Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 508 - JeepForum.com
 25Likes
post #7606 of 13379 Old 04-22-2012, 05:55 PM
SKINUM
Originally Posted by TroubleNEO
2k primer is what Erik will tell you to use.
Is that available locally or is there a product that will substitute?
SKINUM is online now
post #7607 of 13379 Old 04-22-2012, 06:16 PM
TroubleNEO
Look for an automotive paint supplier, I don't think you can find it in a rattle can. Call Eric and place your order over the phone, Monstaliner is a division of Magnet Paints I'm sure he can set you up with the right primer and you might even get free shipping on the primer. I would primer the tub, spray your free quart of chassis saver over it, and then Monstaline it.
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline
post #7608 of 13379 Old 04-22-2012, 06:25 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
SKINUM you have an order in house here that is shipping tomorrow so we can add something to ship with it
Is the primer you asking about for use under Monstaliner?
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #7609 of 13379 Old 04-22-2012, 06:26 PM
SKINUM
edit
post #7610 of 13379 Old 04-22-2012, 06:29 PM
SKINUM
Yes, im going to use chassis saver on all of my armor and then spraying monstaliner on top of it.
However, the actual body section im assuming I can't use chassis saver as the primer?
post #7611 of 13379 Old 04-22-2012, 06:51 PM
Tinga
That's right, gotta prime. I used a self etching primer, but I only had some small spots I over sanded INSIDE the tub. If you are doing a larger area, get the better primer
Girls like STROKIN too!
http://www.jeepforum.com/forum/f153/1971-jeepster-commando-1380633/
Tinga is offline
post #7612 of 13379 Old 04-22-2012, 06:52 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
If the armor is all new/bare metal I would use 2K epoxy primer direct to the metal to save yourself the trouble of having to roughen the metal first to put Chassis Saver
Connect with us on:
post #7613 of 13379 Old 04-22-2012, 06:58 PM
SKINUM
And if it isn't brand new? I've got 2 quarts of chassis saver sitting in the fridge.
I'm wondering what I need to use on the body once it's sanded down?
post #7614 of 13379 Old 04-22-2012, 07:11 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
OK skip new or old references
Is everything bare metal or does something have paint that you are just sanding first before applying ML?
Connect with us on:
post #7615 of 13379 Old 04-22-2012, 07:17 PM
SKINUM
Sent you a PM so the thread isn't jammed up with my ?
post #7616 of 13379 Old 04-23-2012, 06:17 AM
Deacon
Shining Adonis
Deacon's Avatar
Some of us would like to know, too. Posting that you sent a PM is just as "bad" as posting the question in the first place.
Deacon is offline
post #7617 of 13379 Old 04-23-2012, 08:31 AM
SKINUM
Can't win with people on this forum. 50% of people will complain about ?'s and the others will complain if ya don't.
Here is the answer to satisfy the other 50% :
Yes, just scuff all the good paint and spot prime the rusted spots with CS.
If the paint is all sound on the body you can just coat ML over it after scuffing and good solvent cleaning
Just so you know, self etch primers are only for bare metal and should not be applied over previous paint.
Epoxy primer sticks to everything (bare metal or previous paint)
post #7618 of 13379 Old 04-23-2012, 04:23 PM
Deacon
Shining Adonis
Deacon's Avatar
Here's a tip: if you're not going to post your question don't post that you're not posting your question.
Deacon is offline
post #7619 of 13379 Old 04-23-2012, 04:30 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
This is a technical thread. All questions are welcome, repetitive or not.
Some day this thing will be 20,000 posts and ruler of all things bedliner
Connect with us on:
post #7620 of 13379 Old 04-23-2012, 04:48 PM
Gurrenteed555
Thanks for answering my questions! I know it must get old answering the same questions over and over, but isn't that how just about every job goes? I appreciate the fact that you have a great attitude about it! Plus, his customer service is the reason I just bought 3 gallons ($380) of this stuff. Can't wait to get it! Thanks again!
Gurrenteed555 is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
