Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 661 - JeepForum.com
 43Likes
post #9901 of 13541 Old 04-14-2013, 09:27 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by zaleski View Post
^^^ looks great man! i just did mine today too in read my lips red, looks like a clean job!!
zaleski take your time but hurry with pics
99
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #9902 of 13541 Old 04-14-2013, 09:46 AM
piglife68TJ99
99
x2!!!!
"The cure to the insurgency is the massacre" ~Alexander the Great~
Born in Detroit, Baptised on the beaches of Normandy.....Jeep!! Legends belong with legends.
piglife68TJ99 is offline
post #9903 of 13541 Old 04-14-2013, 09:56 AM
dmj13
0 - wash surfaces
1 - Scuff the old thoroughly
2 - vacuum it out
3 - check it well to make sure you did not miss any spots
4 - scuff more if needed, vacuum
5 - solvent clean with acetone or MEK
6 - roll
What color is your existing job, what color does friend have?
101
I did my interior in Desert Sand, he has the same. I was considering going to a darker grey or black because my interior is that funky diamond khaki color, and while the paint chip I got looked almost exactly matched, the finished color was just a lighter than the chip. Not bad, just not as close as i thought it would be.
As far as prep, though, pretty much the same as the original application over paint, huh? I was hoping Id get some slack on the elbow grease, but at least Ive done it once already!
'06 Rubi LJ- 3" Currie springs, Bilstein 5100s, JKS links, BPEs, Metal Cloak TBs, ZJ tierod/ends, Monstalined, KC Fogs, 32" Firestone A/Ts, PowerStop brakes, R.E. adj. CAs, 2 dogs 'n a KCCO sticker.
dmj13 is offline
post #9904 of 13541 Old 04-14-2013, 10:16 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Actually your scuffing is a bit more critical now because new coats of tintable will not stick to old without scuffing. You don't need to scuff it hard to remove texture, just dull it down well and scope out well for missed spots. Do not solvent wipe before vacuuming or it will be hard to see missed spots as the solvent will take away the whiteness from the scuffing
96
Connect with us on:
post #9905 of 13541 Old 04-14-2013, 11:18 AM
dmj13
So, as far as shelf life, how long could his gallon have been sitting around and still be good to use?
dmj13 is offline
post #9906 of 13541 Old 04-14-2013, 11:28 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
The tint is no issue but you want to make sure there are no pigments settled hard in the can. Get a flat ended popsicle stick and scrape along the bottom of the can to check
Catalyst is no problem
Tintable gallon
PM me the #'s on the top of the gallon can. There are 2 lines, lot # + date
55-xxx
date
94
Connect with us on:
post #9907 of 13541 Old 04-14-2013, 11:29 AM
jheck74
I was going through my basement and found the 1 gal black kit I had ordered back in 2011. The gallon can was upside down, so I must have flipped it over at some time. I might just open it and see what it looks like in there
" I have a mind like a steel trap.....things wander in here and get
mangled."
jheck74 is offline
post #9908 of 13541 Old 04-14-2013, 11:33 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Press down and knock on the lid. Does it feel like there is hard stuff under there?
92
Connect with us on:
post #9909 of 13541 Old 04-14-2013, 11:34 AM
dmj13
Tintable gallon
55-xxx
date
94
Once i hook up with the guy and get it i will send the info. Thanks for the quick response.
dmj13 is offline
post #9910 of 13541 Old 04-14-2013, 03:02 PM
JeepComanche89
1989 MJ Comanche
Whats with all the numbers?
JeepComanche89 is offline
post #9911 of 13541 Old 04-14-2013, 03:23 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
it's a count down
add the number to the post number, far right
89
Connect with us on:
post #9912 of 13541 Old 04-14-2013, 03:46 PM
JeepComanche89
1989 MJ Comanche
Countdown for what?
post #9913 of 13541 Old 04-14-2013, 04:24 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
When the thread hits 10,000 posts
Connect with us on:
post #9914 of 13541 Old 04-14-2013, 04:27 PM
jrallen
.....and then what happens?
jrallen is offline
post #9915 of 13541 Old 04-14-2013, 04:32 PM
moses21
We all die
moses21 is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
