Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 219 - JeepForum.com
 21Likes
post #3271 of 13347 Old 04-26-2011, 06:21 PM
TheDirtyGeneral
Originally Posted by LuckRider View Post
No.... someone had to do that because the J would be closer to the wheel if it was mirrored. That was intentionally done in reality.
Are you sure this isn't the picture of a passenger side mirrored?
Chris. I miss driving my Jeep. Can't wait to get into another one.
TheDirtyGeneral is offline
post #3272 of 13347 Old 04-26-2011, 07:25 PM
tangotag
Passenger side view mirrored. Radio antenna is the give away.
tangotag is offline
post #3273 of 13347 Old 04-26-2011, 07:29 PM
parrotparty
It's been a while since I've asked questions.. but will the one gallon kit cover a short bed in an f250?
Originally Posted by 243 View Post
....I don't know that my way is the right way, it is just the way I did it.
Originally Posted by freedommachine View Post
If it makes you paranoid and requires forum discussions it belongs on a Jeep.
"Well boss, a diesel needs its oil like a sailor needs his rum."- Capt. Ron
parrotparty is offline
post #3274 of 13347 Old 04-26-2011, 07:39 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
It should. Just double check your total footage is not more than 60 sq ft
Manufacturers of CHASSIS SAVER™ Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #3275 of 13347 Old 04-26-2011, 07:52 PM
mike_breaker_5
just for that feel good feeling you should start an official countdown to release of colors! lol you know like new years, with all the sparkles and stuff and things..... and stuff. sorry RUM! celebrating a raise at work! another $1.03/hr! i'm winning!
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #3276 of 13347 Old 04-26-2011, 08:21 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
10..9..
I'm more excited about the 3rd video I'm almost done with in less than a week
"How to Mix Monstaliner"
Oh, and a big congrats on the raise! Will you be on here later asking for more emoticons?
Connect with us on:
post #3277 of 13347 Old 04-26-2011, 09:26 PM
TheDirtyGeneral
Originally Posted by magnetman View Post
10..9..
Not the exact measurements you wanted but (edit: all measurements in INCHES and were done on a TJ not TJ unlimited just a regular TJ)
Under hardtop window (still part of hardtop) 35X4
Front hardtop pillar 4.5x26.5
Rear hardtop pillar 26.5x9
Top of hardtop 59x73
Grill 16.5x39.5
Hood (includes side of hood or curve) 65x48
Fender (flat part on top first measurement at thickest point then decreases to 0) 8x42
Side including doors 102x28
Back including rear door 56.5x18.5
post #3278 of 13347 Old 04-26-2011, 09:42 PM
TheDirtyGeneral
In FT we're looking at ~34ft^2 for that hard top and
~56ft^2 for the body
Both are rounded up
post #3279 of 13347 Old 04-26-2011, 10:11 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Both are rounded up
I was just goung to add you #s
So it's 2 qts or 1/2 gal for the top
The body is 1 gallon. How much over actual measurements do you estimate you have in your 56 sq ft?
Is this measured across the wheel wells without subtracting for those spots?
I'm reading back now: What is "56ft^2"
The thing that concerns me here is with an exterior being a more complex job, it's possible that more coating could go to waste which would leave someone hanging high and dry if they run out before complete. That is if the job requires very close to the 1 gallon volume.
Connect with us on:
post #3280 of 13347 Old 04-26-2011, 10:17 PM
TheDirtyGeneral
Definitely didn't subtract wheel wells and they are still added in that 56 square feet
56 square feet
The thing that concerns me here is with an exterior being a more complex job, it's possible that more coating could go to waste which would leave someone hanging high and dry if they run out before complete. That is if the job requires very close to the 1 gallon volume.I over measured for sure just for that reason Like the hood isnt as wide toward the front as it is towards the rear so I measured from thickest part, then measured to lip of windshield to lip of hood. Then for the sides I measured from the longest part of the fender on the side all the way to the back seem. then went from tub lip to bottom of tub. then when measuring the rear I went from back seam to back seam and from hardtop glass to rear bumper.
post #3281 of 13347 Old 04-27-2011, 01:42 AM
Cavguy1965
I have an LJ w/ a soft top and hard doors. I should point out here that when you guys were describing the dimensions of the LJ up top, you forgot to mention it is the coolest Jeep of all the body styles! I'm sure it was just an oversight on your part...
Let me see if I understand this, it should take me one gal to do the inside and we aren't sure yet how much to do the outside?
Mark W. Altman, MIS
~“No act of kindness, no matter how small, is ever wasted.” – Aesop~
~"I have decided to stick with love. Hate is too great a burden to bear."- Martin Luther King, Jr.~
~“Every man is guilty of all the good he did not do.”- Voltaire~
Cavguy1965 is offline
post #3282 of 13347 Old 04-27-2011, 03:43 AM
Deacon
Deacon's Avatar
Am I missing something, or is this pic mirrored? its says nocibur and peej lol
Yes it's mirrored. I did that so the Jeeps were facing in the same direction, minimizing the mental gymnastics your brain has to do to spot the difference.
Deacon is offline
post #3283 of 13347 Old 04-27-2011, 09:47 AM
311LJ
311Popo
311LJ's Avatar
Sorry I went and celebrated passing my academy physical test final Last night, so I didn't get to measure the LJ. I get off work in 4-5 hours and will measure it up then.
John
04 TJ Unlimited, GenRight Armor, 37's
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY*
I ♡ John
311LJ is offline
post #3284 of 13347 Old 04-27-2011, 09:52 AM
MVines
2010 JK Wrangler
Just curious what prep work other than sanding is needed? Should I remove the sound deadining goo that is in the tub of my jk? Also is the one gallon kit enough to do the entire interior tub, including the front floor pan up to the firewall? Thanks,
Melissa
MVines is offline
post #3285 of 13347 Old 04-27-2011, 09:58 AM
Cavguy1965
311WJ, congratulations!!! Which Academy are you headed to? The Long Grey Line?
Mark W. Altman, MIS
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
