Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 673 - JeepForum.com
 21Likes
post #10081 of 13352 Old 04-21-2013, 10:03 PM
snicklefitz
Hi just got my kit quick question I'm doing the chassis saver then monstaliner over that on inside of my xj. How long between the coats of chassis saver and how long till monsta coat 1 and 2 ok thanks in advance
snicklefitz is offline
post #10082 of 13352 Old 04-22-2013, 06:36 AM
Cuder
Ordered a gallon kit of Lady in red last night. If you're going to order some, make sure you read the Promo page all the way thru before trying to order. I had to search for a little while before I found the coupon codes. But, I'm old and it was late.
My Build Thread:
Cuder is offline
post #10083 of 13352 Old 04-22-2013, 03:59 PM
lynskynbnd
1987 YJ Wrangler
I asked the same question a little bit ago.
Recoat Chassis saver after 3-5 hours or when dry to the touch. Apply Monstaliner within 24 hours or you'll have to rescuff the CS.
lynskynbnd is offline
post #10084 of 13352 Old 04-22-2013, 05:11 PM
snicklefitz
ok thanks a bunch for your help I appreciate it! also what about the silver stuff with the glue or goop under it do most take that up or paint over it?
post #10085 of 13352 Old 04-23-2013, 08:37 AM
Rubicon0311
Has anyone tried color matching a pewter GM truck? I love the product, used it in my tub, but now it's the trucks turn. Desert sand or Killer beej seems to be the closest, but I'm not too sure.
Rubicon0311 is offline
post #10086 of 13352 Old 04-23-2013, 09:43 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by JeepComanche89 View Post
Did my rear bumper today, dont know why i cant post pics in this thread but i posted one in the what did u do to your xj/mj today thread
her she is
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10087 of 13352 Old 04-23-2013, 09:44 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
What I miss here.. why are you guys comparing Rhino/Line-x to Monstaliner?
Connect with us on:
post #10088 of 13352 Old 04-23-2013, 09:48 AM
pods8
Jump back to post 10070. Someone talked about it not being tough but then someone else in defense incorrectly stated it was just as tough. In reality as you've pointed out its in the middle. I hopefully clarified that its a tough urethane paint but is not the same thing as polyurea.
pods8 is offline
post #10089 of 13352 Old 04-23-2013, 09:55 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Seriously considering painting my whole XJ in monstaliner.
Any way to avoid the texture, or lessen it? I assume different rollers would do the trick.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #10090 of 13352 Old 04-23-2013, 10:18 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
There's no way to completely avoid texture with ML. It's too thick. Flat, non-texture rollers make a mess
See in the far side of this sheet being rolled.. that's the texture after 2nd coat.
In the foreground of the pic, the coating is being re-rolled once it's gotten sticky to enhance the texture. If you simply avoid the re-rolling it lays flatter with a wavy surface and less bumpiness
Connect with us on:
post #10091 of 13352 Old 04-23-2013, 10:26 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
I'd want to go for a finish like this:
Looks like he just followed your instructions for applying it.
Previous:
DNFJ is offline
post #10092 of 13352 Old 04-23-2013, 10:54 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
That was sprayed
882514_354528801318188_1968203033_o.jpg   906954_354529307984804_1581594075_o.jpg   882020_354528951318173_1445467446_o.jpg   881979_358040090967059_1211073888_o.jpg
Connect with us on:
post #10093 of 13352 Old 04-23-2013, 11:14 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Looks like I'll be spraying the XJ then. Thanks for the extra pics.
Previous:
DNFJ is offline
post #10094 of 13352 Old 04-24-2013, 06:24 AM
hewesyourdaddy
2011 JK Wrangler
Magnetman,
I've got a coworker that just bought a new Wrangler in the color Rock Lobster. He's leaning towards ordering Monstaliner in black, but is curious if you have a comparable color match to the Rock Lobster.
hewesyourdaddy is offline
post #10095 of 13352 Old 04-24-2013, 08:20 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by hewesyourdaddy View Post
Magnetman,
I think that Road Rash will be close but it contains lead
We're working on lead free replacements for the 4 colors with lead
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
