Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 583 - JeepForum.com
 21Likes
post #8731 of 13349 Old 08-16-2012, 12:49 PM
BLACK04WJ
So I have looked through this thread several times in the last couple days and from what I have seen I am SOLD on this product! The customer service is the best I have seen in a long time.
Although I have read most of the pages on this thread, I still have a couple questions I want to clarify while I save up the money for my purchase.
Can I apply CS over a slightly rusted fender (dodge truck) and then apply ML over it? is there anything special i need to do to keep it from rusting further other that using the CS?
Also, im planning on using ML on my entire grand cherokee for the body I need to scuff the paint and get rid of the clear coat correct? and then use white primer for the ML if I am using predator? and what about the plastic body panels and the bumpers.. how do I prep those for the best application? bumpers currently have herculiner and its ok but I really want the monsta
Thanks for the help! I hope to have my jeep covered in Monstaliner ASAP.. just have to save up cause Predator is so expensive lol
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #8732 of 13349 Old 08-16-2012, 01:55 PM
houndman72
Magnetman, do you want me to call you right now for an order I asked about earlier for the 2 jobs I have? Whom should I ask for also... thanks buddy!
mark
Rock krawler Stock Mod 2.5, Bilstein 5100 series shocks, Mamba M5 18" rims, 285/65/18 Nitto Trail Grappler tires, Body Armor Front bumper w/winch and LOTS of LED lights all over the place for blinding oncomers! LOL
houndman72 is offline
post #8733 of 13349 Old 08-16-2012, 03:07 PM
jsp_28504
1974 CJ5
jsp_28504 is offline
post #8734 of 13349 Old 08-16-2012, 03:28 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
mark
Been in the warehouse all day, going home
PM me your phone
or call my cell after 6 EST
516-313-7865
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #8735 of 13349 Old 08-16-2012, 04:12 PM
alh2411
Hey magnetman, I do not have a jeep, however, I am looking to monstaline the entire floor in my 1976 ford econoline. I actually live in this vehicle, and travel around the country rock climbing out of it, so the carpet had to go due to the constant dirt/mud that is tracked in and out of my van. Do you think that your liner is abraisive enough to cut skin? Say I walk around barefoot, would it make the skin raw after a period of time? If so, could it be put on with another applicator to have a smooth finish, which may be easier to clean, as well as easier on my hippy feet? Does the smell of liner fade relatively quickly? Thanks so much for your time, I really appreciate the expertise!
alh2411 is offline
post #8736 of 13349 Old 08-16-2012, 05:05 PM
mooncruiser
Originally Posted by jsp_28504 View Post
Looks Good
mooncruiser is offline
post #8737 of 13349 Old 08-16-2012, 05:52 PM
houndman72
Order placed online just a few minutes ago for the 1st 2 jobs. Will make another order on Monday for the 3rd job. Thanks much!
post #8738 of 13349 Old 08-16-2012, 06:11 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Thanks for the order!
You only ordered the 1 gal kit with ODG
This was not what we discussed. Just checking if that was a mistake?
Connect with us on:
post #8739 of 13349 Old 08-16-2012, 06:16 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Hi, Monstaliner will never be rough and it is always easy to clean.
This was a van interior sprayed
Look at the surface closely, this was jeep tub rolled. There are no nooks or cranies to hold dirt. No rough particles
Connect with us on:
post #8740 of 13349 Old 08-16-2012, 06:27 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
OK, mask question out of the way now
2 gals in a 4 door JK will give you easily 3 coats with some leftovers
You can pre-add the color to ML tintable and not add catalyst but the color must be mixed in thoroughly and the can sealed tight. If you just dump in the color it will settle to the bottom and make a sea monster (don't ask )
It's fine when thoroughly mixed/uncatalyzed but not indefinitely. I would recommend using it all within 3 days to avoid any problems
What color do you have?
Originally Posted by RUDY850 View Post
Couple questions
I will be doing it in a garage that has a 8x16 garage door and i do have a big fan.
If i don't spray it and roll it on. can the color be added to the gallon and mixed. then add the hardener later on to make smaller amounts as needed.
I would like to use all of the 2 gal that i got for my 4 door jk. about how many coats will that give me spraying or rolling.I only got a total of 4 of the big rollers and 4 of the smaller rollers. would i need more if i roll it all on.
THANKS.
Connect with us on:
post #8741 of 13349 Old 08-16-2012, 06:28 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by jmccallie View Post
Eric, sent you a PM please get back to me ASAP. Thanks
mccallie I just left you a voice mail
Connect with us on:
post #8742 of 13349 Old 08-16-2012, 07:41 PM
PirateQM
1982 CJ7
I am so happy with this color combination... Turquila and Pyroclastic!
Still need to knock out the full doors, the windshield frame, hood hinges and fix any light spots I missed tonight.
~Semper Paratus~
'97 TJ (Polaris) Long gone, but not forgotten.
'85 CJ7 (LiL Dragon) Hauled away to be scrapped.
'82 CJ7 (Echo)
PirateQM is offline
post #8743 of 13349 Old 08-16-2012, 08:26 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Woooho that is awesome!
Connect with us on:
post #8744 of 13349 Old 08-16-2012, 08:46 PM
Jims-87YJ
1987 YJ Wrangler
Eric, I will be doing my interior in about 2 weeks, it will be all epoxy primered but outside of the re-coat window. How much of a scuff will I have to give it? and will I still need to do the MEK wipe down?
PS will be ordering another gallon as soon as I see how the exterior looks after its painted. Will the Quarts of tintable be ready soon, as I will most likely need one or two of them also.
Thanks again
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #8745 of 13349 Old 08-16-2012, 09:01 PM
alicethecat
I have been wanting to see what Turq would look like on an exterior. It looks AWESOME! Great job with the interior as well. I bet this post will convince a few others to use this color.
99 White Sahara
alicethecat is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
