Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 513 - JeepForum.com
 19Likes
post #7681 of 13308 Old 04-27-2012, 09:13 AM
jrp78
I ordered a kit a few days ago to do my RTV. I'm going to hold off on the trailer for now. I've found several comments about different sandpaper grit to use, etc but magnetman, can you tell me what I can get to put on my 18V drill? Is there a specific wire cup brush I can use for the hard to reach areas? And also what grit to get for sanding blocks.
jrp78 is offline
post #7682 of 13308 Old 04-27-2012, 10:15 AM
LuckRider
LuckRider's Avatar
Magnet, that is diesel mileage. And... sitting like that, maybe 11mpg. Slightly better than the 9mpg of the H2.
I have seen the lower forty and know it is the stock suspension. They did a lot of body work that isn't immediately noticeable to make everything fit and travel right. My understanding is that the suspension still has the same amount of travel it had from the factory (a little more down with the bigger shocks actually).
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #7683 of 13308 Old 04-27-2012, 04:16 PM
alicethecat
Originally Posted by magnetman View Post
That's a monster. gas mileage?
My 2 door gets 14 on the highway as long as I keep it under 65mph. At 80 it gets 9mpg. I run B5 bio in it but only drive it 2k miles a year so the $150 fill ups don't hurt too much. Some day this one will get a 6bt cummins and a transfercase and will get 18mpg, just waiting for the 6.5 to blow up.
alicethecat is offline
post #7684 of 13308 Old 04-27-2012, 05:42 PM
dongalonga
As promised:
Attachments are roughly 12mm,13mm, and 16mm respectively.
dongalonga is offline
post #7685 of 13308 Old 04-27-2012, 08:33 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Thanks for the photos
Tip opening may be too large
This unit has an open turbine motor and the manual states it should not be used with oil base or flammable products.
I would test it myself because I love fire but i don't advise you getting involved right now. ML needs to be thinned slightly for spray but we would need to ID an alternate solvent to MEK for reducing and spray with electric. But, still we can't predict any results unless tested safely.
I still need to know if it would work and I am looking at a used one now on ebay to purchase and test. Anything is possible for the future. Replacing motor w/explosion proof, tip modification, etc.
If I get this used gun I will let you know and you should watch the news for a fireball in Amityville
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #7686 of 13308 Old 04-27-2012, 10:20 PM
dongalonga
Hahaha excellent. Now that's customer service. Willing to burn down your entire town just to test a product!
post #7687 of 13308 Old 04-28-2012, 09:36 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
1 day left
$16.50
Edit: I may change my mind. Specs say Maximum pressure of 2 PSI
Have you sprayed this unit with popcorn material?
Connect with us on:
post #7688 of 13308 Old 04-28-2012, 01:28 PM
BigDogTJ
Just ordered the tintable liner from you. I think I can still salvage the plain black and use it for something else. Thanks for the high quality product!
"The only thing necessary for evil to triumph is for good men to do nothing." ~Edmund Burke~
BigDogTJ is offline
post #7689 of 13308 Old 04-28-2012, 04:42 PM
dongalonga
I have never sprayed it. I bought it awhile ago because I got a good deal on it. I was planning to use herculiner back then though. Oh how far I have come
post #7690 of 13308 Old 04-28-2012, 06:59 PM
Bot
Will this adhere to body putty like bondo? I had a few small dents along the rail I bondoed. I will prime over it before applying.
2016 Rubicon Hard Rock JKU - ready for the mods
98 Sahara
2005 Rubicon
Bot is offline
post #7691 of 13308 Old 04-28-2012, 07:27 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Trust me, scuffing with a drill is more of a hassle than doing it by hand and wire wheeling really does not make the kind of powder off the surface like abrasive pads or sandpaper. Use 120 grit. You can go coarser down as low as 80 grit for faster scuffing but risk cutting through to metal much easier. It's all a matter of what you are comfortable with and how much you can control it without over sanding
Connect with us on:
post #7692 of 13308 Old 04-28-2012, 07:28 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Thanks for the order
PM me a week or 2 before you plan to use the black
Connect with us on:
post #7693 of 13308 Old 04-28-2012, 07:29 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Prime the bondo before putting ML over it
Connect with us on:
post #7694 of 13308 Old 04-28-2012, 09:20 PM
TJ_Tim
Interwebz Specialists
TJ_Tim's Avatar
Just ordered a kit this evening along with some extra rollers and my free chassis saver
Now for some promising weather.
1969 Mercury Cougar 351w
1998 Jeep Wrangler Sport 4.0
2009 Yamaha V Star 950
2006 Jeep Commander 4.7 Base
TJ_Tim is offline
post #7695 of 13308 Old 04-29-2012, 01:13 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Got it, thanks for the order!
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
