Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 566 - JeepForum.com
 28Likes
post #8476 of 13416 Old 07-24-2012, 02:31 PM
clintlight27
For those of you who have done your exterior, how well does monstaliner hold up to a powerwasher? Does it peel or flake when powerwashed?
clintlight27 is offline
post #8477 of 13416 Old 07-24-2012, 03:00 PM
BAMFpullin719
if you prep the metal correctly theres no reason for it to peel. if it did, i'm sure we wouldnt be reading through 566 pages of positive reviews
"4 low, 2nd gear, skinny peddle on the right"
bought not built, broke, then rebuilt
you thought you had rust?
BAMFpullin719 is offline
post #8478 of 13416 Old 07-24-2012, 03:46 PM
Viencent
1982 CJ7
its been a year for me, just got a power washer 2 months ago and its holding up great, no peel or flaking anywhere I've seen yet. first time i used it was surprised it looks as good as the day i put it on
Viencent is offline
post #8479 of 13416 Old 07-24-2012, 07:10 PM
clintlight27
Excellent, I am deployed right now but this will be the first thing I do to my YJ when I get home. I figured it would be durable, and its good to see positive feedback. From what I gather proper prepwork makes all the difference, as with any paint job.
post #8480 of 13416 Old 07-24-2012, 07:25 PM
Viencent
1982 CJ7
Ya, the prep took 3 times as long as the install did, getting ready to redo mine, not that anything is wrong with it, just that the all black is too hot for here in Texas, going to put one of the yellows(atm Don't yell at me ) on the inside and see how that does, then I may redo the outside in "Outbreak".
Viencent is offline
post #8481 of 13416 Old 07-25-2012, 01:45 PM
Rittsy
should the actual windshield be taken out if you are going to do the entire exterior and interior of the windshield frame?
Rittsy
2000 Jeep TJ Stock. except for the CB radio :)
Rittsy is offline
post #8482 of 13416 Old 07-25-2012, 01:54 PM
Tikijeep
I've also been wondering if windshield out is best....?
Utah JeepCrew member # 131
Tikijeep is offline
post #8483 of 13416 Old 07-25-2012, 06:20 PM
Viencent
1982 CJ7
I didnt take mine out and its been great sofar, but if you know how I think it would be better if you remove it and reinstall it after
Viencent is offline
post #8484 of 13416 Old 07-25-2012, 09:33 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I got a question, How is the windshield installed in the frame? Is there a gasket that can be reused to reinstall or is it trashed once you dig it out?
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #8485 of 13416 Old 07-25-2012, 09:38 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by RedlegWJ View Post
Magnetman,
Any progress on your no-slip marine application? Just bought an old Starcraft project boat.
We have the material to do this. It needs to be broadcast into the first wet coat and then rolled over to encapsulate the particles under the 2nd coat.
The grit is actually clear so when used with a light color Monstaliner and the tops of the particles get worn it won't look like dark specks all over
We don't list it yet for sale. If you want it for a project I'll give it to you no charge with kit purchase
15 posts to 8500
Connect with us on:
post #8486 of 13416 Old 07-25-2012, 10:03 PM
mike_breaker_5
i left mine in.
i taped half on the gasket and half left to be linered.
the liner has been holding up great. i have pressure washed, been in copious mud, pressure washed more, been in harsh direct sunlight among other elements, and it has held up great for the last 2 years.
the liner has not separated or cracked at the seam of the windshield frame meets the windshield gasket.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #8487 of 13416 Old 07-25-2012, 10:44 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by a_l_i_C_i_a View Post
it took me about 1 1/2 gallons to spray the exterior but i bought 2 gallons to make sure i had enough.
a_l_i_C_i_a did your order another gallon of Barbaric to do exterior highlights?
Connect with us on:
post #8488 of 13416 Old 07-25-2012, 10:50 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
If anyone is doing a regular paint job on an exterior we could tint single stage acrylic enamel or urethane to match any of the Monstashades colors
Connect with us on:
post #8489 of 13416 Old 07-26-2012, 12:26 AM
a_l_i_C_i_a
Yeah, its still sitting in the garage tho...havent had time to do it yet. How well do u think the pink will go over the black? I sprayed the whole hood with the black but i want to go over it with pink.
a_l_i_C_i_a is offline
post #8490 of 13416 Old 07-26-2012, 08:33 AM
JeepJunkie98
For a Jeep the windshield has a rubber grommet around the windshield but is held in with a silicon type sealant dispensed out of a calking gun.
Going to paint the surface for the windshield, tape it off and monstaline the frame then remove the tape and install the windshield.
JeepJunkie98 is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
