Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 606 - JeepForum.com
 29Likes
post #9076 of 13469 Old 10-02-2012, 11:36 AM
ospreyfe55
2016 BU Renegade
MEK (substitute)???
ospreyfe55 is offline
post #9077 of 13469 Old 10-02-2012, 01:37 PM
Jims-87YJ
1987 YJ Wrangler
Yes I could not find MEK, but Lowe's sells Sells a product called "MEK substitute" that Magnetman says works just as well.
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #9078 of 13469 Old 10-02-2012, 02:05 PM
tangotag
I put in one gallon Black ML on my Inca Gold TJ tub. It took all of the one gallon in 2 coats rolled to cover it so none of the original color came through. I would guess a LJ would run a little thin.
tangotag is offline
post #9079 of 13469 Old 10-02-2012, 04:26 PM
mooncruiser
MEK substitute is fine - Ace Hardware sells MEK Substitute. Buy 2 qts, take 1 back if you don't use it.
mooncruiser is offline
post #9080 of 13469 Old 10-02-2012, 04:29 PM
mooncruiser
Originally Posted by ospreyfe55 View Post
Ok I am getting a little nervous! I bought a 1 gal kit and some extra rollers a couple of months ago and I am planning on tackling this project this weekend on my LJ. However I am now getting stressed out and think I won't have enough to line my tub! For the guys that have done their TJ how much of the whole gallon did you used? Or is there anyone out there that has lined their LJ? Should I put this off until I can get another gallon or will it be enough?
Took 1 gal to do the interior of my CJ7, almost every bit.
post #9081 of 13469 Old 10-02-2012, 04:38 PM
mooncruiser
Thanks for the advice. I am doing a LJ tub and hope that the 1 gal kit I got will be enough. I was also wondering about the drain holes. I replaced all the factory metal plugs with the JK style rubber plugs. My worry is that the ML will be to thick for the plugs to stay in place. But it hard to tell in some of the pics from other members projects. Do you have any insight or suggestions on this as well or does anyone else have any advice on this matter? And how high do you recommend going up the side of the tub? I have seen some that go up over the lip where the soft top slides into. My kids have scratched the top of the tub up so I thought about doing the lip as well!
I pulled all my drain plugs, not sure if they are the same style on your LJ...I plugged all threaded holes with those squishable earplugs-you can buy them cheap at Wally World or a drugstore. Just coat the entire tub, 2 coats, and pull the ear plugs from the threaded holes as soon as you're done with the 2nd coat. I used 1/4", 5/16" and 3/8" taps to just chase the threads once it had cured so I didn't have any problems putting everything back together. If you don't have the taps go to your local parts store and buy a cheap set-I bought a nice set just so I don't have to worry about the cheap ones breaking off in hole I'm threading for other times, but a cheap set would fine for cleaning up these threads.
post #9082 of 13469 Old 10-02-2012, 06:59 PM
Netrix
Dude, if anyone researches hard before purchasing something, it's me. My lift sat in my living room for several months before it got installed, and I took like 4 years to pick out the parts. My job is research. So believe me, I'm on top of the research thing. Like I said, I did my research and did NOT come across the 1 year shelf life thing until long AFTER purchasing....so I'm guessing some others had the same issue I did, and they added some info to their website.
Since you purchased it in May, you better get to it. You'll be in the same boat I'm in...winter approaching and weather issues to prevent you from using the product and you'll end up with a wasted can of gum next summer when you finally get the opportunity to do something with it. btw, my box never saw temps outside 60-80°F, so you can't blame cold/heat for anything.
I ran into the same thing, good to know I wasn't the only one. Bought it when the first sale went up. Stored in my finished basement where we've stored paint for years and years. It was about 1.5-2 years after purchase before I was ready for it. It all separated and settled in the bottom of the can. Destroyed the paddle trying to mix it, since the black was hardened in the bottom. Ended up being to many chunks, stringy pieces, and hard pieces stuck to the bottom. I didn't want to try to apply it and be stuck with the results. Never seen info on shelf life until after I opened the can. Had to search pretty deep on the website to find the shelf life.
E-mailed magnetman and he recommended buying another paddle to mix it (since the one I had got destroyed), but it had already been 2 days since I put the activator in (early Saturday morning). So I opted not to even try that.
Ended up just buying another gallon to get it done. Second can I mixed without any issues. Partially my fault for not preparing before I purchased. Still should be made clear this stuff should not sit for very long.
Netrix is offline
post #9083 of 13469 Old 10-02-2012, 07:18 PM
Jevy
I placed an order over the weekend. Should I be receiving a tracking number or anything? I was hoping to get it this week?????
Jevy is offline
post #9084 of 13469 Old 10-03-2012, 11:04 AM
morr
sorry is this has been asked,but i have a 97 wrangler sport color red . what color would match that the best to do the grill and tale gate
morr is offline
post #9085 of 13469 Old 10-03-2012, 12:33 PM
Jevy
How much time should i budget to actually apply one coat for a tub interior. Also did you guys remove the roll bar or just do it all together
My '84 CJ7
Thread
My M416 with Roof Top Tent
Thread
Jevy is offline
post #9086 of 13469 Old 10-03-2012, 12:48 PM
mooncruiser
Definitely remove roll bar or anything else bolted to tub. Use ear plugs, rolled up paper/tape to plug the threaded holes to keep the ML off threads.
Figure about an hour to roll the first coat. The most time consuming part is "cutting in" all the corners, tight spots that you can't get the roller.
post #9087 of 13469 Old 10-03-2012, 01:07 PM
BAMFpullin719
i left roll bar and seam sealer in, lined everything.
"4 low, 2nd gear, skinny peddle on the right"
bought not built, broke, then rebuilt
you thought you had rust?
BAMFpullin719 is offline
post #9088 of 13469 Old 10-03-2012, 02:01 PM
mooncruiser
Only reason I removed bolted items is that you are going to have to mess up the liner if you need to remove it later- same goes for window hinges, door hinges, tailgate...you get the picture hopefully.
post #9089 of 13469 Old 10-03-2012, 02:19 PM
Netrix
I just put wide painters tape around the flat bracket where the sports bar mounts to the tub. Then traced the bracket with a razor blade to trim the tape. Bit of newspaper around the areas of the bars I didn't want to slop paint on. Wrapped tin foil around the wiring in the tub. Also used some fishing line to keep the wiring up out of the way so I could work around it. Plastic grocery bags + tape over pedals, shifter, steering wheel, and transfer case handle.
After you prep it, applying it is easy. Wish I would've got a mini roller for the hard to reach areas.
Netrix is offline
post #9090 of 13469 Old 10-03-2012, 08:36 PM
Jims-87YJ
1987 YJ Wrangler
Just an FYI after the fact I found that Big Lots (the store) sells a big box of the Foam ear plugs for only $5.00 I wish I had them when I did mine...
My build thread:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
Bigb75i
You may not post new threads
