Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 58 - JeepForum.com
 18Likes
post #856 of 13305 Old 03-31-2010, 04:35 PM
Joepa
I have a textured undercoating sprayed in my jeep now. Could I go over top of it with Monsta?
Joepa is offline
post #857 of 13305 Old 03-31-2010, 05:08 PM
Viencent
1982 CJ7
be very very cairfull if you try this, just went tried this and had to remove every thing the solvent in the Monsta turned my old liner to a gooy mush and didnt stick. I would get some MEK and see if it removes your old liner easy, if so remove it first
Viencent is offline
post #858 of 13305 Old 03-31-2010, 05:22 PM
Ironworker709
Ironworker709's Avatar
still have the finger ready to pull the trigger when you get the spice color ready
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #859 of 13305 Old 03-31-2010, 06:14 PM
Rynoman27
UPS man dropped off my kit today, everything was there. Cant wait till next weekend gonna start to take it apart. Any fellow jeepers in the monroe, MI area are welcome to come over and shoot the ****, there will be beer.
Rynoman27 is offline
post #860 of 13305 Old 03-31-2010, 11:12 PM
ValleyJeeper
I ordered the Promo deal tonight.
I know I have rust under the carpet.
Now I'll wait until June, take the hard top off, and get to some messy work.
Will this increase the value of my Jeep?
I think so. Less rust, no carpet, hardcore floor.
ValleyJeeper is offline
post #861 of 13305 Old 03-31-2010, 11:17 PM
LuckRider
LuckRider's Avatar
Ins. Company gave me $800 for it when they totaled it ... I guess you can say it does.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #862 of 13305 Old 04-01-2010, 01:15 AM
tangotag
Magnetman can you recommend a specific self-etching epoxy primer for use in prep of bare metal?
I have one of the Chassis Saver distributors a couple miles away so I should be able pick up the primer locally.
Another thing I had been thinking about. If I wipe the interior with MEK then mask off everything and spray the interior with the self-etching epoxy primer would I be able to bypass the scuff up the paint surface step and still have a solid prep for Monstaliner? I can see it taking me a long time preping the surface by hand, hoping to find some time saving ideas in this area.
My kit should arrive within 24 hours, the Chassis Saver (Jet Black Gloss) ordered was planned to be used on the frame and underneath body work.
Everything I do will be photographed throughout the process.
I too am interested in the "OD Green" color Monstaliner for a currently sidelined project, maybe a year out for my needs still.
http://i228.photobucket.com/albums/e...207071948a.jpg
tangotag is offline
post #863 of 13305 Old 04-01-2010, 06:16 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Another thing I had been thinking about. If I wipe the interior with MEK then mask off everything and spray the interior with the self-etching epoxy primer would I be able to bypass the skuff up the paint surface step and still have a solid prep for Monstaliner? I can see it taking me a long time preping the surface by hand, hoping to find some time saving ideas in this area.
Self etch and epoxy primer are 2 different things. You only use self etch on bare metal (not over previous paint)
You can not avoid scuff sanding painted surfaces without risk of adhesion problems.
Is the majority of area you will be coating with Monstaliner bare metal or painted surface?
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #864 of 13305 Old 04-01-2010, 08:02 AM
erickpl
erickpl's Avatar
To use the chasis saver on my tub (some minor surface rust in the passenger area floorboard), how much scuffing do I need to do?
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #865 of 13305 Old 04-01-2010, 08:49 AM
tangotag
Looks like there is no shortcut for proper preparation. Other than using the scuff pads under a DA sander and light sanding keeping the paint intact.
The majority of the area that I will be applying this time will be the prepainted Jeep interior.
I have a few areas of spotting rust which I will MEK then rough up and apply 2 coats Chassis Saver (Gloss Black), what I have on hand, and wait 24 hrs then scuff that surface. Would this work?
When it comes time for my other project, that will be an application going on bare metal. Should I use a self-etch in that case?
tangotag is offline
post #866 of 13305 Old 04-01-2010, 08:55 AM
LuckRider
LuckRider's Avatar
Really the prep work is the most important part, and you want to do that right. Unless you have a strict deadline, there is no rush when you are doing that. The actual application of the liner is very easy, and there is no way to go wrong except for maybe brushing some spots and not going back over with the roller for texture.
Support Our Troops!
JFI Member #7:
post #867 of 13305 Old 04-01-2010, 11:19 AM
Goobersbro
if you apply the liner within 24 hours no scuffing is needed. Anything over that you need to hit it with 120 grit.... I believe
My marshmallow build
Goobersbro is offline
post #868 of 13305 Old 04-01-2010, 01:49 PM
Deacon
Deacon's Avatar
English, please.
Deacon is online now
post #869 of 13305 Old 04-01-2010, 01:50 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Chassis Saver over Rusted Areas
To apply Chassis Saver over rust, wire brush the rust to remove any loose, powering or crusty material. You can also sand the rusted areas with 60 grit paper. Blow down or vacuum to remove all debris and wipe with MEK. Apply Chassis Saver in 2 thin coats (no puddling or extra heavy brush coats). Allow 3 to 4 hours between coats. 1 coat only is sufficient if you are applying Monstaliner within 24 hrs. If you plan to leave it longer before installing Monstaliner, do 2 coats of Chassis Saver.
Chassis Saver over Previous Paint
On previously painted areas, scuff to remove gloss and generate a light dust with scuff pads or 60 grit sandpaper. Clean surface as above and apply only 1 coat of Chassis Saver.
Topcoating Chassis Saver with Monstaliner
Chassis Saver can be topcoated in as little as 6 hours with Monstaliner. If Chassis Saver is allowed to cure more than 24 hours, surfaces should be scuff sanded with 120 to 180 grit sandpaper. (This applies to recoating with itself or any other coating)
Let me know if I left anything out here
MagnetMan
Connect with us on:
post #870 of 13305 Old 04-01-2010, 01:59 PM
aerojeeptj
lol I sanded with 120 grit instead of 60, still seemed to go on and dry fine though
aerojeeptj is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
