Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 581 - JeepForum.com
 36Likes
post #8701 of 13514 Old 08-14-2012, 12:47 PM
SideshowBob024
I was gonna say, it's glass except the outside rim on the iphone 4
Curious to see how that turns out, I'd do it esp since I have an outstanding phone credit with AT&T
SideshowBob024 is offline
post #8702 of 13514 Old 08-14-2012, 12:48 PM
XabuJr
XabuJr's Avatar
1992 XJ Cherokee
Originally Posted by craniumboy View Post
Aluminum... As in an original iPhone?!
I guess it looks to be glass on the back.. it's a 4. So aluminum on the side and glass on the back.. I'm tired of a case, so monsta-lining to match the Jeep is the route I'm going to go..
XabuJr is offline
post #8703 of 13514 Old 08-14-2012, 01:39 PM
craniumboy
Definitely interested to see if this stuff sticks to glass!
Keep on Jeepin' on!
craniumboy is offline
post #8704 of 13514 Old 08-14-2012, 02:05 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by XabuJr View Post
Aluminum..
If it's bare aluminum you going to need to prime it
Annodized alum I'm not sure if ML will stick directly
Glass..............................thinking....... ....
If it could be scuffed without f'ing up the phone you may be able to scratch the surface enough to get adhesion or prime it to be certain
This is nuts do we need to make a 2 ounce epoxy primer kit
The Monstaline Your iPhone Kit
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #8705 of 13514 Old 08-14-2012, 03:15 PM
Neudiin
Didn't Sarah do this already? I know she did a case not the bare phone but still lol
Neudiin is offline
post #8706 of 13514 Old 08-14-2012, 03:43 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I don't know what that case is made from
Here's The_Blacksmith's phone in MQG
Connect with us on:
post #8707 of 13514 Old 08-14-2012, 05:06 PM
XabuJr
XabuJr's Avatar
1992 XJ Cherokee
hahaha Well, since I'm cleaning up my wife's monsta work, I figure I'll have some left over of the quart. Going to put it to good use. I'll just scuff the glass and give it a shot. If it doesn't work, so be it, I'll find a case that covers it.
XabuJr is offline
post #8708 of 13514 Old 08-14-2012, 05:56 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by BAMFpullin719 View Post
you should draw up a version of him with his one arm up in the air holding a roller, and his other arm (draw it smaller) down holding a paint bucket. DIY roll on bedliner
I like this idea alot. Gonna do something like this after the new main image is complete
These were other versions submitted by same artist.
Connect with us on:
post #8709 of 13514 Old 08-14-2012, 06:30 PM
SarahRose
Hahaha I still have that case around here somewhere!! it was just plastic. I didn't prime it or anything, just roughed it up and wiped it down and slapped some monsta on it.
The way I see it, a Jeep is like sex-when it's good it's terrific, and when it's bad it's still pretty good!
SarahRose is offline
post #8710 of 13514 Old 08-14-2012, 07:49 PM
Copperhead89
I'm getting ready to place an order for Monsta. I have one question. Without going through all 580+ pages, what is the general consensus regarding the quantity needed to spray two coats to the bottom of a Jeep Wrangler (YJ) tub, not including the firewall? Will one gallon be enough? I'd hate like hell to run a little short in the middle of the job! Thanks!
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline
post #8711 of 13514 Old 08-14-2012, 07:57 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You will definitely do it with 1 gallon
Spraying will waste less than rolling because you don't lose what gets soaked up by the rollers and what is left in a roller pan
Also the small amt of reducer added gets you a little more coverage
Connect with us on:
post #8712 of 13514 Old 08-15-2012, 07:13 AM
Jims-87YJ
1987 YJ Wrangler
I just completed the bottom of my tub and the firewall (with the tintable Monsta) and 2 coats , I did spray with the economy gun and had about 1" left in the bottom of the gallon can. I would say plan on covering something else so as to not waste the product.
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #8713 of 13514 Old 08-15-2012, 07:17 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Round up your phones!
Connect with us on:
post #8714 of 13514 Old 08-15-2012, 04:08 PM
houndman72
will be looking to buy,
1 gallon of light quartz grey liner
1 gallon of O.D. Green liner
2 gallons of chassis saver gloss black
will need the roller and prep kits too for them. Can you help me with this? Thanks a bunch!
Rock krawler Stock Mod 2.5, Bilstein 5100 series shocks, Mamba M5 18" rims, 285/65/18 Nitto Trail Grappler tires, Body Armor Front bumper w/winch and LOTS of LED lights all over the place for blinding oncomers! LOL
houndman72 is offline
post #8715 of 13514 Old 08-15-2012, 04:12 PM
houndman72
2nd post, also magnetman, I have a customer that is wanting to paint/liner his hardtop on the inside with your white. Is this recommended by you to do? He is wanting to kill some of the noise and help on the air/heat issues. Please give me your thoughts.
And finally, I have 4 customers wanting to roll/line their JK's wheel flares. They are all painted to factory color. Thoughts or tips on doing that? WIll all be the black in color of course.thanks again!
Mark
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
