Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 665 - JeepForum.com
 43Likes
post #9961 of 13541 Old 04-15-2013, 10:28 PM
pods8
Let the smoke escape on a cheap random orbital tonight, sanding fiberglass is rough on stuff. Motor windings get caked and cook. Low cost "disposable" sanders are handy unless you go really high end.
pods8 is offline
post #9962 of 13541 Old 04-16-2013, 12:26 AM
Sparrows
So whose buying the beer for the 10k party?
38
Cheers
June '13 YJOTM
Sparrows is offline
post #9963 of 13541 Old 04-16-2013, 12:36 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
38
Cheers
I'm buying
it's coming up fast.. maybe tonight!
37
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #9964 of 13541 Old 04-16-2013, 01:23 AM
outlawsix
When you started this endeavor.... how far, big did you envision it going?
36
outlawsix is offline
post #9965 of 13541 Old 04-16-2013, 01:24 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Pricing on 2 ounce Monstashades to go with tintable quarts is now visible on the ML web site
http://www.monstaliner.com/monstaliner_pricing.htm
Quarts go live for sale online next Monday 4/22/13
Quart kit includes: Tintable quart, catalyst pouch, plastic mixing cup, mini drill mixer, wooden paint stick (Kit does not include scuff pad or mini roller kit)
35
Connect with us on:
post #9966 of 13541 Old 04-16-2013, 01:26 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
36
I was grasping for straws when I stumbled on JF with my 2 gallon black kit
34
Connect with us on:
post #9967 of 13541 Old 04-16-2013, 02:13 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
What to do with a tintable quart?
A Mean Green Mother roll cage or a some Blood Bath Bumpers
33
monstaliner-mean-green-mother-rollbars-072.jpg   blood-bath-bumper_DSC_0305sm.jpg
Connect with us on:
post #9968 of 13541 Old 04-16-2013, 02:17 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Truck bed leftovers for some custom doggie steps
32
Connect with us on:
post #9969 of 13541 Old 04-16-2013, 06:29 AM
Loomie
I gotta feeling that today is the big day!
31!
Loomie is offline
post #9970 of 13541 Old 04-16-2013, 08:19 AM
crackedcornish
The Monstaliner FAQ says it will "bond to most clean/dry surfaces, including painted or primed steel, wood and fiberglass" but no mention of aluminum....Since a lot of paints have a problem sticking to aluminum, any special prep or primers needed, or can Monsta be applied directly to the aluminum??
and can I build up the thickness of Monstaliner (6-8 coats or more) in high traffic areas, or can it be applied too thick?
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #9971 of 13541 Old 04-16-2013, 08:25 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Updates are needed: Bare aluminum or steel can not be coated directly. Prime aluminum with 2 part epoxy primer for best adhesion. Scuff alum first to remove any oxidation and solvent clean with white rags until rags come up clean with no grayishness
You can do as many coats as you want just keep in mind the 8 hour recoat window for colors and if it cures more than 8 you need to wait 24 and scuff before recoat. Black has a much longer recoat window of at least 24 hours
Connect with us on:
post #9972 of 13541 Old 04-16-2013, 10:06 AM
lynskynbnd
1987 YJ Wrangler
I'm basecoating my YJ with Black Gloss CS this weekend. How many hours do I need to wait before I can do a second coat?
lynskynbnd is offline
post #9973 of 13541 Old 04-16-2013, 10:10 AM
lynskynbnd
1987 YJ Wrangler
Second question.
I placed an order Friday, 5336.
When will it ship out?
Thanks,
Bryan
post #9974 of 13541 Old 04-16-2013, 10:14 AM
Sparrows
http://youtu.be/TcJ-wNmazHQ
26
Cheers
edit: bleh, I don't know why the video won't embed...oh well
June '13 YJOTM
Sparrows is offline
post #9975 of 13541 Old 04-16-2013, 10:54 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Recoat CS with itself when you can run your fingertip across it without sticking. Depending on temps should be 3.5 - 6 hours
ML can go over CS in the same time frame or up to 24 hrs, after 24.. scuff CS first
Your order is shipping today
25
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
