Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 481 - JeepForum.com
 36Likes
post #7201 of 13514 Old 03-18-2012, 06:36 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by outlawsix View Post
Funky you say...... now im curious
Trust me it was funky, stayed sticky for 3 days
It needs some different material we don't stock right now
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #7202 of 13514 Old 03-18-2012, 06:40 PM
JPetru82
JPetru82's Avatar
ok, was supposed to post these a while back, but life has been a little crazy lately. Any ways, we will start with some pics
Tub, just after pulling carpet:
Tub, again:
Tailgate, after:
Driver Side, after:
Behind Drivers Seat, after:
My two cents:
Product arrived in the mail shortly after ordering, happy about that. Prep work took the longest to do, and is the most important. I wish I did the second coat thicker to get more of a texture out of it, I though I did but it dried with less texture then when it's wet. I did the whole tub with enough left over to do some smaller projects. If only I had known I would have extra left over, I could've cleaned them and had them ready ahead of time.
Question: If I want to go over certain areas to thicken it up, ie: drivers/passenger area, can I just buy a quart and go over it as is?
JPetru82 is offline
post #7203 of 13514 Old 03-18-2012, 06:48 PM
tinyjeep
Originally Posted by magnetman View Post
Get 1 extra roller and the mini roller kit with foam block.
1 Quart MEK or Acetone at Home Dep or Lowes
Tinyjeep... you mixed that gallon by hand with no drill?
Originally Posted by tinyjeep View Post
yup, i beat the crap outta it.being over excited and on a tight deadline( only 3 day weekend in sight) think whisking eggs with a knife
i might have used a drill, sorry. Flipping and painkillers will mess with yea head.
Originally Posted by The_Blacksmith View Post
Remember, it was a shark attack when you dove into the ocean to save a trapped puppy, while you were doing charity work to help clean up a local beach.
tinyjeep is offline
post #7204 of 13514 Old 03-18-2012, 06:59 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Oh man I liked whisking eggs with a butter knife
Got any extras
Connect with us on:
post #7205 of 13514 Old 03-18-2012, 07:13 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Yes, just need to clean and light scuff areas to coat over. You can roll clean lines and gently feather the edges with the roller.
Connect with us on:
post #7206 of 13514 Old 03-18-2012, 08:13 PM
WheelinCT
I don't know if this is even feasible, but is there a way to create a clear non slip type of liner?
Planning a party barge project and would like to coat the floor but keep it clear so you can see the actual flooring we use.
WheelinCT is offline
post #7207 of 13514 Old 03-18-2012, 08:31 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
This can be done in different ways but I would not use Monstaliner for that
What material will the floor be made from?
Connect with us on:
post #7208 of 13514 Old 03-19-2012, 08:23 AM
SideshowBob024
Adding Additional Non-Skid Properties to Monstaliner - 1st Trials
OK, here we go.
This material you see in hand is some sort of ground up plastic. It comes in many different particle sizes. Traditionally, we have used it as an non-skid additive
that either gets broadcast into wet floor epoxy or even mixed into the coating for rolling on the epoxy. It also works very well in gray Chassis Saver,
mixed into the coating and rolled on concrete floors.
I did not like what happens when I mixed it directly into Monstaliner. The mix got too thick to handle and roll correctly. Also because Monstaliner goes down
pretty thick, the particles got burried under the coating and the non-skid effect was not dramatic enough for my liking. It would take too much additive
thus making the Monstaliner almost like peanut butter, so...
I rolled 1 nice coat of Desert Sand tinted ML and broadcast the particles into the wet coating. I let it dry 2 or 3 hours (time will vary at diff temps and time of year)
and then rolled another coat of Desert Sand on top of the particles that were embedded in the first coat. Results below show straight Desert Sand (no aggregate) compared to the test.
I like it ALOT. We have a customer right now in Alaska building a custom wood canoe that will be getting his stuff this week. He is going to use this method to
try the process for himself and I am very anxious to see the results. Spent an hour on phone with him and will speak to him again after packages are received.
We've had sooooo many requests recently from people doing boats I am committed to ironing this out to work with complete documentation. I'm looking to
package the stuff for sale in some kind of shaker jar so it will be easy to use and broadcast as evenly as possible.
I do not suspect this will make a Monstaliner surface any more difficult to clean. As long as the material is broadcast sparingly you will not have any deep pockets to trap dirt.
This was just the first experiment so we will improve it over time.
Opinions - Comments?
Awesome, can't wait to see the results.
I also really like this because we were planning on non-skidding the foot traffic area's but leaving the rest regular ML, and this allows us to decide how much to non-skid or NOT non-skid any area we want. Bad ***.
SideshowBob024 is offline
post #7209 of 13514 Old 03-19-2012, 09:48 AM
WheelinCT
The top floor (or parts of it) we plan to use some marine grade wood/signs we have. We want to put a clear no slip substance on it so you can still see and read the signs.
Just trying to figure out if any of it could actually work or we need to go a more traditional route for the floor.
post #7210 of 13514 Old 03-19-2012, 11:12 AM
codymiguel
1987 YJ Wrangler
Zombie sunset !
Just ordered my 2 Gallon Tintable kit last night and Starting my sanding and prep work today... Can't wait to get my project under way! Just have to decide what color the interior is going to be.
codymiguel is offline
post #7211 of 13514 Old 03-19-2012, 12:06 PM
Tinga
Just ordered a full set of the Chips. Will decide what to line the commando in. AND, since hubby got a new compressor he wants to spray it. Better look at some spraying threads lol
Girls like STROKIN too!
http://www.jeepforum.com/forum/f153/1971-jeepster-commando-1380633/
Tinga is offline
post #7212 of 13514 Old 03-19-2012, 03:50 PM
mike_breaker_5
i have a few vids of spraying on my build thread... about page 7 i think.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #7213 of 13514 Old 03-19-2012, 04:15 PM
Tinga
Awesome. I'll look that up. I don't know CRAP about spraying or painting, though the DH used to work auto body alot so he has a good idea
Tinga is offline
post #7214 of 13514 Old 03-19-2012, 05:00 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
The face of the signs where the coating will go, is the graphics or images painted on the wood?
Connect with us on:
post #7215 of 13514 Old 03-19-2012, 05:01 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Got that, thanks for the order!
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
