Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 660 - JeepForum.com
 43Likes
post #9886 of 13541 Old 04-12-2013, 08:17 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by rda616 View Post
Hey Eric. I got the brackets out yesterday, so I would guess they will be there Monday. I showed a buddy a few pic's and he had to have some, so I'm putting in another order today.
Thanks again Ryan.
Thanks Ryan, I will but those things to good use.
We are planning to release acrylic enamel automotive paints color matched to all Monstashades colors.
Someone from the forum asked for a quart of paint to match his liner for door jams and a metal dash. This was a great idea so I thought to do a hinge painting kit so when an exterior is being done, the hinges can be painted with an exact match to the liner. Here's Apocalypse we made recently.
Manufacturers of CHASSIS SAVER™ Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #9887 of 13541 Old 04-12-2013, 08:21 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
113
Connect with us on:
post #9888 of 13541 Old 04-12-2013, 08:27 PM
ospreyfe55
2016 BU Renegade
That is a fantastic idea! Does it require any clear or it just s single stage? Once you have that all figured out you can sell a kit for the complete jeep! I will be doing my entire jeep in the next year, just haven't decided on color, but the kids want me to do turquila!
ospreyfe55 is offline
post #9889 of 13541 Old 04-12-2013, 08:34 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Turquila and Sans Panties are my 2 fav colors
Single stage acrylic enamel with small catalyst, no clear needed. This stuff can be brushed carefully with black foam like in the pic, or sprayed with a little reducer added. Eventually I also want to do 2K single stage acrylic urethane (Imron style)
It's a no brainer as we already have all the formulas. Ryan sent me old hinges so we could make some samples and take pics of diff colors
Connect with us on:
post #9890 of 13541 Old 04-12-2013, 08:37 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Opinions on my last post?
Pints or Quarts of this stuff?
Gallons will always be available
Connect with us on:
post #9891 of 13541 Old 04-12-2013, 08:41 PM
pods8
Can you get my density numbers for the stuff I ordered so I can mix by weight if needed?
Tintable monsta
Catalyst
White tint
Light grey tint
Mangnapoxy A
Mangnapoxy B
pods8 is offline
post #9892 of 13541 Old 04-12-2013, 08:48 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Tintable monsta
Catalyst
White tint
Light grey tint
Mangnapoxy A
Mangnapoxy B
Absolutely, I will have this for you in a few days? How soon are you starting?
Ahh.. epoxy primer formula is on my desk
1 to 1 mix by volume
Light Gray part = 14.28 lbs/gal
Clear part = 8.44 lbs/gal
Lt Gray @ 169 grams
Clear @ 100 grams
Connect with us on:
post #9893 of 13541 Old 04-12-2013, 08:51 PM
pods8
Couple weeks, I got time.
pods8 is offline
post #9894 of 13541 Old 04-13-2013, 08:20 AM
tractor1
1979 CJ5
106 Go with Quarts
1979 CJ5 304 T150 Dana 20 under construction
1993 Wrangler 4.0 HO AX15 231 4” lift 33 12.5 15 DD
1994 Wrangler 2.5 AX5 231 Stock Sold
1973 Cj5 304 T15 Dana20 Sold
tractor1 is offline
post #9895 of 13541 Old 04-13-2013, 05:39 PM
piglife68TJ99
A combination of the weather being nice and me doing my homework way early this week lead me to do this to the Jeep. Last night I disassembled, sanded w 80 grit sand paper and a wire wheel, cleaned the exterior with water and the dawn dish soap and water (pics of the finished prep work are as it was drying from the cleaning). This a.m. I checked for any missed clear coating there was none, I then wiped it down with MEK x 2 and taped it up and mixed the Blood Bath and started painting!!! 2.5 hours for the first coat, I waited 4 hours in between coats and then it took 1.5 hours for the second coat.
I am happy with the way it came out!!! I love the way the Pyroclastic (interior) and the Blood Bath work well together!!!!!! Letting it dry in the garage overnight (two fans blowing to circulate the air) as the sun is going bye bye and I will assemble it tomorrow afternoon after letting it sit in the sun in the a.m. for a few more hours. Ok let's hope I can submit this with all these pics.
"The cure to the insurgency is the massacre" ~Alexander the Great~
Born in Detroit, Baptised on the beaches of Normandy.....Jeep!! Legends belong with legends.
piglife68TJ99 is offline
post #9896 of 13541 Old 04-13-2013, 09:08 PM
zaleski
1979 CJ7
^^^ looks great man! i just did mine today too in read my lips red, looks like a clean job!!
zaleski is offline
post #9897 of 13541 Old 04-13-2013, 11:31 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
piglife68TJ99 that looks awesome, congrats!
Can't wait to see reassembled pics
103
Connect with us on:
post #9898 of 13541 Old 04-14-2013, 01:48 AM
dmj13
When i lined my LJ last summer i had the misfortune of choosing the hottest, most humid day of the year. The end result still looked good, but it set up so quick that it really needs another coat to be 100 percent. I ended up with some thin spots towards the end. What is the prep to lay down an additional coat on a currently monstalined tub? Also, i may be getting a free gallon and tint from a local guy who never ended up using it. His kit has been on a shelf for over a year. Is it still usable?
'06 Rubi LJ- 3" Currie springs, Bilstein 5100s, JKS links, BPEs, Metal Cloak TBs, ZJ tierod/ends, Monstalined, KC Fogs, 32" Firestone A/Ts, PowerStop brakes, R.E. adj. CAs, 2 dogs 'n a KCCO sticker.
dmj13 is offline
post #9899 of 13541 Old 04-14-2013, 08:11 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
0 - wash surfaces
1 - Scuff the old thoroughly
2 - vacuum it out
3 - check it well to make sure you did not miss any spots
4 - scuff more if needed, vacuum
5 - solvent clean with acetone or MEK
6 - roll
What color is your existing job, what color does friend have?
101
Connect with us on:
post #9900 of 13541 Old 04-14-2013, 08:37 AM
lynskynbnd
1987 YJ Wrangler
100
lynskynbnd is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
