paint been cured?
Last full coat was 2 days ago, last night touched up a few other spots so only like 18 hours or so
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, ARB Front locker, 4.56 gears
I understand.
IAFF Local 3265
Holm-z is offline
post #10146 of 13379 Old 04-26-2013, 11:11 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Be careful, I would let fresh spray paint cure longer before ML
Connect with us on:
post #10147 of 13379 Old 04-26-2013, 03:39 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Look what brown brung here
Connect with us on:
post #10148 of 13379 Old 04-26-2013, 03:45 PM
outlawsix
okay I give up...what is it?
outlawsix is offline
post #10149 of 13379 Old 04-26-2013, 04:37 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
The vinyl cutter for window MONSTAs
Connect with us on:
post #10150 of 13379 Old 04-26-2013, 04:49 PM
smcutter
Originally Posted by smcutter View Post
I have the ACE Crawler Rock Rails that came as raw steel. I'd like to Monstaliner them, and I've seen how people have prepped painted surfaces and plastic surfaces, but I couldn't find anything on bare, raw steel.
^ This would've been a nice time to hear the chorus saying that Monstaliner isn't going to hold up on rock rails. You know... before I dropped $100 and permanently coated them.
Originally Posted by pods8 View Post
Lol, funny that some folks can't understand the limitations of paint.
It's funny you should say that. I thought I was paying $100 for something more than paint.
Why people put any kind of coating like bed liner or powder coat on skid plates, rocker guards, bumpers, etc. is beyond me.
Rust prevention was my intended goal. Tell me... how would you prevent rust on raw steel rock sliders? Just leave them bare?
Originally Posted by magnetman View Post
True.. even a high quality powder coating would have a problem with 1/2 the vehicle weight against the small area on that jack hook
The powder coating on my rock rails on my TJ held up just fine to repeated use of my Hi-Lift jack (but got scratched to hell in rock gardens, of course ). As for the earlier comment that the same would happen on my front bumper: I've often jacked it up by the powdercoated front bumper with no ill effects.
Also.. with the primer that many choose to use being rattle can crap, I want to say that epoxy primer would probably do better. Those spots appear to be down to the metal
Sure. If the epoxy primer had been available in smaller quantities, I definitely would've paid for it. But that's the whole reason I posted in here and asked you what to use on my raw steel sliders. Your response:
Avoid self etch primers. Too many issues with Monstaliner sticking well
Best locally available item for spot priming bare steel and small projects: Rustoleum "Automotive" Primer in spray cans
Bingo. Swapping out suspension components in my garage, and I don't have a floor jack. I use the Hi-Lift to get it up on a jack stand.
For the record, I'm probably judging you for your bad grammar or spelling.
smcutter is offline
post #10151 of 13379 Old 04-26-2013, 04:55 PM
smcutter
I don't mean to be a downer: I think the Monstaliner is a great product. It looks fantastic, it's relatively easy to apply, and the texture is great. I just hope nobody else buys it hoping/expecting that it'll be every bit as tough as powdercoating (or even Line-X). If I were lining my Jeep tub, I'd go with Monstaliner again no questions asked. But for anything that is expected to stand up to physical contact and lots of force, I wouldn't use the same product. If the consensus is that my expectations were unreasonable, that's fine... I just hope we can do a better job of helping n00bs in this thread set reasonable expectations in the future.
smcutter is offline
post #10152 of 13379 Old 04-26-2013, 06:14 PM
Tikijeep
Want!
Utah JeepCrew member # 131
Tikijeep is offline
post #10153 of 13379 Old 04-26-2013, 06:42 PM
lynskynbnd
1987 YJ Wrangler
Hey Eric,
I'm going to be spraying my YJ next weekend with the Dark Burnt Orange.
How much should I thin each gallon for spaying? With MEK?
What are the recommended settings for the Walcom Shutz gun?
Any other advice you can give me before I spray?
Everything has been coated with CS and I'm in the process of scuffing it all down again now. I will be cleaning and wiping everything with MEK before I start to spray.
lynskynbnd is offline
post #10154 of 13379 Old 04-26-2013, 07:15 PM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Now I'm upset, I want one!
Previous:
DNFJ is offline
post #10155 of 13379 Old 04-26-2013, 08:29 PM
Cuder
Is it a Bren cutter? I have been using one for 20 years and it still cuts like it's new. Pm me if you need any help with it or the program.
My Build Thread:
Cuder is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
