Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 246 - JeepForum.com
 36Likes
post #3676 of 13514 Old 06-06-2011, 11:13 PM
onelow1ton
1983 FSJ Wagoneer
Originally Posted by magnetman View Post
Every order we have had through the web site will get mailed stickers.
This started as a pet project 6+ years ago. 2.5 yrs ago it got serious.
The plate is going in the dishwasher soon. Just gotta make the pink and the lime green
lime green hot dam im happy now lol
NEW BUILD 1983 wagoneer bagged and bodydropped Click here for build -->
onelow1ton is offline
post #3677 of 13514 Old 06-07-2011, 11:20 AM
monkeyhouse
EXCELLENT points you made.
The greatest issue with doing any install outdoors is that air movement and heat from the sun will make
the coating set up faster which is detrimental to being able to take your time and look over all surfaces
carefully and make some more clean passes with the roller to even out the texture.
If you at least had a canopy or carport above it would help greatly.
Having good light to reflect off surfaces helps greatly to see spots that need another roller pass.
A cheap clamp on aluminum reflector light or a big flashlight would also help.
Totally agree. Although I like the idea of working out in the sun, if I had it to do over again, I would use a garage. I even had a small setback from a light wind when it blew some Styrofoam peanuts onto my hardtop hatch door, lol. Luckily, I saw it and took care of it in time.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #3678 of 13514 Old 06-07-2011, 11:59 AM
SarahRose
Are you really doing lime green? Because my cage is painted lime green and I'm going to paint like the tie rod and track bar and dif cover, those things, lime green too...I was going to spray paint them but...if there is lime green monsta coming, well, now I'm not sure if I want to hold off on spray painting them to wait for the monsta or what...
The way I see it, a Jeep is like sex-when it's good it's terrific, and when it's bad it's still pretty good!
SarahRose is offline
post #3679 of 13514 Old 06-07-2011, 12:09 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Yep, 2010 Camaro Lime Green
Manufacturers of CHASSIS SAVER™ Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #3680 of 13514 Old 06-07-2011, 12:14 PM
aztec_doc
Boy you so crazy with all your rad colors. Yeah I said rad.
2008 JK Rubicon
aztec_doc is offline
post #3681 of 13514 Old 06-07-2011, 12:25 PM
SarahRose
Ughhhhh the last thing I need is to spend more money but that is suuuuuch an amazing color! And with the spray guns, doing things that are round like a roll cage is going to be way easy. Well...as easy as painting round things is, I guess.
Man. I might not be able to resist this. How soon dya think it'll be out? I know you probably get that question a lot, sorry. "It'll be done, when it's done", I assume.
**** it looks awesome.
post #3682 of 13514 Old 06-07-2011, 01:06 PM
clg82
hello everyone, been seriously considering doing a Monstaliner, on the interior of my jeep.....what is the drying time in between coats that you suggest? thanks for any help magnet~Chris
clg82 is offline
post #3683 of 13514 Old 06-07-2011, 01:11 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
For rolling:
Black is 3 - 5 hours between coats
Colors will be 2 - 4 hours
Times are less in higher heat/humidity conditions
Connect with us on:
post #3684 of 13514 Old 06-07-2011, 01:14 PM
SarahRose
Will the promo last until all the colors come out? I sure hope so...
post #3685 of 13514 Old 06-07-2011, 02:10 PM
clg82
For rolling:
thanks for the quick reponse, I noticed that it comes with one scuffing pad to prep the tub....is that enough to do the whole thing? and how many coats do you suggest for the inside of the tub of my jeep?
clg82 is offline
post #3686 of 13514 Old 06-07-2011, 02:16 PM
TESmith
Anyone done a burnt orange or white exterior yet?
95 YJ, 99 TJ and 86 Comanche
Love them all in their own way!
TESmith is offline
post #3687 of 13514 Old 06-07-2011, 02:34 PM
Viencent
1982 CJ7
On the exterior, Magnetman you have any idea when you will get the chance to do the smooth rool out and post some pics?
Viencent is offline
post #3688 of 13514 Old 06-07-2011, 02:34 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
2 coats always in a tub. If the scuff pad wears out before done just use 100 grit sandpaper
Connect with us on:
post #3689 of 13514 Old 06-07-2011, 02:35 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Sorry I did not forget about you. Will have some samples done this week.
Connect with us on:
post #3690 of 13514 Old 06-07-2011, 02:36 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Colors were just released 2 days ago. Got to give it some time.
Have not sold any burnt orange yet
So far: ODG, desert sand, med quartz, white
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
