Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 594 - JeepForum.com
 34Likes
post #8896 of 13504 Old 09-03-2012, 08:48 AM
USMCBuckWild
I'm not afraid of doing it myself, just would rather have someone who knows what they are doing to give guidance. I don't mind making mistakes, but from what I understand doing the lining is kind of a 1 shot deal.
USMCBuckWild is offline
post #8897 of 13504 Old 09-03-2012, 11:18 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Labor Day 2-for-1 CHASSIS SAVERô Sale
LABOR DAY 2 for 1 CHASSIS SAVERô Sale
3 Days Only - Monday 8/03 thru Wednesday 8/05
Available Only Online - Not Available in Stores
For anyone not familiar with this product, CHASSIS SAVERô is a direct replacement for POR-15 at up to 45% lower cost.
We have been manufacturing CHASSIS SAVERô for almost 20 years and it has been proven under the harshest conditions.
In addition to the auto restoration market, more than 500 townships, public works departments and DOT fleet maintenance
facilities use CHASSIS SAVERô for protection of snow and ice removal equipment, highway, off road and general vehicle maintenance.
Starting Now 8-03-12 thru Wednesday 8-05-12 at Midnight
all CHASSIS SAVERô Quarts and Gallons will be sold 2 for 1
Buy 1 Quart CHASSIS SAVERô Get 1 Quart FREE - Coupon Code: CSQT-B1G1F
(1 Quart price $37.50) Choose 2 of same color or 2 different colors
Buy 1 Gallon CHASSIS SAVERô Get 1 Gallon FREE - Coupon Code: CSGL-B1G1F
(1 Gallon price $104.75) Choose 2 of same color or 2 different colors
To get the free item, YOU MUST PUT 2 ITEMS IN YOUR CART BEFORE APPLYING COUPON CODE.
Standard UPS shipping rates apply - $11.00 for 2 Quarts, $17.00 for 2 Gallons
Place Orders Here @ www.shop.monstaliner.com
Colors/Finishes available are as follows:
UCP99 Gloss Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an
automotive grade synthetic, acrylic or urethane enamel.
UCP934 Silver-Aluminum - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoating is not needed unless change of color is desired.
UCP98 Floor & Machine Gray - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an automotive grade
synthetic, acrylic or urethane enamel. Makes an outstanding, chemical and abrasion resistant coating for shop and industrial floors.
UCP970 Antique-Satin Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Note: Use of gloss black is recommended if you know ahead of time you are going to topcoat.
Note: Chassis Saverô can be topcoated with itself or any other solvent base coating within 24 hours with no additional surface prep.
After 24 hours scuff sanding is required.
Please see Technical Data Bulletin link below for complete directions on surface preparation and application.
CHASSIS SAVERô Tech Bulletin
CHASSIS SAVERô Material Safety Data Sheet
Further Details:
The Coupon Codes above ARE NOT COMBINABLE
If you want to purchase more than 1 set of Quarts or Gallons you can do so by just completing
your first order and then going back to place another order. Do so as many times as you like.
This offer is a stand-alone promotion and can not be combined with any other Magnet products or MONSTALINERô purchases
Please post any questions regarding the promo to the thread so others who have similar questions can read the conversation.
PM's are OK too. I'm just trying to cut down on answering similar questions many times.
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #8898 of 13504 Old 09-03-2012, 06:55 PM
CrazyJeepMan92
Originally Posted by BAMFpullin719
here yall go. URINE TROUBLE, sprayed exterior on 2000 tj. a few issues as you might see on the doors, had to throw last half a gallon out but it was my own fault, shoulda had someone there to help me. got a solid 2 coats on everything. doors got 3 and thats when i stopped, but most of it looks great. got a couple out in the sun so you can see the color!
How many gallons did the exterior take
CK KUSTOM FABRICATION #92
NATEF/ASE Certified
US Marine MOS: Diesel Mechanic
Fabricator/Mechanic Kool Kidz ATV
CrazyJeepMan92 is offline
post #8899 of 13504 Old 09-03-2012, 08:37 PM
BAMFpullin719
well i ordered 2 gals. 1st gallon did everything with one coat. mixed up 2nd gal, sprayed 2 hoppers and right before filling the hopper the 3rd time i power mixed and dried chunks came off the sides of the mixing bowl. i sprayed the fenders, doors, and front clip with a 3rd coat and then noticed the globs and threw the other half gallon out.
so 1 1/2 gals should get you 3 coats spraying, prolly could laid a nice 4th or 5th coat with the full 2 gallons, if i didnt let it glob up, but no sweat, i think 2 will do for me for now. color looks great!
