Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 245 - JeepForum.com
 36Likes
post #3661 of 13514 Old 06-06-2011, 01:15 AM
ApolloXIII
Originally Posted by magnetman View Post
Thanks to all for the orders!
No, thank you for the colors!
ApolloXIII is offline
post #3662 of 13514 Old 06-06-2011, 07:53 AM
craigbru
2007 WK
More love for the Monsta! I got my Genright flares and corner armor installed. I know earlier in this thread I was asking about methods for getting a smoother finish, but I've now fully embraced the texture.
Jeep-Core
craigbru is offline
post #3663 of 13514 Old 06-06-2011, 07:56 AM
mike_breaker_5
I've been avoiding this question for the moment
Here's the problem: 1 gallon tintable needs 8 ounces of color which we have packed in a nice little 8 ounce paint can.
1 quart of tintable needs 2 oz of color and they don't make a can that small. There will be a solution but I was not rushing to come up with it. Part filled cans are a nightmare because they need to be filled by weight
How soon you want this???
maybe for the time being you could offer 4 of the 4oz catalyst packets with gallon kits by request. then all you have to do is mix the color, take 30oz (?) of that mixture, and mix it with the 4oz packet of catalyst. this is no less expensive but your not pressed to use all the gallon at once, also if your like me there is always something that can use a coat of monstaliner. i actually had a dream lastnight that i coated the entirety of the interior of my house in colored monsta.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #3664 of 13514 Old 06-06-2011, 10:01 AM
tractor1
1979 CJ5
I think you and Eric are hitting that bottle again
1979 CJ5 304 T150 Dana 20 under construction
1993 Wrangler 4.0 HO AX15 231 4” lift 33 12.5 15 DD
1994 Wrangler 2.5 AX5 231 Stock Sold
1973 Cj5 304 T15 Dana20 Sold
tractor1 is offline
post #3665 of 13514 Old 06-06-2011, 12:12 PM
The_Blacksmith
1993 XJ Cherokee
screen shots and tequila shots!
paint phil blue!
I think I might have to check out this magnapoxy
Thanks Chris!
The_Blacksmith is offline
post #3666 of 13514 Old 06-06-2011, 12:15 PM
95builtXJ
1995 XJ Cherokee
How many cans to do an XJ?
95builtXJ is offline
post #3667 of 13514 Old 06-06-2011, 12:22 PM
TESmith
Ok so post #3242, page 217 of this thread, was the exterior sprayed, or rolled on this Jeep?
I think I may like that texture on my exterior, would not want much rougher I do not believe
95 YJ, 99 TJ and 86 Comanche
Love them all in their own way!
TESmith is offline
post #3668 of 13514 Old 06-06-2011, 12:30 PM
95builtXJ
1995 XJ Cherokee
That did turn out really good.
post #3669 of 13514 Old 06-06-2011, 12:56 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I know who that is, rolled for sure
Manufacturers of CHASSIS SAVER™ Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #3670 of 13514 Old 06-06-2011, 02:16 PM
TESmith
I wonder if I put wet sheets down and a canopy/tent top overhead If I would be asking for disaster If I rolled the exterior out in the yard? ( I do not have a garage) Has anyone done this outdoors?
TESmith is offline
post #3671 of 13514 Old 06-06-2011, 02:54 PM
mike_breaker_5
i have done all my work outside. however i have sprayed everything except the first coat i applied to the interior last year, so i do not have alot of rolling experience with monsta.
post #3672 of 13514 Old 06-06-2011, 04:36 PM
JamesHasler
I rolled mine outdoors (exterior)... although I have to say that mine didn't turn out quite as well as the pics above and I think it had to do with the glare I had off the hood as well as the technique. The sides have a great uniform texture because there was no glare and I started to perfect the technique of getting a uniform texture (hood was done first). The hood looks awesome in places, but there is a texture transition that is kind of noticeable and it's because I couldn't see that well given the sun's reflection off the wet hood. (Yes, magnetman warned us about doing it in direct sunlight... LOL)
Knowing all of this, instead of just focusing on coverage like I did with the hood, I would have gone back and made some nice clean passes with the roller one last time, like I did with the sides/doors, and I think the hood would have been perfect too...
And don't forget the drips! I saved many a drip by going back around and catching them in time. I have one on my rollbar that I didn't see and it's nasty once it is hardened... ;-)
James
JamesHasler is offline
post #3673 of 13514 Old 06-06-2011, 10:57 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
James
EXCELLENT points you made.
The greatest issue with doing any install outdoors is that air movement and heat from the sun will make
the coating set up faster which is detrimental to being able to take your time and look over all surfaces
carefully and make some more clean passes with the roller to even out the texture.
If you at least had a canopy or carport above it would help greatly.
Having good light to reflect off surfaces helps greatly to see spots that need another roller pass.
A cheap clamp on aluminum reflector light or a big flashlight would also help.
Connect with us on:
post #3674 of 13514 Old 06-06-2011, 10:59 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Just pick your day wisely. Have the prep done ahead of time.
Roll first coat early in the AM before sun is high and hot.
Do it before summer really kicks in
Connect with us on:
post #3675 of 13514 Old 06-06-2011, 11:01 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Not OD Green?
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
