Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 39 - JeepForum.com
 25Likes
post #571 of 13379 Old 03-12-2010, 10:38 AM
Deacon
Shining Adonis
Deacon's Avatar
Have you ordered a sample? It actually feels really nice and smooth.
Deacon is offline
post #572 of 13379 Old 03-12-2010, 11:21 AM
84MSRB
It is very nice and smooth- except for where you maybe lose a brush bristle, or a small chunk of the roller toward the end of one of the coats. Ask me how I know.
1984 CJ7 Mud Slingin Rust Bucket
90 YJ tub
Ford Mutt 5.0( 69 block, 89 EFI)
84MSRB is offline
post #573 of 13379 Old 03-12-2010, 03:45 PM
DaleII
Originally Posted by magnetman View Post
No issues with more coats. I have a panel with at least 30 coats.
QUOTE]
So I can apply two say on Saturday then another two on Sunday? Giving time in between the two? I didn't know whether you could apply more Monsta after the first couple coats have already dried without hindering it's abilities.
2005 Silver LJ
DaleII is offline
post #574 of 13379 Old 03-12-2010, 05:30 PM
LuckRider
LuckRider's Avatar
x2, The material has a nice feel on bare skin, and it offers great insulation. I have posted a full write up and review, and that was one of the things I addressed.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #575 of 13379 Old 03-12-2010, 06:09 PM
erickpl
erickpl's Avatar
I haven't gone back through the thread, but i got my sample piece in the mail today. Feels GREAT!!!! But it leads to a few questions:
1. How grippy is it when it gets wet? What can I expect? I do NOT wanna bust my butt climbing up and in with wet or muddy shoes.
2. Do we have pics in this thread with the product applied? Any updated ones?
I'm trailguiding a Jamboree here in Cullman, Alabama in May, and would LOVE to have this installed before then. It will facilitate cleanup and I'm sure it will get a lot of looks while I'm there. Plus if it rains, I won't have to worry about my carpet.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #576 of 13379 Old 03-12-2010, 06:13 PM
LuckRider
LuckRider's Avatar
1. It is really hard to say how grippy it is. I would say it is about as grippy as the factory paint, or any surface that has paint of it (where you would be putting the stuff anyways).
2. That is simple, I did a full write-up with pics, and a review at the end. Here is the link: http://www.jeepforum.com/forum/f9/mo...ite-up-901675/ It is actually the first link if you type in Monstaliner Write Up in Google.
As for cleaning up, this really will help. I took a spray bottle, and just sprayed my bumper with it, and it came off super easily. I have stepped on my bumper when it was wet, and I didn't fear slipping.
Support Our Troops!
JFI Member #7:
post #577 of 13379 Old 03-12-2010, 06:21 PM
erickpl
erickpl's Avatar
Luck, what would I use the chassis saver for? Is that meant for undercoating or for applying to the paint before I apply the Monstaliner? I haven't been following this thread much (school, work, etc in the way), so I'm playing catch up. My 97 is in good shape where I'd be applying this (interior), but I want to be sure I do this right so I don't hose it up.
What technique did you use for applying to those tight areas (like around the jack storage location and the grooves in the front)?
Looking for your writeup now...
-Paul
erickpl is offline
post #578 of 13379 Old 03-12-2010, 06:27 PM
LuckRider
LuckRider's Avatar
I did post the link the the write up, and it is also in my sig. For the tight areas I used the included roller and brush (as well as an old brush we had laying in the garage).
I didn't get the chassis saver, that is just an extra that is included as a special deal to help get some exposure. I would save it for cleaning up some cancer under the Jeep.
Support Our Troops!
JFI Member #7:
post #579 of 13379 Old 03-12-2010, 06:54 PM
erickpl
erickpl's Avatar
Went through your writeup - I forgot I read it!
So basically, prep interior with sanding, wash out, use the MEK to get all junk off the paint, let dry, then go at it...
My carpet was installed with a spray glue, tacky stuff, especially in the back... i wonder if that will pose a problem with sanding or if I could use the MEK first to get that out, then sand, then wash/MEK again...
With Spring here in Alabama, humidity will be close behind, so it is coming on the perfect time to do this. Glad this TJ isn't seeing DD duty any more with my son. I can afford to let it cure the right way. Would curing in sun be better or in the shade of a warm/humid garage out of direct sunlight?
I'd likely do the door sills and go up to the dash base for completeness. Also planning on doing the edge around the tub where I have some good scratches. It'll be under my duster usually, but it should look nice and be protection for that exposed lip around the back. Just have to decide how far up the inside of the tub I want to go. Probably all the way up on the inside just to protect some areas where I've drilled holes for my rockers and side sliders in back. Guess that is just a personal choice. Did you go up your cage at all in back or just around the base?
-Paul
erickpl is offline
post #580 of 13379 Old 03-12-2010, 06:58 PM
LuckRider
LuckRider's Avatar
The MEK sand MEK process sounds like a good plan. As for the sun versus shade thing, I really have no idea.
Well MagnetMan, I ended up getting that hard top. I am not sure, but I think I might be using the other gallon on the top of that. If I do, my plan is:
Strip the interior of the Jeep again
Spray the inside of the top with the Rustoleum Gloss black that we have
Roll one coat on the top.
While the first coat is drying, put a third coat in the Jeep, on my bumper, and on the frame rails of the trailer
Roll out the second coat on the top
Hit the trailer again with any left over liner
Now for a question, is there a way to get a butter smooth coat? I really want it to look factory, so that means no texture. I am actually surprised at it being in perfect shape for a '97. Would a regular paint roller work, or do I need to get a couple of those really smooth rollers? I still have two of the blue rollers for the tub, so I am not worried about that.
Support Our Troops!
JFI Member #7:
post #581 of 13379 Old 03-13-2010, 06:55 AM
Viencent
1982 CJ7
ok started pulling the Monstaliner back out and its coming out is big sheets, it turned my old liner to a mushy tar like mess, going to start with the MEK today to get all the rest out
Viencent is offline
post #582 of 13379 Old 03-13-2010, 08:51 AM
LuckRider
LuckRider's Avatar
Good Luck getting the other stuff out.
Support Our Troops!
JFI Member #7:
post #583 of 13379 Old 03-13-2010, 09:14 AM
Viencent
1982 CJ7
its turned to powder over night as it dried, can scrap it with my fingernail so dont think it will be too bad with the MEK. on the way to get that if a few minutes
Viencent is offline
post #584 of 13379 Old 03-13-2010, 11:08 AM
Deacon
Shining Adonis
Deacon's Avatar
Good luck, Viencent. Let us know how it works out!
You might want to reconsider that. It's going to be like a cave in that Jeep. Interior roofs are generally light colored for a reason. I'd say go with an eggshell brown at the very darkest (I don't remember what your interior color is) or otherwise paint it some shade of white.
Deacon is offline
post #585 of 13379 Old 03-13-2010, 11:11 AM
LuckRider
LuckRider's Avatar
The top right now is white, but I am used to my soft top which is such a dark gray that it is just shy of black. I do see what you are saying now that you mention it. We managed to snag 1 gallon of the oil based paint for just $10, and we have more than half the gallon left over from painting the trailer. I figure if I don't like it I can just get like 2 cans of charcoal gray or something.
Support Our Troops!
JFI Member #7:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
