Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 203 - JeepForum.com
 25Likes
post #3031 of 13379 Old 04-16-2011, 09:11 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by ajf1994 View Post
Question... Would you apply with ~50 degree weather and raining outside? I ended up having the day off of work, and nothing to do...
Ehhhhhh.... I would wait. Temp is not such an issue as the 100% humidity
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #3032 of 13379 Old 04-16-2011, 09:17 AM
ajf1994
So tomorrow, ~40 and 30% chance of rain, would be better?
-SupportOurTroops-
High School Jeepers #361
Parrothead Jeep Club #46
37,xxx Miles
Originally Posted by XJ-Tim View Post
my welds look like popcorn with sprinkles.
Originally Posted by Benjamin Franklin
Beer is proof that God loves us and wants us to be happy.
ajf1994 is offline
post #3033 of 13379 Old 04-16-2011, 09:18 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by aestrad1 View Post
Can you recommend anything to lay down before to keep the heat out? Its gets HOT here over the summer here in AZ, so Id rather not fight the floor heat when running the AC.
Also the LJ is 10 inches longer in the tub and I want to do the roll bars. I want to take the liner all the way up the sides up to the windows in the rear. Will the quart cover this extra area or should I just get 2 gallons to be safe?
Thanks for the quick replies!
Nothing really to recommend for heat right now. If a mad scientist idea I have works out we may have something to offer later in the year.
What's the length of a standard Wrangler 2 door tub adding for the upswing at the fire wall behind gas/break pedals?
Connect with us on:
post #3034 of 13379 Old 04-16-2011, 09:21 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Will you be working in a regular garage with the door open?
Connect with us on:
post #3035 of 13379 Old 04-16-2011, 09:24 AM
ajf1994
Yes.
-SupportOurTroops-
37,xxx Miles
ajf1994 is offline
post #3036 of 13379 Old 04-16-2011, 09:34 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Yes.
Just check the humidity. Best if it's below 65%.
I just looked at tomorrows weather. Long Island, 60 deg, windy, partly cloudy
If Buffalo is similar with 10 deg less it's good.
We're really getting close to ideal weather for Monstaliner installs. Sunny, cool 60's is nicest.
Connect with us on:
post #3037 of 13379 Old 04-16-2011, 10:02 AM
Tinga
From what I have observed. When in direct summer sun for a long length of time the liner will get warm to the touch. However, from a convection heat source standpoint, such as a transmission tunnel, it barely warms up. I'd say from personal experience that it works better as a deflector than an absorber.
Girls like STROKIN too!
http://www.jeepforum.com/forum/f153/1971-jeepster-commando-1380633/
Tinga is offline
post #3038 of 13379 Old 04-16-2011, 10:15 AM
mike_breaker_5
all i have to say is !! that gif is perfect. i am off to use it elsewhere in the forum.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #3039 of 13379 Old 04-16-2011, 12:11 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Connect with us on:
post #3040 of 13379 Old 04-16-2011, 12:17 PM
mike_breaker_5
are you trying to find the bottom of the tequila bottle again? lol awesome work on the gif though
post #3041 of 13379 Old 04-16-2011, 12:26 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
nope just the worm
thanks
by the way for anyone curious, the animation was done in Photoshop CS5 using the new Puppet Warp feature
Connect with us on:
post #3042 of 13379 Old 04-16-2011, 12:55 PM
npsrubicon
I'm sure that somewhere in the last 3000+ posts these questions have been answered, but I don't really want to read back through them. Hope you don't mind me being redundant with a couple questions so I make sure I get the right amounts.
1. I assume the 1 gallon bedliner kit is enought for doing the interior of my TJ, correct??
2. Any additional products recommended with this kit? extra brushes, scrub pads, rollers, solvents, etc.
3. 1 quart of chassis saver enough for the frame of a TJ?
4. I was thinking about using something like this inside my front flares and possibly on the underside of the tub. Would you have a product for these applications??
5. What kind of shelf life do these products have? I'll be using the Chassis Saver soon, but might not get around to lining the tub for about a year.
Thanks for your time.
npsrubicon is offline
post #3043 of 13379 Old 04-16-2011, 05:15 PM
KMD
1976 CJ7
Started prepping the Cj7 For Monsterliner.
These little things are a life saver. 2" roloc 36 and 60 grit flap wheels from Roark supply another JF supporter.
Hope to finish it next weekend.
KMD is offline
post #3044 of 13379 Old 04-16-2011, 05:40 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
1- std wrangler tub uses 1 gal kit
2- 1 quart MEK or Acetone (MEK not available in California), maybe some extra scuff pads or 80 grit sandpaper, could buy an extra roller refil when getting the kit
3-Yes
4- Under the tub is good, what are the flares made of. If plastic you need to prep correctly. See download document at www.monstaliner.com on plastic prep
5- Monstaliner is good if unopened for at least 1 year. I have material that is over 3 yrs old and it's fine
Connect with us on:
post #3045 of 13379 Old 04-16-2011, 05:42 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Great pics! Yes Tom from Roark Supply is a good man. I will invite him over here to tell you about what he has, excellent prices on quality stuff!
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
