Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 61 - JeepForum.com
 21Likes
post #901 of 13349 Old 04-06-2010, 02:03 PM
LuckRider
LuckRider's Avatar
Originally Posted by erickpl View Post
Sigs can be turned on and off in your profile.
Got my package yesterday packed very nicely!!! Small dent in the chassis saver can but no leaks!
Picked up sponge brushes, 60 grit paper and block, and a breather mask for paint fumes.
I think Keith is having an issue with images. Anything that is listed as an attachment is loading really small. He is supposed to be fixing those issues today. That might be why there is an issue with the pic in your sig MagnetMan. Go to edit sig and check the bottom of the page for permissions. As far as I know, only vendors have the ability to use images in sigs. That might be messed up right now.
As for the Breather mask, good call. It can be pretty strong, even in a well ventilated area. We had the garage door open and you could really smell it. I would also suggest leaving the garage door open, or the Jeep outside as it cures. My downstairs smelt like paint for 2 days because the door was closed at night.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #902 of 13349 Old 04-06-2010, 05:59 PM
erickpl
erickpl's Avatar
Where I work, safety is always an issue. While not really called for in this application, why not take proper precautions with ventilation and filtration...
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #903 of 13349 Old 04-06-2010, 06:02 PM
aerojeeptj
That MEK stuff is pretty nasty, I literally held my breath while I wiped the floor pans with it because the fumes were VERY strong!!
aerojeeptj is offline
post #904 of 13349 Old 04-06-2010, 06:07 PM
LuckRider
LuckRider's Avatar
Have you lined yet? I found the Liner to be stronger than the MEK. Then again, the MEK and the Liner might irritate differently. The MEK didn't bother me much, and I found it to work well on hands so I used that to clean mine.
Support Our Troops!
JFI Member #7:
post #905 of 13349 Old 04-06-2010, 06:13 PM
aerojeeptj
Noo haven't lined yet :/ I just rustproofed the rust spots with the chassis saver. You are right though, MEK can definitely clean well. I got chassis saver on the laundry room tub and it seemed it was permanently on there until I tried rubbing it out with MEK and sure enough it came off. I noticed it turns my finger tips dry and white (until you wash with soap) I'm pretty sure that MEK probably has some carcinogens in it, it's probably something you shouldn't wash your hands with all the time lol. Anyways, I'm hoping to get the liner on soon, I'm extremely anxious but just don't have the time yet!
post #906 of 13349 Old 04-06-2010, 06:17 PM
LuckRider
LuckRider's Avatar
lol, sounds good. I definitely would clean my hands with it all the time since it does turn hands white and chalky. We used it to clean out our spray gun when we ran oil based paint through it (purposely). The mek cleaned out the gun, and it looked like new.
Support Our Troops!
JFI Member #7:
post #907 of 13349 Old 04-06-2010, 06:19 PM
aerojeeptj
I think it's amazing how good it works but I'm always going to use it as a last resort
post #908 of 13349 Old 04-06-2010, 07:12 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
MEK smells gooooood. Adn I cna't fnid nay evodnece onlien taht ti cuases drain bramage
Sorry, that was a symptom of overexposure. Flammability is #1 caution followed by breathing too much in a confined space but mainly for long periods of time. If you are working with decent ventilation it should be minimal risk. No determination on MEK causing cancer and it does not accumulate in the body.
Just don't work with it in a closed up garage with open flame!
Manufacturers of CHASSIS SAVER™ Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #909 of 13349 Old 04-06-2010, 07:32 PM
Ironworker709
Ironworker709's Avatar
lol
I'm probably the living proof that it DOES cause brain damage ( so the lil lady says i have brain damage anyhow..lol)
I've been around and used it ALOT in Structural Fabrication shops,it's regularly used on steel before it is painted with primer and coatings to rid the grease and oils.
Anytime we've used it,it had to be either outside or in a paint booth with ventilation systems,and wearing respirators or HUGE fines were placed to the owners from OSHA...so there IS some kind of serious danger to the health.I would think that stuff would do some serious damage to lungs and throat with the way it eats away at chemicals and coatings.
I've had work gloves that practictly fell apart a few days after some of the MEK had gotten onto them,probably from drying them out so much,chemicaly safe rubber gloves work best and respirators(not the dust mask type),i wouldn't personaly want to be the guinea pig if it actualy is dangerous to the health.
Bottom line is..be safe,safety should always be No 1 in a persons life...I've seen too many lil kids and other halves lose their loved ones because the person said"'ahhhh..it won't happen to me!"
Just lil note...lol...still waitin on the Spice color
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #910 of 13349 Old 04-06-2010, 07:39 PM
LuckRider
LuckRider's Avatar
Wow that is a long sentence. Anyways, the finger on one of the gloves that came with the kit just disappeared on my dad when the MEK hit it. It was kind of funny. I looked over and asked what happened to his finger, and he said the glove just disintegrated.
Support Our Troops!
JFI Member #7:
post #911 of 13349 Old 04-06-2010, 07:42 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
lol
Agreed upon regarding safety to avoid being sorry.
Overexposure is what needs to be avoided and common sense needs to be observed.
Work fast, breathe little and run fast if you see flames.
AND DON'T SMOKE WHILE WIPING YOUR TUB DOWN!
Connect with us on:
post #912 of 13349 Old 04-06-2010, 09:22 PM
aerojeeptj
I was wearing rubber gloves and they starting wrinkling up and became weak after MEK came in contact. I didn't even see my buddy get any on his hands but he must of because the skin on his hands suddenly turned dry as was peeling! He was confused but thought it was kinda funny, I made him wash his hands lol
post #913 of 13349 Old 04-06-2010, 10:36 PM
tangotag
Look into using "Butyl Rubber Gloves" for safely working with MEK.
These are expensive around $20 a pair but will last a while.
Army's MOPP Level 4 Gloves for those who had the pleasure.
The more common Nitrile gloves won't last long using direct contact with MEK. A lesson from past experience.
tangotag is offline
post #914 of 13349 Old 04-07-2010, 11:06 PM
apexjeepinjoe
I hope you all know that MEK goes straight to your liver through your skin. So please wear the correct gloves.
~Joe~
2012 Wrangler Rubicon(my woman's ride)
2002 Wrangler Apex Edition(with lots of goodies)
1988 Comanche(stock for now)
1970 Jeepster Commando(a work In progress)
apexjeepinjoe is offline
post #915 of 13349 Old 04-07-2010, 11:19 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Please don't post information that is incomplete.
The paragraph below comes from this link: OSH Answers: 2-Health Effects of Methyl Ethyl Ketone
Q: Is there potential for methyl ethyl ketone to build-up or accumulate in my body?
MEK does not accumulate in the body. It is rapidly absorbed by inhalation, skin contact and ingestion and transferred into the blood and other tissues.
MEK is metabolized in the liver, mainly to 3-hydroxy-2-butanone and 2,3-butanediol which are eliminated in urine. Most MEK probably enters the
general metabolism in the body and is converted to acetate which is eventually broken down to carbon dioxide and water which are then
eliminated in exhaled air and urine. Small amounts of MEK itself are also eliminated in exhaled air and urine. MEK and its metabolites are mostly
cleared from the body within 24 hours.
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
