Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 608 - JeepForum.com
 34Likes
post #9106 of 13506 Old 10-05-2012, 10:46 PM
mooncruiser
Originally Posted by ospreyfe55 View Post
I went ahead and used some self etching primer to all the bare metal spots. So the gloss black is the one to use with ML? I remember talking to Eric about it and I ended up with gloss black in my kit. But vaguely remember him mentioning that satin or gloss was not compatible. So when I opened the box and to my surprise was black!!! But it's gloss.
Eric told me not to use self etching primer, that they've had some issues with ML bonding to it...Go over that(self etching primer) with Rustoleum Automobile Primer, he recommended that in one of his posts and i spoke to him regarding the Rustoleum.You dont need to scuff the Rustoleum. If you don't apply ML within the cure time of the Chassis Saver you'll need to scuff the CS before applying the ML.
mooncruiser is offline
post #9107 of 13506 Old 10-05-2012, 10:50 PM
mooncruiser
http://www.rustoleum.com/cbgproduct.asp?pid=37
post #9108 of 13506 Old 10-05-2012, 11:06 PM
ospreyfe55
2016 BU Renegade
Awesome! That's something I wish I knew before hand! With limited time to complete my jeep, this is definitely not what I wanted to hear! So I guess just spray a few more coats with the rustoleum primer?
ospreyfe55 is offline
post #9109 of 13506 Old 10-05-2012, 11:11 PM
mooncruiser
I feel your pain! I went ahead and lightly sanded the self-etching primer I put on, wiped it clean and and then sprayed the Rusto...not sure if it was necessary
post #9110 of 13506 Old 10-05-2012, 11:13 PM
mooncruiser
I don't think you need a few coats, just cover the self-etching with the Rusto and away you go!
post #9111 of 13506 Old 10-05-2012, 11:43 PM
ospreyfe55
2016 BU Renegade
What about using CS over the self etching primer? Also where can I find the rusto primer? Ive seen duplicolor and similar brands but cant recall where I have seen the Rusto. Also just cover the self etching primer with the rusto and I should be good to go?
post #9112 of 13506 Old 10-05-2012, 11:49 PM
mooncruiser
Rusto I bought at ACE, probably find it at HD or Lowes? Eric didnt say anything about the CS over self-etching. I would imagine it would be fine, that stuff will stick to anything, it's tough stuff. Just remember to scuff that CS if you go bast the cure time-I think it's 8-10 hours..maybe someone else can chime in regarding the cure time of CS??
post #9113 of 13506 Old 10-06-2012, 06:46 AM
RedlegWJ
Wait a minute. I thought Magnetman said not to apply over aerosol products?
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline
post #9114 of 13506 Old 10-06-2012, 08:41 AM
mooncruiser
Never heard that-if you do a search, you will find where Eric recommends and even post a picture of the Rustoleum Automobile Primer.
post #9115 of 13506 Old 10-06-2012, 08:51 AM
ospreyfe55
2016 BU Renegade
Yep I sent Eric and email late last night and I woke up to his kind words! And a pic of the What rustoleum primer to get! They have it at lowes and now back to the jeep! Hopefully I can get to lining today or first thing in the morning! I'm on day 2 and the wife is already complaining! Mooncruiser it's the exact primer you mention above in the link. Thanks man, now lets just hope the gallon is enough for the job!
Also so I can mix the whole gallon at one time and it should be good for the second coat
post #9116 of 13506 Old 10-06-2012, 09:07 AM
mooncruiser
No problem, good luck and yep, just mix the entire gallon. Post pics when you're done.
post #9117 of 13506 Old 10-06-2012, 11:13 AM
tjsean0308
Well crap I just put the montsa over self etching primer. It was an autobody professional quality brand Aeropro. I had never heard of it, the paint shop guy said he sells a ton of it and never heard a bad word. That makes me feel a bit better but I guess time will tell.
tjsean0308 is offline
post #9118 of 13506 Old 10-06-2012, 02:33 PM
tangotag
He said not too long ago that there had been too many failures over self etching primers.
No go on self etching primer
Stick with epoxy primers.
tangotag is offline
post #9119 of 13506 Old 10-06-2012, 04:11 PM
ospreyfe55
2016 BU Renegade
Well so far I am very disappointed in the prep work involved leading up to rolling the liner. The instructions are very vague! It doesn't mention anything about what or how to prep the surface when dealing with bare metal and It seems that I had to jump through hoops just to figure out what I needed to do, because everything that I now about prepping bare metal is/was wrong when using this product. And now I have spend a good portion of the day fixing it. Now I am about ready to lay down the liner and what do I use to do a final wipe down, because if I use the MEK or prep solvent it takes the primer off!
post #9120 of 13506 Old 10-06-2012, 04:19 PM
inovermyhead2
As far as the self etching primer is concerned, it is the single component primer that is the problem (aerosol type). A "2K" professional self etching primer should be fine. 2K being (2) component or simply put, it requires mixing with another chemical before it cam be applied. Just never use an aerosol self etching primer.
1983 CJ7
350ci Chevy
SM465 Trans
Rancho 2 1/2" lift
Confer Engineering Shackles
32x11.50x15 BFG All Terrains
whoever invented Torx bolts should be shot in the face, burned then pissed on - saskcj7
inovermyhead2 is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
