Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 510 - JeepForum.com
 36Likes
post #7636 of 13509 Old 04-25-2012, 02:11 PM
Neudiin
Yours look so much better than mine...still messing with the texture plug in. But there ya go....
Neudiin is offline
post #7637 of 13509 Old 04-25-2012, 02:57 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You got the texture going on nice in the white one
a_l_i_C_i_a
Are you planning to disassemble some of this jeep to do the exterior?
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #7638 of 13509 Old 04-25-2012, 05:46 PM
a_l_i_C_i_a
Originally Posted by magnetman View Post
a_l_i_C_i_a
All Barbaric or Charcoal Gray
wow thanks for taking the time to do that for me! I have to say im loving the barbaric. It just might be the winner.
a_l_i_C_i_a is offline
post #7639 of 13509 Old 04-25-2012, 05:52 PM
a_l_i_C_i_a
Thanks Neudiin for you help too! I like the black with the pink top. Never really considered doing the top anything but black but i like it in the pink. So im now debating between magnetman's all barbaric or neudiin's black with pink top.
post #7640 of 13509 Old 04-25-2012, 05:57 PM
a_l_i_C_i_a
a_l_i_C_i_a
I havent put much thought into that yet. I know i'll be taking off the flares thats about as far ahead as i've thought about it. suggestions?
post #7641 of 13509 Old 04-25-2012, 07:11 PM
mike_breaker_5
troublemaker
sad part is i think you are the only one that saw what i did there. lol
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #7642 of 13509 Old 04-25-2012, 07:46 PM
Bot
Thinking about painting a truck with this stuff but don't want the rough surface. Could I use those little foam rollers to make it smooth? Any options for a smooth glossy finish ? Also will the black stay glossy when exposed to sun? At minimum I'm going to use it on the bottom for a 6" chip guard
2016 Rubicon Hard Rock JKU - ready for the mods
98 Sahara
2005 Rubicon
Bot is offline
post #7643 of 13509 Old 04-25-2012, 08:22 PM
timatoe
timatoe's Avatar
Nope, I caught it but didn't have the heart to point it out to the next guy that was trying to answer you.
timatoe is online now
post #7644 of 13509 Old 04-25-2012, 09:41 PM
hawgfan0705
can I please get the latest spray instructions, Thanks
hawgfan0705 is offline
post #7645 of 13509 Old 04-25-2012, 11:08 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Here you go. Let me know if you have any questions
Spraying Tintable Monstaliner + Monstashades with the Walcom Shutz Gun
IMPORTANT
1) Before you start: You must have a new or clean 2 gallon plastic bucket. Monstashades color and the catalyst will not all fit into the tintable gallon can.
2) The siphon tube supplied with the Walcom gun is a bit too long when the quart can is screwed up under the gun. Carefully cut a small piece off the end
of the tube at a 45 degree angle. Test fit the tube before cutting to make sure you do not cut it too short. 3/8 to 1/2" should be enough to remove.
The angled cut end goes towards the bottom of the can.
3) The Walcom gun has a nice tip adustment. Start spraying with the tip screwed all the way in and back it out no more than 1/2 way.
Hand shake gallon of tintable for 30 seconds. Hand shake can of Monstashades color concentrate for 5 seconds. Open both cans and dump entire contents
of color concentrate into gallon. Add 2 tablespoons of MEK or Acetone TO THE EMPTY COLOR CONCENTRATE CAN and reseal the can. Shake vigorously for 5 seconds
and dump wash solvent into tintable gallon.
Power mix tintable gallon with color at medium speed for 2 minutes. Dump entire contents of color mixture into your 2 gallon bucket. Scrape sides and bottom
of can with paint paddle to get as much out as possible. Shake Monstaliner Catalyst for 10 seconds and pour entire contents into bucket with tinted mixture.
Power mix bucket at medium speed for 1 minute and stop. Scrape out remaining catalyst into bucket and continue power mixing for an additional 3 - 4 minutes.
Note: While mixing, stop periodically to scrape sides and bottom of bucket with paint mixing stick.
Add 4 ounces of MEK or Acetone to the bucket and power mix for 1 additional minute.
Fill your quart Shutz can with the mixture and put the cap on the can. Pour the remaining tinted/catalyzed mixture back into the original gallon paint can and sit the lid on it.
DO NOT under any circumstances leave the mixed material in the plastic bucket.
Attach the full Shutz can to the gun and spray a test spot at 50 - 60 PSI. For the 1st coat, spray evenly but do not try to achieve full coverage or you could
cause drips/runs. Cover all surfaces so you still see some of the underlying paint showing through. Refill Shutz can as needed. Reseal the gallon Monstaliner
can after you fill the Shutz can each time. Spraying inside a jeep tub you should only need to fill the gun 1 more time after initial fill.
When done with 1st coat, pour any remaining material from gun back into the gallon can. Scrape down the sides of the can so little or no coating clings to the sides.
Pour 2 - 3 ounces of MEK or Acetone INTO THE EMPTY SHUTZ CAN, cap the can and shake vigorously to wash the can. Pour this solvent gently over the surface as
a "float" over remaining material in gallon to prevent it from thickening at the surface. When you open the can to start your 2nd coat just mix in the floating solvent.
Wait 1 hour before starting the 2nd coat. At this point, the Monstaliner mixture will have thickened some and now is when you are going to get some awesome texture.
Refill the gun and go. If the material is not spraying enough just up the pressure. You can go to the max, 80 to 100 PSI.
Note: If you do not rinse the Shutz can between coats it's possible that some material will thicken inside the can and cause chunks to blow out on the 2nd coat.
Connect with us on:
post #7646 of 13509 Old 04-25-2012, 11:19 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
5 New Colors
------- Pyroclastic ----------- Predator ----------- Apocalypse ----------- Detention ------------ Tarheel
Connect with us on:
post #7647 of 13509 Old 04-25-2012, 11:23 PM
alicethecat
Those all look great. I want the predator!
alicethecat is offline
post #7648 of 13509 Old 04-25-2012, 11:28 PM
SkippyPB13
5 New Colors
Predator all the way. Love all the new colors.
Ask about my Custom Paracord Jeep Stuff!!
Door straps, rollbar grab handles, bracelets.
SkippyPB13 is offline
post #7649 of 13509 Old 04-25-2012, 11:31 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I know you do! Just sent you a PM
More colors coming soon:
Outbreak
Killer Beej
Yank My Doodle
Turquila
Copper Feel
Nuclear Winter
NOTE ON NEW COLORS: The web request form needs to be updated to allow requests of new color chips.
PLEASE.. DO NOT REQUEST THESE COLORS UNTIL YOU SEE THEM AVAILABLE IN THE FORM.
THEY WILL NOT BE SENT AND DO NOT ADD THEM IN THE COMMENTS SECTION.
I WILL DELETE ANY REQUESTS SUBMITTED LIKE THIS. WE GET OVER 250 REQUESTS WEEKLY
AND IT IS ALL AUTOMATED. WE WILL NOT FISH THROUGH COMMENTS TO FULFILL CHIP REQUESTS.
IF IT'S NOT A CHOICE ON THE FORM IT'S NOT AVAILABLE YET.
I SHOULD HAVE IT ALL DONE/READY BY THE END OF THIS WEEKEND
Connect with us on:
post #7650 of 13509 Old 04-25-2012, 11:41 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
The long time missing 4 color chips from the Monstaliner Colors Page are now up
http://www.monstaliner.com/forms/monstaliner_colors.htm
Johnny Popper
Brown Eyed Girl
Road Rash
Don't Yell At Me!
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
