Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 656 - JeepForum.com
 28Likes
post #9826 of 13416 Old 04-08-2013, 07:20 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by pods8 View Post
I see my shipping notification today (120lbs worth!), I'll get you a pyramid-o-cans shot on my camper.
That sounds cool because we bulk packed that order and I don't think there were any fancy ML labels on boxes
That's a big *** pile of cans you have coming
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #9827 of 13416 Old 04-08-2013, 07:22 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by hboy828 View Post
Visiting jail for my criminal justice class!
Those MEK fumes are brutal...
Save yourself man there is no justice in America any more
Connect with us on:
post #9828 of 13416 Old 04-08-2013, 07:40 PM
piglife68TJ99
I bought and recieved a poison spyder hood louvre and it is bare, what is the best way to prep it for monstaliner? I did my tub with the pyroclastic. Is the prep work the same or should I primer the hood louvre?
"The cure to the insurgency is the massacre" ~Alexander the Great~
Born in Detroit, Baptised on the beaches of Normandy.....Jeep!! Legends belong with legends.
piglife68TJ99 is offline
post #9829 of 13416 Old 04-09-2013, 12:13 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Any bare metal (steel or aluminum) needs to be primed.
Connect with us on:
post #9830 of 13416 Old 04-09-2013, 03:35 PM
JeepComanche89
1989 MJ Comanche
Looking to monstaline a rear steel bumper. Brand new metal, in primer. Is it ok to line over the primer, or should i spray it with a good spray paint first? Some of the part(brackets) will hve to be painted anyway. Just wondering if i would get better adhesion on the primer, or a finished surface?
JeepComanche89 is offline
post #9831 of 13416 Old 04-09-2013, 04:26 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Scotchbrite or green/maroon/brown pad primer very lightly and ML right over primer
If you put fresh spray paint and then ML over it you will have grief. It will lift the spray paint or wrinkle the spray paint as if you put paint remover on it
Edit: It's impossible to know the quality of primers used by the people building bumpers. Scratch it gently with fingernail. Is it hard and stuck on the metal good?
Connect with us on:
post #9832 of 13416 Old 04-09-2013, 05:57 PM
JeepComanche89
1989 MJ Comanche
It seems pretty tough. I used a SEM high build primer, in a aerosol can. It was from a bodyshop supply store, so its a pro grade product. I will check to make sure that its good anyway.
post #9833 of 13416 Old 04-09-2013, 07:04 PM
JeepComanche89
1989 MJ Comanche
Im sure this question has also been asked 1000 times, but about how much sf does i gal cover? Im thinking of buying a gallon for my bed, and an extra quart for the bumper
post #9834 of 13416 Old 04-09-2013, 07:13 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
60 sq ft per gal in 2 coats
Quart does 15 sq ft
Connect with us on:
post #9835 of 13416 Old 04-09-2013, 07:24 PM
JeepComanche89
1989 MJ Comanche
Quart does 15 sq ft
Gal does 60 sf twice?
post #9836 of 13416 Old 04-09-2013, 07:47 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
This has.. on occasion even twisted my brain explaining
No.. I mean yes or no
** To get the correct thickness... 1 gallon is designed to cover 60 sq ft but it is done in 2 coats
Does that make better sense?
Connect with us on:
post #9837 of 13416 Old 04-09-2013, 07:49 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
If you started rolling .. or spraying and you stopped after going 60 sq ft... you should have 1/2 gallon remaining for the 2nd coat
Connect with us on:
post #9838 of 13416 Old 04-09-2013, 07:52 PM
JeepComanche89
1989 MJ Comanche
Haha think i got it now. I can cover 60 sq ft with one gallon. But i will need two coats to achieve desired results. And i can do this all with 1 gallon.
post #9839 of 13416 Old 04-09-2013, 07:53 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
1 gallon goes 120 sq ft in 1 coat
Split that in 1/2
Back it off to 60 sq ft and you have enough to do the recommended 2 coats
Connect with us on:
post #9840 of 13416 Old 04-09-2013, 07:54 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
