Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 53 - JeepForum.com
 44Likes
post #781 of 13549 Old 03-27-2010, 10:27 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by renegade91 View Post
i know the subject of putting the liner over spray paint was brought up earlier in this thread but i don't remember seeing an answer. i tried rubbing some parts of my tub that had spray paint on them with some m.e.k. and it started taking the spray paint right off and now i'm wondering what i should do. thanks for any info.
I would remove the spray paint first and then scuff sand the surfaces.
Are surfaces under the spray paint bare metal or do they have original paint?
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #782 of 13549 Old 03-27-2010, 10:33 PM
renegade91
the spray paint is over bare metal.
renegade91 is offline
post #783 of 13549 Old 03-27-2010, 10:52 PM
LuckRider
LuckRider's Avatar
You should have used a self etching primer. I used a self etching primer on my bumper, and then coated it with Rustoleum hammered. At the last minute, we scratched it a little, wiped it with some M.E.K, and then threw 2 coats on. It stuck perfectly till the day the ins. company took it (which means almost 6 months).
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #784 of 13549 Old 03-27-2010, 10:53 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Scuff the metal really coarse, 50 or 60 grit sandpaper and apply Chassis Saver.
Note to all: MEK is a very strong solvent. It's the standard solvent used in lab tests to check solvent resistance of other coatings.
Monstaliner and Chassis Saver contain the same solvent. It's not MEK but a very strong, slow evaporating Naptha type solvent and also has the potential to dissolve spray paint. The reason we use MEK to test solvent resistance is because it shows results fast. When you put Chassis Saver or Monstaliner over spray paint it may take a while for a problem to show up so we don't take a chance before testing with MEK.
Connect with us on:
post #785 of 13549 Old 03-27-2010, 11:04 PM
Ironworker709
Ironworker709's Avatar
So how long until the Spice color is ready magnetman??
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #786 of 13549 Old 03-27-2010, 11:12 PM
renegade91
alright, cool. thanks for the info. looks like i have some more work ahead of me before i can get this stuff in.
post #787 of 13549 Old 03-28-2010, 05:27 PM
gdp057
Just placed my order! Really excited about getting this stuff in.
Magnetman, question: I have been slowly going about the process of getting my tub prepped. In sanding down some of the surfaces I have definitely taken the paint down to bare metal. Can I just spot prime these areas with the chassis saver before rolling on? Is there something else I should do to promote adhesion in those areas?
gdp057 is offline
post #788 of 13549 Old 03-28-2010, 05:46 PM
erickpl
erickpl's Avatar
If I place an order for a 1 gallon kit with the discounts offered, when would it ship?
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #789 of 13549 Old 03-28-2010, 06:16 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Got it. Thanks for your order Boston!
Just coarse up the bare areas with 50 or 60 grit and spot prime with Chassis Saver. Save the rest for something else. As long as you've scuffed and deglossed the existing paint in the tub you are good to apply Monstaliner direct to old paint.
New photo set online (click link)
Monstaliner Installation in 1989 Chevy S10 EV Electric Pickup Truck Bed
We did this bed Friday and Yesterday in our warehouse. Will take final pics tomorrow after reinstall of tailgate.
It drives like an electric forklift. Only 40 miles before you need to recharge the batteries. Kind of scary on the road with absolutely no engine noise.
Connect with us on:
post #790 of 13549 Old 03-28-2010, 06:18 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
We are pretty much caught up on orders. New orders will ship by Tuesday.
Connect with us on:
post #791 of 13549 Old 03-28-2010, 06:37 PM
84MSRB
Wow- spice Monstaliner would be kickass to re-do my dash pad.......
1984 CJ7 Mud Slingin Rust Bucket
90 YJ tub
Ford Mutt 5.0( 69 block, 89 EFI)
84MSRB is offline
post #792 of 13549 Old 03-28-2010, 06:43 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
What is the dash pad made from?
Connect with us on:
post #793 of 13549 Old 03-28-2010, 06:45 PM
LuckRider
LuckRider's Avatar
If he is talking of the dash liner, it is made of rubber. It is pretty flexible, but not porous.
Support Our Troops!
JFI Member #7:
post #794 of 13549 Old 03-28-2010, 06:59 PM
84MSRB
Old CJ dash pad- dense foam, pretty heavy duty vinyl cover.
90 YJ tub
84MSRB is offline
post #795 of 13549 Old 03-28-2010, 07:18 PM
Goobersbro
here is a question can you bedliner over the chasis saver??? I need to apply chasis saver or por-15 to the edges of the jeep around the whole tub..... and all the seem lines where the panels have been welded. I have ground and got as much rust out and done everything possible so now I want to put some chasis saver or Por in there.....but I also want to bed line it so can I bedline over the chasis saver or Por????
My marshmallow build
Goobersbro is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
johnwesley
You may not post new threads