"4 low, 2nd gear, skinny peddle on the right"
bought not built, broke, then rebuilt
you thought you had rust?
BAMFpullin719 is offline
post #8900 of 13504 Old 09-04-2012, 10:44 AM
qlfarm
Ok folks; I am waiting to hear back from Eric on two PM's so I can order my exterior liner.
I have this question for those of you have have done their exteriors: Roll or Spray?
I rolled the interior and I am very happy with the job. I am not sure by myself I can keep up with the liner as far as hardening goes if I were to roll the entire exterior.
I am doing my YJ exterior and two full size pick up rockers, one set of bed rails and tail gate and rockers on my wifes SUV. Do I get the economy gun from Eric or stock up on rollers?
I just installed a new 60 gallon compressor so air isn't the issue.
Thanks,
qlfarm is offline
post #8901 of 13504 Old 09-04-2012, 11:22 AM
morr
how much of the chassis save would i need to coat the frame
morr is offline
post #8902 of 13504 Old 09-04-2012, 11:25 AM
Jims-87YJ
1987 YJ Wrangler
morr, I got two coats on mine with one qt of chassis saver, still had a little left (This was on a sandblasted frame)
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #8903 of 13504 Old 09-04-2012, 11:30 AM
morr
thanks for the help jims
morr is offline
post #8904 of 13504 Old 09-04-2012, 12:19 PM
bobthecatkiller
hey, i painted my xj with desert sand and unfortunately i have some small pin holes where i can see the primer, how should i go about patching these small holes up? i have another gallon of desert sand im going to use on the doors, i know ill have enough to patch some spots up but like i said how should i go about doing this? scuff, and spray? if so how much scuffing would be required?
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #8905 of 13504 Old 09-04-2012, 12:38 PM
morganfam00
2011 JK Wrangler
Can you quote me for UCP970-01 and 2 gallons of black roll on bedliner shipped to 09021 (it's an APO).
morganfam00 is offline
post #8906 of 13504 Old 09-04-2012, 01:31 PM
mooncruiser
Thanks,
I have done both - rolled and sprayed. I even have one that I sprayed and then went over all the exterior surfaces with a coat...rolled. Yes, glutten for punsihment.
You will be able to keep up with rolling the exterior-I did a CJ exterior complete, including both sides of the hood, inner fenders, here in AZ in 90-95 degree heat just a couple weekends ago.
I much prefer, by a large margin, the texture of the rolled surface vs the sprayed surface. Spraying is excellent for getting in all the nooks and crannies of the grill, hood, inner fenders,etc..as long as you do it the right way and dissassemble, so you can get to those hard to reach areas-plus I wanted it looking complete and not see old paint, etc. Then I rolled the outer surfaces, it turned out awesome.
Again, much smoother surface with rolling. You would think spraying would be smoother but that is not the case.
Last edited by mooncruiser; 09-04-2012 at 01:35 PM. Reason: spelling and added text
mooncruiser is offline
post #8907 of 13504 Old 09-04-2012, 02:30 PM
mooncruiser
The prep is the hardest part-putting it on is a piece of cake. You'll be surprised of how easy it is to apply.
post #8908 of 13504 Old 09-04-2012, 02:40 PM
TheRealKTrain
JK Wrangler
About how long does it take to get the paint chips one requests?
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #8909 of 13504 Old 09-04-2012, 03:12 PM
Tinga
Mine took a little more than 4 days..
Girls like STROKIN too!
http://www.jeepforum.com/forum/f153/1971-jeepster-commando-1380633/
Tinga is offline
post #8910 of 13504 Old 09-04-2012, 04:54 PM
TheRealKTrain
JK Wrangler
Shoulda ordered before the holidays. It's been 9 days for me...
Μολὼν λαβέ
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
