Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 214 - JeepForum.com
 19Likes
post #3196 of 13307 Old 04-24-2011, 09:14 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by LuckRider View Post
http://<font color="White">http://ww...011.htm</font>
Tada, it is a matter of wrapping the colored text in the URL code.
Now I'm tearing hairs here. Can you get this to stay in color?
Read Full Promo Details Here
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #3197 of 13307 Old 04-24-2011, 09:18 PM
TheDirtyGeneral
Chris. I miss driving my Jeep. Can't wait to get into another one.
TheDirtyGeneral is offline
post #3198 of 13307 Old 04-24-2011, 09:19 PM
TheDirtyGeneral
The trick is where you type the name of the link (where you typed "read the full promo details") put the color code in around that!
post #3199 of 13307 Old 04-24-2011, 09:33 PM
LuckRider
LuckRider's Avatar
^That. The color is the second layer. From what I can tell, these are the layers:
1. Image/Text
2. Color For Image
3. URL Code.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #3200 of 13307 Old 04-24-2011, 09:34 PM
humbertotrevino
That's a very dirty lab scale.
98 TJ, K&N cold air intake, gibson exhaust catback, Bushwacker 6" fender flares, 31" AT, 2.5 OME HD lift, JKS adj. front trackbar, JKS adj rear trackbar, JKS quicker disconnects, JKS 1" MML, JKS 1.25" BL Superwinch EPi9.0, Bestop Sunrider and sliders, PIAA, custom winch plate,
My buildup:
Originally Posted by RnEmOvr View Post
I'm going to beat gas prices Flintstones style!!
humbertotrevino is offline
post #3201 of 13307 Old 04-24-2011, 09:35 PM
TheDirtyGeneral
][B ][SIZE="5" ][URL ="http://www.monstaliner.com/jeepforum_promo_43011.htm"][ COLOR="White"]Read Full Promo Details Here[/COLOR ][/URL ][/SIZE ][/B ]
Okay I added spaces so you could clearly see the order to insert them!
post #3202 of 13307 Old 04-24-2011, 09:37 PM
LuckRider
LuckRider's Avatar
Forgot about the size layer and bolding. It automatically gets underline being a link, and you can Italicize it too.
Support Our Troops!
JFI Member #7:
post #3203 of 13307 Old 04-24-2011, 10:45 PM
LuckRider
LuckRider's Avatar
Delete the Space between the image and link it (The pic).... I showed you how
Otherwise, looks good
Support Our Troops!
JFI Member #7:
post #3204 of 13307 Old 04-24-2011, 11:07 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Can't link to a pic uploaded as part of sig and you can't center it either
Connect with us on:
post #3205 of 13307 Old 04-24-2011, 11:10 PM
LuckRider
LuckRider's Avatar
That sucks. Ok, well. then it is go the way you previewed. Shoot a quick PM to Keith and see if he can change that. It is not like you are using it to make your sig more obnoxious and overly large like some members have on certain forums. I like that they restrict certain things to make JF cleaner.
Support Our Troops!
JFI Member #7:
post #3206 of 13307 Old 04-24-2011, 11:18 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
OK thanks for your help and the General too!
Bedtime is here. Hope everyone had a Happy Easter weekend!
Connect with us on:
post #3207 of 13307 Old 04-24-2011, 11:46 PM
Showtime3492
1 Quart of Chassis Saver covers 90 sq ft for 1 coat.
How much is a little rust?
No pictures right now but it would be on the underside of my xj above and around the gas tank area its nothing really heavily rusted but is somethin that i would like to do some preventative maintenance too. I also have some rust on the body where the rear doors are on the panel at the base of the door on the body. I am plannin on lining the exterior of my jeep from the windows down because it sees plenty of trail time and i need somethin that will hold up. I was planning on chassis savering the bottom of the door jams and underside around the gas tank and around the rear on the exterior where the rear quarters are down to the rockers, which 1 qt should be plenty if it covers 90 sq ft for 1 coat i can probably get the 2 full coats out of it.
Showtime3492 is offline
post #3208 of 13307 Old 04-25-2011, 07:28 AM
XJelvis
I would think so. With my quart of Chassis Saver, I did the front and rear floor pans of a TJ, plus some various other spots in the tub, then primed a new front bumper with it. And just using the excess I had poured out each time, I did some old cast iron weight plates. Two coats on everything.
And I still have over half the can left!
94 YJ, 2.5L, 5sp Sold.
97 TJ, 4.0, 5sp Sold.
01 XJ, 4.0, Auto
XJelvis is offline
post #3209 of 13307 Old 04-25-2011, 09:30 AM
Showtime3492
Ordered cant wait to get it and install it!!
post #3210 of 13307 Old 04-25-2011, 09:42 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Got your order, THANKS!
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
