Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 407 - JeepForum.com
 14Likes
post #6091 of 13210 Old 10-22-2011, 07:01 PM
timatoe
timatoe's Avatar
Originally Posted by The_Blacksmith View Post
xeylol takes off almost everything sticky in my experience.
I used xylol to remove a some adhesive spots on the floor of mine too. Not as much as he's got but time and patience is probably the key.
Wonder if that's going to effect reception?
timatoe is offline
post #6092 of 13210 Old 10-22-2011, 07:24 PM
The_Blacksmith
Genius with this metal
The_Blacksmith's Avatar
1993 XJ Cherokee
it shouldnt lol its just the battery cover lol.
The_Blacksmith is offline
post #6093 of 13210 Old 10-22-2011, 08:13 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Crap, you covered up all that pretty welding
I'm gonna just post a few pics in this thread, the rest are in my floor thread alot of them.
med quartz grey sprayed with the shutz gun available from magnet paint
magnetman is offline
post #6094 of 13210 Old 10-22-2011, 08:14 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by Mr.ThunderMakeR View Post
Don't really remember, I think it was just a general automotive adhesive, came in a spray can. Its pretty hard.
Are you game to figure out, maybe you can coat over it without removal?
post #6095 of 13210 Old 10-22-2011, 08:55 PM
Mr.ThunderMakeR
Nope no experiment for me
After trying a bunch of chemicals I finally found one that removes most of it. There is still a little left, especially on the sidewalls where I cant let it soak but its not too bad.
Making progress...
Mr.ThunderMakeR is offline
post #6096 of 13210 Old 10-22-2011, 08:58 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Awesome, glad it wasn't that much trouble
What did you use to cut the stuff?
Making progress...
post #6097 of 13210 Old 10-23-2011, 06:57 AM
RedlegWJ
Originally Posted by magnetman View Post
If Monstaliner was formulated to have the consistency of paint it would lose durability. First off because you could not build film thickness and you would need 8 coats to create a thicker barrier. Would get way expensive
Explain what you are thinking in more detail. I'm always looking for new ideas.
I put CS on my steel bumpers already. I plant to put the ML on next. The bumpers look good as they are and if the CS was UV protected, I would just leave them instead of having the textured/adobe look on them. I also plan to coat my flared portion of the fenders on my WJ and rockers, it would be nice to have the smooth look there if it were available. I'd keep the textured for inside the wheel wells and the body tub. Also the roof area inside the proximity of the luggage rack. Another idea for contemplation might be a true flat black. It would be cool to have that on either the whole hood or the raised center prtion. Flat to eliminate any glare. Would also be useful for some "tactical" applications...
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline
post #6098 of 13210 Old 10-23-2011, 08:56 AM
The_Blacksmith
1993 XJ Cherokee
use gloss black chassis saver and wait a few weeks, it turns a nice flat black lol
post #6099 of 13210 Old 10-23-2011, 10:01 AM
QCDoc
Whats a good psi to set for the shultz gun.. And does playin with the psi effect the texture as far as more or less texture?
QCDoc is offline
post #6100 of 13210 Old 10-23-2011, 05:02 PM
The_Blacksmith
1993 XJ Cherokee
the psi does effect the texture a little, but the nozzle on the guns adjustment really has a ton to do with it, also how you spray it. I was spraying around 60 psi the whole time.
post #6101 of 13210 Old 10-23-2011, 07:21 PM
QCDoc
Cool, how did u decided how to adjust the nozzle.. Just start sprayin a little then adjust to ur preference?
QCDoc is offline
post #6102 of 13210 Old 10-23-2011, 07:44 PM
The_Blacksmith
1993 XJ Cherokee
I started with it all the way in per magnets reccomendation, this is awesome setting, because it comes out nice and smoothe, when I moved to the second coat I played with the nozle coming out about a turn or a half turn and i got a little more texture that way. You'll know right away when you play with it, just spray something random like scrap, I sprayed my parts jeep
post #6103 of 13210 Old 10-23-2011, 07:54 PM
QCDoc
Sweet.. Im excited to get started, im startin my exterior tomorrow so im lookin for all the tips i can get lol
QCDoc is offline
post #6104 of 13210 Old 10-23-2011, 08:18 PM
The_Blacksmith
1993 XJ Cherokee
I was really nervous that I was gonna screw it up, but its realy easy, the first light coat (if you are spraying) really helps the product not to run when you go for the second coat etc, just dont over do it, and let it properly flash inbetween coats, you'll be really happy with the results, its hard to mess up.
post #6105 of 13210 Old 10-24-2011, 07:57 AM
nufga
2010 JK Wrangler
I had used both the scuff pad and a palm sander. It seemed like the scuff pad took too long and the palm sander was way too quick. I ended up using the 3M sanding sponges and they worked perfectly IMO.
nufga is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
