Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 67 - JeepForum.com
 32Likes
post #991 of 13493 Old 04-10-2010, 08:03 PM
LuckRider
LuckRider's Avatar
I think he is trying to figure out how to get the thickest coat. I would just say working lightly (slopping it on and just smoothing it out rather than spreading it out).
Like said, the second coat should be thinner so that you actually get the texture.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #992 of 13493 Old 04-10-2010, 08:03 PM
FlynG
Originally Posted by LuckRider View Post
Yep, I have tons in my writeup thread: http://www.jeepforum.com/forum/f9/mo...ite-up-901675/
Great thanks for the pix and the link.
Do you notice a lot more engine heat now?
Flyn G
FlynG is offline
post #993 of 13493 Old 04-10-2010, 08:08 PM
burlyq
Thanks,
So best procedure is to go thick first and get some texture with later coats? Sounds like a plan.
burlyq is offline
post #994 of 13493 Old 04-10-2010, 08:08 PM
LuckRider
LuckRider's Avatar
I haven't noticed more engine heat. I have driven with the carpet in and out (after the install). The trans tunnel never really go warm either. I think the trans tunnel is the only part of a TJ floor that gets hot (because it is the only part that has the waning sticker). There is a heat shield protecting the tub from the exhaust.
I am pretty sure my tanny ran cool for an auto though. I could touch the tunnel with no problem before the liner. It only felt luke warm through the carpet, and barely warmer on just the metal.
Support Our Troops!
JFI Member #7:
post #995 of 13493 Old 04-10-2010, 08:10 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
He is doing inside a Bronco like the orange 72 Jimmy on the Monstaliner site. I spoke with him by phone yesterday.
Yes, slopping it on without leaving puddles will work.
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #996 of 13493 Old 04-10-2010, 10:00 PM
DaleII
Originally Posted by magnetman View Post
DaleII, are wanting to roll or spray silver?
I would go either way. Rolling would probably be easier, but I want to be able to get a really thick finally thickness. I want it for the heat and sound deadening. I'm willing to try either or as long as one isn't really expensive then the other. Silver will be more interesting to put on since I have a silver Jeep. I won't have the contrast of color. It would be like putting normal Monsta on a black Jeep.
2005 Silver LJ
DaleII is offline
post #997 of 13493 Old 04-10-2010, 10:02 PM
LuckRider
LuckRider's Avatar
MagnetMan, will it shine like the facotry paint? I know the black comes out like a satin if not duller.
Support Our Troops!
JFI Member #7:
post #998 of 13493 Old 04-10-2010, 10:08 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
No, colors will be slightly higher sheen than black but only a high satin.
Connect with us on:
post #999 of 13493 Old 04-10-2010, 10:11 PM
LuckRider
LuckRider's Avatar
Cool. I don't think it would be right if it was an all out gloss or semi gloss.
On a different note, I love how your sig changes colors
Support Our Troops!
JFI Member #7:
post #1000 of 13493 Old 04-10-2010, 10:13 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
How's the new banner look?
Connect with us on:
post #1001 of 13493 Old 04-10-2010, 10:23 PM
LuckRider
LuckRider's Avatar
It dances more. It is a little catchier. It did take me a moment to realize "Bride of" also switched colors, but I think that is part of what draws you in. It is always that thing that you don't notice that catches your attention the best.
Support Our Troops!
JFI Member #7:
post #1002 of 13493 Old 04-10-2010, 10:40 PM
David_M
Well, my 1 gallon kit has been sitting in the garage long enough. I have finally found the time and motivation to take on this project. I removed all the interior today and got the back half of the tub sanded down. Tomorrow I will finish all the sanding, cleaning, and taping off. I plan to roll the liner Monday.
I have a question. The kit came with 2 rollers. I have read where many people have used two for the first coat and one for the second. Can I pick up one of these locally? I don't recall see these types of rollers at home depot or lowes. What has everyone else been using? If I would have known ahead of time I would have just ordered an extra.
Thanks, David M
David_M is offline
post #1003 of 13493 Old 04-10-2010, 10:44 PM
LuckRider
LuckRider's Avatar
Thanks, David M
If you aren't going to use the rollers from the kit (or you are going to use a mix), I would suggest using a different roller for the first coat. You want to use the provided roller for the final coat to get the texture.
I do wonder if other type rollers would hold up. The Monstaliner is pretty mean stuff, and it can probably eat through it.
Support Our Troops!
JFI Member #7:
post #1004 of 13493 Old 04-10-2010, 10:50 PM
David_M
You raise a good piont. I agree with your suggestion about saving at least one of the supplied rollers for the second coat. I'll have to go out and see what I can find in the line of rollers tomorrow. I'd still like to hear from anyone else who ran into this problem, and what they used. Am I the only one who didn't think ahead?
David_M is offline
post #1005 of 13493 Old 04-10-2010, 11:36 PM
burlyq
On a hot day, how long will it take for the first coat to dry enough to put a second coat on?
burlyq is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
