Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 619 - JeepForum.com
 21Likes
post #9271 of 13352 Old 11-27-2012, 06:21 PM
TJSWJ
Just ordered 2 gallons of CS, thanks for the great deals!
TJSWJ is offline
post #9272 of 13352 Old 11-27-2012, 06:22 PM
jlsalani
I just put Chassis Saver on the underbody and new front floor of my kids Cherokee.
and it is awesome.... I now want to Monstaline the entire interior floor now, but have a few questions. I have tried to contact you but can't get through the tech line. There is a large stick on liner in the rear floor and 2 on the rear wheel house. do I have to remove them?? I can probably get the ones off the wheel house but not the rear load floor.... also what temp can it go down to for it still to work?? Looks like a bit of a warm up coming and I need to get it down soon. Thanks
jlsalani is offline
post #9273 of 13352 Old 11-27-2012, 07:10 PM
cjjon7
1983 CJ7
Magnet, what is the reccomended solvent to wipe down a truck bed with prior to lining, after sanding? Thanks
cjjon7 is offline
post #9274 of 13352 Old 11-27-2012, 08:29 PM
BuckeyeNative
BuckeyeNative's Avatar
1974 CJ5
Ordered some of the CS last night...thanks
BuckeyeNative is offline
post #9275 of 13352 Old 11-27-2012, 08:34 PM
BuckeyeNative
1974 CJ5
Originally Posted by rodgers3 View Post
how much ml did that take i would like to do this to mine in the spring/summer
x2
post #9276 of 13352 Old 11-28-2012, 10:12 AM
TroubleNEO
Originally Posted by cjjon7 View Post
magnet, what is the reccomended solvent to wipe down a truck bed with prior to lining, after sanding? Thanks
mek
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline
post #9277 of 13352 Old 11-28-2012, 04:58 PM
Jims-87YJ
1987 YJ Wrangler
Originally Posted by TroubleNEO View Post
mek
x2 (or MEK substitute that's what I used)
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #9278 of 13352 Old 11-28-2012, 06:08 PM
Mr.ThunderMakeR
Originally Posted by magnetman View Post
I can swing a repair kit in LQG which will be enough to do that. Contact me after Wed this coming week
Whats the best way to contact you? Through the JF personal message?
- '91 Jeep Wrangler YJ, 4" lift with 33" BFG KM2's, 1" body lift, NV3550 swap, NP241OR Rubicon TCase w/ Novak Cable Shifter, Monstalined Tub
- '09 Mazda RX-8 R3
Mr.ThunderMakeR is offline
post #9279 of 13352 Old 11-28-2012, 10:56 PM
goonies
Are you guys still looking for retail vendors? Ive left voicemails, emails, and messages through JF and FB looking for some info over the last few months with no response. Our shop is in Patchogue and i have a ton of Jeep customers as well as alot of classic muscle car and hotrod customers. All asking me about POR 15 and bed liner products. Whatsa guy gotta do to get in touch with someone in charge over there LOL. Id like to deal with a local company like you guys. Please PM me with some info.
goonies is offline
post #9280 of 13352 Old 11-29-2012, 09:56 PM
Copperhead89
Well, this weekend is FINALLY the weekend I get to lay down the Monstaliner on the bottom of my '89 tub. I'll be spraying it with Eric's Walcom gun. The color is Medium Quartz Gray. All of the rusty areas, courtesy of the salty air and wintery roads of Long island where she lived the past 22 years, will be covered in two coats of silver Chassis Saver on Friday night. The next morning around 9am, I will shoot two coats of Dupont Corlar 2.1 ST epoxy primer (actually, its labeled as a mastic, because its so thick). Then, about 3 or 4 hours later, I'll lay down the first coat of the Monsta. Wish me luck!!!
Here is a "before" pic, all scuff sanded with 100 grit paper. A couple months ago, I blasted off every bit of the undercoating with my pressure washer, and completely de-greased it as well.
***LATE BREAKING UPDATE #1***
Well....my plans for doing the bottom of my tub tomorrow have been shot to hell. While going through the instructions for the first time tonight, I took inventory of what I had received, and I quickly realized that I didn't get a can of catalyst!! No catalyst, no Monsta. The crappy part of it is, tonight I brushed on the first coat of Chassis Saver. I'll have to re-scuff those areas.
***LATE BREAKING UPDATE #2***
I called and spoke to someone at Magnet Paints this morning. They were very helpful, and said they will be shipping out the catalyst to me today.
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline
post #9281 of 13352 Old 11-30-2012, 08:22 AM
Jims-87YJ
1987 YJ Wrangler
Wow Looks good, just like mine did a few months back. When spraying the drying times between coats for me was just a couple hrs if that. So just keep an eye on it. Make sure you still have a small brush as there are a lot of places it is hard to get coverage with the gun, pockets behind the tail lights for example and under some of the cross members. Good luck.
My build thread:
post #9282 of 13352 Old 11-30-2012, 02:21 PM
Mr.ThunderMakeR
magnetman, I'm having trouble getting in contact with you or someone at Magnet Paints. I tried calling yesterday and got someone on the phone, not sure who it was, but he put me through to your voicemail and told me to leave a message and you would get back to me today. I tried calling again today but the message said the office was closed (at around 3PM EST).
I need to get this ordered soon as this is preventing me from finishing my trans/tcase swap.
- '09 Mazda RX-8 R3
post #9283 of 13352 Old 11-30-2012, 06:59 PM
misfit77
Do you guys have a color match for Jeep color J7 AKA Chargold 2 S/G Pearl?
I was going to use black on top and bottom of my ZJ, but would consider matching the current color.
misfit77 is offline
post #9284 of 13352 Old 11-30-2012, 10:42 PM
Copperhead89
post #9285 of 13352 Old 12-01-2012, 09:31 PM
misfit77
misfit77 is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
