Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 629 - JeepForum.com
 36Likes
post #9421 of 13514 Old 01-17-2013, 11:11 AM
ZCherokee4x4
1994 XJ Cherokee
Ok, I'd hate to get into it and not have enough, but then I don't want to buy too much because I'm on a tight budget.
I'd double check with Eric though. Get. The square feet if you want an accurate amount. And I know what you mean, the first time I ordered it I got one gallon and only used half of it and of course the life for this stuff isn't even 10 hours so it ended up in the trash.
ZCherokee4x4 is offline
post #9422 of 13514 Old 01-17-2013, 11:22 AM
ashland82391
Ok, I'll measure it out when I get some time and I'll post back on here
ashland82391 is offline
post #9423 of 13514 Old 01-17-2013, 11:31 AM
ZCherokee4x4
1994 XJ Cherokee
Alright cool
post #9424 of 13514 Old 01-17-2013, 02:46 PM
RedlegWJ
Don't heat the vehicle or the ML directly or you'll risk wrinkling. I did my cargo area last year (inside of vehicle) while in the upper 40's. Had fums for a LONG time but they did go away, so cure time is a lot longer. They recommend spraying a light mist after a few hours to help speed curing though. I would make CERTAIN it was cured before taking it on our salty roads though.
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline
post #9425 of 13514 Old 01-18-2013, 10:24 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Latest Hood Shot from Columbus, NE
Before
Road Rash
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #9426 of 13514 Old 01-19-2013, 10:41 PM
moses21
Hey magnet man I messaged you a couple questions. for a 4 door jeep Cherokee exterior would I need the 2 gallon kit. I also do you just dump the titable stuff into the gallon and mix it?
moses21 is offline
post #9427 of 13514 Old 01-20-2013, 05:21 PM
hewesyourdaddy
2011 JK Wrangler
Can't wait for the weather to warm up a little so I can get my tub lined with Urine Trouble!!! Monstaliner looks like a superior product compared to other brands out there. I got my sample chips in last week and I'm highly impressed with color match and texture.
hewesyourdaddy is offline
post #9428 of 13514 Old 01-20-2013, 05:29 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Sorry I just found your PM, will get back to you tonight
Connect with us on:
post #9429 of 13514 Old 01-20-2013, 05:30 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
What color is your exterior paint?
Just curious what you matching Urine Trouble up against
Connect with us on:
post #9430 of 13514 Old 01-20-2013, 06:15 PM
crackedcornish
there's a chip available for Urine Trouble??
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #9431 of 13514 Old 01-20-2013, 06:42 PM
Sparrows
Magnetman,
I was getting ready to order a 1 gallon kit of Predator (that's the correct amount for the exterior of a YJ right?) but I stopped when I noticed that you recommend white primer. My YJ has half the exterior of the tub already Rhino Lined in black. The rest is factory white paint. I did some googling but couldn't find a good answer to whether or not you can prime over Rhino Liner. People who tried had good luck with self etching primer, but I seem to remember reading in one of these threads that self etching primer and Monstaliner don't play well together. Am I remembering that correctly?
What, if anything, do you recommend I do? I finally settled on a color, but I don't want to proceed if I'm going to have less that satisfactory results. I'd honestly rather go with my 2nd choice color instead of ending up with a trashy, half-as$ed looking job.
Any insight/help would be awesome. Thanks in advance!
Cheers!
Sparrows is offline
post #9432 of 13514 Old 01-20-2013, 06:48 PM
hewesyourdaddy
2011 JK Wrangler
Magnetman, my Jeep is solar yellow. If Urine Trouble wasn't supposed to be a match for that color then that's one heck of a coincidence.... I may end up doing the grille, too.
post #9433 of 13514 Old 01-20-2013, 06:53 PM
hewesyourdaddy
2011 JK Wrangler
I didn't think it was available either, but I requested it (if available) in the additional comments section when i placed the order. Looks great..
post #9434 of 13514 Old 01-21-2013, 09:20 AM
BAMFpullin719
I approached magnetman over the summer and asked if he'd be willing to try a factory yellow color for 00 tj. Swapping tubs on a +10 year old jeep i was sure the yellows would be faded/different so it was paint it (and cry everytime i scratched it) or line it and keep hammerin. The other 3 yellows were to lemon-white or schoolbus looking. He mixed it up and im super impressed with the job he did. My jeep looks great and i cant wait to show it off at the wheelin events coming up.
Alot of people ask how it washes, mud, road spray, and everything else comes of great, some light scrubbin with a brush is needed sometimes, i have a few spots i go some grease on it and thosebi have to scrub with degreaser before it cleans up but what a great product! Wish i was a little more ahead in life, i would totally start/join a garage to spray monsta for a living. I will pist ip some high res pics of urine trouble shortly
"4 low, 2nd gear, skinny peddle on the right"
bought not built, broke, then rebuilt
you thought you had rust?
BAMFpullin719 is offline
post #9435 of 13514 Old 01-21-2013, 09:30 AM
BAMFpullin719
Forgot to get some with my doors on when my sister was snapping pics but i will get some more this week and post em. I sprayed mine 80-100psi.
image-2870809234.jpg   image-1883266853.jpg   image-811870859.jpg   image-838755946.jpg   image-2630170265.jpg
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
