Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 676 - JeepForum.com
 44Likes
post #10126 of 13547 Old 04-26-2013, 08:04 AM
ashland82391
Originally Posted by DNFJ View Post
Try lifting a bumper with a high lift, but it at the very least creases slightly.
Guess bumpers aren't suited for use with a hi-lift. Or you can acknowledge the fact that hi-lift's lift arms have teeth, and 2000+ lbs of pressure on a single point it more likely to end up ripping up paint or bending metal.
Sounds like he should have stayed at the mall :-)
ashland82391 is offline
post #10127 of 13547 Old 04-26-2013, 08:06 AM
Holm-z
Originally Posted by magnetman
Go for it
That's the answer I was hoping for!! Thanks!
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, ARB Front locker, 4.56 gears
I understand.
IAFF Local 3265
Holm-z is offline
post #10128 of 13547 Old 04-26-2013, 08:12 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
If this is the contact surface we are talking about I think it would have been wise to put something between both surfaces
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10129 of 13547 Old 04-26-2013, 09:35 AM
pods8
Lol, funny that some folks can't understand the limitations of paint.
pods8 is offline
post #10130 of 13547 Old 04-26-2013, 09:44 AM
geiman
Originally Posted by smcutter View Post
I hate to say it, but I'm regretting my selection of Monstaliner for my particular application. I was super thorough with the prep, application, and drying of the Monstaliner. I was in a perfectly controlled environment and I followed the instructions to the letter.
However, I used my Hi-Lift to jack up my Jeep a few times today via the rock rails. I got underneath the Jeep just to make sure I hadn't scratched the Monstaliner off. Needless to say, staring at two patches where the Monstaliner had disappeared completely was a big surprise.
Has anyone else tried using this on outside surfaces and had problems with it being so easily removed?
If this stuff can't hold up to a Hi-Lift, it definitely isn't well suited for use on Rock Rails.
Why people put any kind of coating like bed liner or powder coat on skid plates, rocker guards, bumpers, etc. is beyond me. Something that will take abuse is the last place I'd waste time and money with anything fancy like that.
I don't see any liner holding up to repeated use on rocker guards unless you're staying at the mall; mine get dragged over rocks every time we go out, so obviously I'd expect whatever they're coated in to be scraped off. And that is exactly why the Monstaliner is inside the Jeep, and my rocker guards/bumpers/skidplates are coated with rattle can.
Plus, if you're actually using your rocker guards to slide over obstacles like rocks, why would you want something rough that would hinder your movement?
geiman is offline
post #10131 of 13547 Old 04-26-2013, 09:57 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Not everyone plays in the rocks
Connect with us on:
post #10132 of 13547 Old 04-26-2013, 09:58 AM
geiman
Completely understand; I should have been more clear. My point was that if you don't subject your vehicle to that kind of abuse, you probably don't want to be rubbing a big metal object all over the nice clean pieces you just painted either.
geiman is offline
post #10133 of 13547 Old 04-26-2013, 09:59 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Holm-z how long has that spray paint been cured?
Connect with us on:
post #10134 of 13547 Old 04-26-2013, 10:03 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
True.. even a high quality powder coating would have a problem with 1/2 the vehicle weight against the small area on that jack hook
Connect with us on:
post #10135 of 13547 Old 04-26-2013, 10:07 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Also.. with the primer that many choose to use being rattle can crap, I want to say that epoxy primer would probably do better. Those spots appear to be down to the metal
Connect with us on:
post #10136 of 13547 Old 04-26-2013, 10:40 AM
Rubicon0311
Jeeps come with bottle jacks.....to lift the vehicle safely from the frame....
Rubicon0311 is offline
post #10137 of 13547 Old 04-26-2013, 10:52 AM
DNFJ
What does this have to do with anything?
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #10138 of 13547 Old 04-26-2013, 11:00 AM
geiman
Well I'm not sure about lifting from the frame via the OE bottle jack, but I'm guessing he's saying to lift the Jeep properly instead of jacking from the rocker guards with a high lift.
I can see using the high lift if you're off-road and it's the best/safest option, but not really at home.
geiman is offline
post #10139 of 13547 Old 04-26-2013, 11:05 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You will always get damage that's beyond your control
In this situation, it was fully in control
Connect with us on:
post #10140 of 13547 Old 04-26-2013, 11:05 AM
DNFJ
I have to use my hi-lift if I want to get my suspension to completely droop. Though I've only had to do it like once or twice.
Previous:
DNFJ is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
