Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 654 - JeepForum.com
 36Likes
post #9796 of 13514 Old 04-07-2013, 06:24 AM
rda616
Originally Posted by magnetman View Post
Does anyone have some old hinges not needed?
Door or hood don't matter
If you are still looking for hinges I have door, hood and window hinges off my 98. They are a bit rusty and would need blasted to be perfect, but you would be saving them from the scrap bin if you want them.
rda616 is offline
post #9797 of 13514 Old 04-07-2013, 07:49 AM
PaulisTJ
Hey magnetman is there anyway you could post a picture of a thinned and filtered ML? I'm looking to do something similar to what Viencent did. Well I can't really tell just from pictures but I'm looking for a texture more like link below(the small square is a chip of monsta, while the rest is herc). I'm not looking for a "smoother" finish rather a tighter with less big bulges I guess. Hard to explain but I assume this is obtained through filtering which is why I ask. I realize Monsta, Herc and other products are comparing apples to oranges. But from my research Monsta has a better track record and would rather stick with it, just trying to see if I can achieve different textures.
PaulisTJ is offline
post #9798 of 13514 Old 04-07-2013, 09:02 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by zaleski View Post
i would say i used i used between 1/4-1/3 of a gallon for the first coat. im all ears! should i be going lighter on the first and heavier on second? there was 3 spots where i can see runs, and they were on corners, i think i failed to inspect it closely enough. Im still happy with how it turned out though.
Basically yes, you want to work it out more on the 1st coat so it's thinner. No heavy buildup. Roll it out so you see some of the primed surface still showing through.
When 1st mixed, the coating is much thinner than after it sits waiting to roll the 2nd coat so it's much easier to spread thin during 1st coat. This also works in you favor because it's harder to cause runs in the 2nd coat when it's thick and gooey
EVERYONE: This is normal for what the 1st coat should look like. You should never try to get full coverage on 1st coat. The object is to conserve as much coating for 2nd coat as possible
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #9799 of 13514 Old 04-07-2013, 09:05 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Yes I would like them. Someone else also has set for me but more is better for what I'm doing
Do you want me to send you a UPS ship label and you drop it at a UPS store?
Connect with us on:
post #9800 of 13514 Old 04-07-2013, 09:12 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
That is the COOLEST thing I have ever seen. Avid Zombie Slayer myself, going on 12 years of obsession now! Absolutely love it! I wish I was gutsy enough to do something like that myself!
You ever find yourself in Boise, beers are on me!
Cheers
The guy is in OK city and is going to be doing another vehicle like that. I'm getting him some foam blocks to do a zombie face stamp for the front end
Connect with us on:
post #9801 of 13514 Old 04-07-2013, 09:13 AM
rda616
That would be great. I would rather them go to a good cause then wind up a kia fender. I'll pm you my email!
rda616 is offline
post #9802 of 13514 Old 04-07-2013, 09:19 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Sorry to tell you this but I do not think you can get that look with Monstaliner
Tightest texture is not achieved by thinning but by re-rolling when it is very sticky
Connect with us on:
post #9803 of 13514 Old 04-07-2013, 11:33 AM
rda616
Here's rescue7's project.
Not everyone has the time and resources to get it done like he has with almost complete disassembly... but this is the absolute right way to do this
This looks absolutely amazing.. Great job rescue7!
rda616 is offline
post #9804 of 13514 Old 04-07-2013, 12:05 PM
rescue7
Thanks a lot man! I appreciate it.
rescue7 is offline
post #9805 of 13514 Old 04-07-2013, 12:16 PM
platym
Magnetman, the green monstaliner above, is that Johnny Popper?
platym is offline
post #9806 of 13514 Old 04-07-2013, 12:40 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I believe so
Connect with us on:
post #9807 of 13514 Old 04-07-2013, 02:54 PM
hboy828
Anybody have an idea on how to remove the center console out of early tj's with the auto? The shift bezel thing is in the way of the console lifting up
hboy828 is offline
post #9808 of 13514 Old 04-07-2013, 03:08 PM
rda616
IIRC the t handle just presses on. All you need to do is pull really hard upward and it should come off. I have managed to fish the console around the handle and selector cover but it's a pita. Puting it in 1st gear doesn't hurt either.
rda616 is offline
post #9809 of 13514 Old 04-07-2013, 03:19 PM
Sparrows
Hey Eric,
I think I'm changing my plan. I'm thinking of going with one of the tan colors now to give my jeep a more "Post-Apocalyptic" feel. Can you tell me what Pass the Bubbly, Yank My Doodle, and Killer Beej are similar too? I'm assuming they are champaign, cooked pasta, and, uh, ???. But it seems like most of your colors are based on a similar "factory" paint color, and being able to look into those may give me a better idea of how they turn out finished. I haven't been able to find any pics of those colors used, and I can't remember where the pic of the Cherokee was that was done in Desert Sand. You mind digging it up?
Thanks man!
Cheers
June '13 YJOTM
Sparrows is offline
post #9810 of 13514 Old 04-07-2013, 04:24 PM
flcracker
Hood Shots!!
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
