Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 395 - JeepForum.com
 36Likes
post #5911 of 13514 Old 10-07-2011, 07:40 AM
geiman
Originally Posted by magnetman View Post
In the 2 years we have been on JF I can remember 2, maybe 3 instances where someone did not get their free quart of Chassis Saver and when we heard about it we sent it out. I've never heard from you before other than a PM you sent me yesterday and I never delete PMs so I checked my old messages and I have no others from you. Who did you email or leave a message for? Was this a web order you placed or a phone order to our office?
Frankly, I don't like your attitude as demonstrated in your PM. If you have a gripe about something just ask me a question or tell me what the problem is without the other stuff.
I always try to go out of my way to help people here on JF and I don't think you will find anyone who will dispute that and we certainly never screw anyone over on the promo offer.
x50; magnetman goes way out of his way for us on here, there is no reason for him to be treated badly.
geiman is offline
post #5912 of 13514 Old 10-07-2011, 07:42 AM
QCDoc
Is the 800# back in working order yet?
QCDoc is offline
post #5913 of 13514 Old 10-07-2011, 07:57 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Yes it is back working
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #5914 of 13514 Old 10-07-2011, 08:01 AM
QCDoc
Cool thanks
QCDoc is offline
post #5915 of 13514 Old 10-07-2011, 08:05 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I am workin on testing out things to remove what i belive to be duplicolor spray on liner from the back of my jeep. One of te things i picked up attaches to my angle grinder and sands it off but it also takes it down to bare metal, gets it all off but it also is cumbersome for tight spaces but makes quick work of flat areas..so my question is if i go i bare metal, and clean it properly using the mek is that "scuffed" enough to apply monsta to?
No Monstaliner direct to bare metal it will not stick well. You must prime that first. If the metal is smooth, use epoxy primer and a roller, then ML over that.
If the metal can be made rough with good sand scratches you can use Chassis Saver as the primer
Connect with us on:
post #5916 of 13514 Old 10-07-2011, 08:08 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by LuckRider View Post
Xylene. I was recommended that by Magnet. He never mentioned MEK and I am not sure I would even want to try it. IIRC, 5%. It really isn't much that it needs.
LuckRider are you drinking this early in the AM?
MEK is what we have always recommended to spray ML
Acetone is second choice with xylene 3rd for smoother texture as Vincent used with his black rolled exterior
Connect with us on:
post #5917 of 13514 Old 10-07-2011, 08:17 AM
LuckRider
LuckRider's Avatar
He was talking about CS Magnet. MEK for Monstaliner, Xylene for Chassis Saver.
Edit: Whoops... I can't read
Alright. So I nominate that CS is no longer CS, but Chassis Saver, and ML is no longer ML. ML shall now be refered to as Monstaliner or The Monsta, or
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #5918 of 13514 Old 10-07-2011, 08:28 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I had to read it again myself now. Too much typing
Note that any of these solvents we are talking about can be used with Monstaliner or Chassis Saver
It's time for an FAQ section here on JF in attempt to cut down on repetition
Connect with us on:
post #5919 of 13514 Old 10-07-2011, 08:38 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by The_Blacksmith View Post
I had a question on preference.
On application of monstaliner, which I cant wait to do. I'm basically ready now.
The recoat window is 24 hrs, maning If I spray chassis saver and in less than 24 hrs can monstaliner over it.
Do you reccomend this, or should I get the chassis saver down, let it dry fully for say 4 or more days, then come back in and scuff it all down with 50 grit etc. Which would hold up better. I'm not worried about the extra work if it will stick better with less risk of me tearing it up.
Sorry for the delay on this
This is really your choice. 50 grit is way too coarse to scuff CS before ML
You want to dull the surface and make some powder. 100 - 120 grit, maybe 80 grit as the coarsest I'd go. 4 days is overkill if you want to get it done
you still have a lot of time on your hands correct
Connect with us on:
post #5920 of 13514 Old 10-07-2011, 09:23 AM
mike_breaker_5
HAHAHA BAM!
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #5921 of 13514 Old 10-07-2011, 09:34 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Note to anyone else waiting for an answer to PMs sent and not responded to yet, I will get to this all tonight and tomorrow
Connect with us on:
post #5922 of 13514 Old 10-07-2011, 10:48 AM
GregStephens2
Sweet sent an email through the site contact addy.
Will you be getting to those soon?
Greg Stephens/Arboreal Specialties
http://www.arborealspecialties.com/Home.html
GregStephens2 is offline
post #5923 of 13514 Old 10-07-2011, 04:00 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Answering all questions tonight from my new mega laptop
Yes LuckRider I have finally caught on!
Connect with us on:
post #5924 of 13514 Old 10-07-2011, 04:43 PM
The_Blacksmith
1993 XJ Cherokee
thanks bro. you rock as always!
Thanks Chris!
The_Blacksmith is offline
post #5925 of 13514 Old 10-07-2011, 09:54 PM
Mikeg175
I would like to know what attitude there was in my pm , which was sent on the 27th of last month , not yesterday .
Hello ,
I ordered the kit to do my Jk a few months ago , I never received my chassis saver , I sent emails to the company and even left messages . I just bought a YJ to play around with and I bought POR-15 to do the chassis with , I am going to order some Herc liner or have it Linex'd . I didn't want to blast you guys in the forums , but when people ask me about my liner , I explain how well it works , how easy it was to apply , then I wont tell them who it is from . I work part time at a 4x4 shop and was looking for a new product to get my customers to use , but I think I will work out something with a local company who uses linex or something like that . Thanks for your time . Mike
If that was attitude , I am sorry , as I have stated I had a great experience with the product , but when I sent a few emails and even left messages . I let it go since it was a new Jeep and I wasn't worried too much , just figured I would never do business with your company again . Then when I bought a beater Heap to go have fun with I came back to the forums to see what was new out there . I then sent a pm ( above ) and after a week of waiting ( I assumed I would get some response ) I posted up . I was shocked that I didnt receive a Pm back , because it does seem like your always responding quickly to responses here . I am not here to argue or disagree with how well the product works ,( it rocks ) but I know I run a 90 hr work week , burn my cell phones down , but I can always answer all my emails/texts and faxes when it comes to making my business work .
Thanks for the great product , but please don't act like I sent a nasty Pm , I was hoping it would at least warrant a response back in a 10 day period and it didn't . I don't post a lot , I read a lot and I try to learn a lot , I will chalk this up to a learning experience . Thank you for your time .
Mikeg175 is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
