Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 580 - JeepForum.com
 25Likes
post #8686 of 13379 Old 08-13-2012, 02:46 PM
ariff
1987 YJ Wrangler
So I just finished up my Mostaliner application this weekend. I have to say this stuff is great. Anyone thinking about doing this should. Takes a lot of prep work ( I spent about 6hrs sanding) but it is totally worth it. I can't believe it is finally finished, and I am very happy with Monstaliner. A few tips I might give others thinking about doing this.. Get their small roller and sponge kit for your Jeep. Ireally used this a lot for the tight spaces. Dabbing with the sponge really works well in the creases and what not. Be sure to stir after every pour.. I did not and got a few chunks here and there, not bad though. Take off your tape after your second coat. I have no problems with the tape getting stuck to the ML doing it right after the second coat. Eric you have an awesome product and thanks for all your help.. I am thinking about putting ML on my wheel wells. How much would you suggest I get to do two coats in the wells? Thanks!
Ready
First coat
Second coat
Second coat driver
Mist
ariff is offline
post #8687 of 13379 Old 08-13-2012, 03:45 PM
JeepJunkie98
Originally Posted by mike_breaker_5 View Post
i am going to be monsta-ing an old t6 alumuminum bicycle frame after i sandblast the old paint off. what is your suggestion for best results with monsta? i still have both magnapoxy primer and some cs, i was going to magnapoxy then monsta ofer the bare aluminum. just checking for an affirmation that this is the best course of action.
From what I have read on bare aluminum to use an epoxy primer or an etching primer. CS would be for rusted steel.
Hope this helps and hopefully someone will confirm.
Here is a link to pictures of my build http://outdoors.webshots.com/album/582256652CqwLSD?vhost=outdoors
A link to my build on a local forum http://forums.exploringnh.com/showthread.php?t=19636
JeepJunkie98 is offline
post #8688 of 13379 Old 08-13-2012, 04:34 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Epoxy primer only. I've seen too many failures with self etch and no longer recommend it for anything
Are you planning to take pics of this project?
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #8689 of 13379 Old 08-13-2012, 06:36 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Very nice job!
Can you give an estimate of how many sq ft in 1 wheel well?
Ready
First coat
Second coat
Second coat driver
Mist
Connect with us on:
post #8690 of 13379 Old 08-13-2012, 09:38 PM
mooncruiser
Originally Posted by XabuJr View Post
And you only have to pay to attach photos that way. Using something like image shack or photobucket you can post pictures all day long without upgrading.
Thx Xabu, I already went ahead and renewed, it's for a good cause!
mooncruiser is offline
post #8691 of 13379 Old 08-13-2012, 09:41 PM
ariff
1987 YJ Wrangler
Looks like about 2.25 sq feet for the rear wells.. Fronts would be a little smaller.
ariff is offline
post #8692 of 13379 Old 08-13-2012, 10:49 PM
XabuJr
XabuJr's Avatar
1992 XJ Cherokee
I can't argue with that one!
XabuJr is offline
post #8693 of 13379 Old 08-13-2012, 11:23 PM
mike_breaker_5
i can definitely take some pics. i have hit some of the roughest parts of oxidation already. the frame i am blasting will be an old f900 cannondale frame from the late 90's. when the bike was new, and with the options i had on it, it was worth about $2k. i'm old and fat now, so i'm replacing alot of the old parts with some run of the mill accessories just so i can get some exercise. i will be building an old volvo team edition f900 for Mrs_breaker_5 to ride.
i used to be one of the top 10 riders in my area on a mtn bike back in the day (10 years ago). now i just need exercise. i came home from iraq at 202lbs, at 240lbs now i need to start cutting the fat. i'm 6'5" so before anyone calls me fat, do the bmi for 202lbs and 77" tall. 210 is my goal. i was at 220 before i broke my foot over the winter. it's easier to gain weight sitting on the couch playing gra ntourismo 5 than it is to lose it after convalescing.
p.s.
if this sounds like rambling, i'm into the bottle of rum again, so deal with it. eric has had about 3 years now of random drunken posts from me in this thread. i do not intend on stopping anytime soon.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #8694 of 13379 Old 08-14-2012, 06:31 AM
JeepJunkie98
ramble on and for your service to our country.
Good luck on the bike, I hear ya on getting back down to weight
post #8695 of 13379 Old 08-14-2012, 06:54 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Thanks
I have only one thing to add
p.s.
Connect with us on:
post #8696 of 13379 Old 08-14-2012, 07:08 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Well, 1 quart does 15 sq ft so x 4 and a quart should do it
Connect with us on:
post #8697 of 13379 Old 08-14-2012, 11:09 AM
XabuJr
XabuJr's Avatar
1992 XJ Cherokee
Any special prep to line an iPhone? Just scuff it good?
XabuJr is offline
post #8698 of 13379 Old 08-14-2012, 11:47 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Is the surface hard plastic?
NOT like fender flare plastic
Connect with us on:
post #8699 of 13379 Old 08-14-2012, 12:29 PM
XabuJr
XabuJr's Avatar
1992 XJ Cherokee
Aluminum..
XabuJr is offline
post #8700 of 13379 Old 08-14-2012, 12:32 PM
craniumboy
Aluminum..
Aluminum... As in an original iPhone?!
Keep on Jeepin' on!
craniumboy is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
