Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 201 - JeepForum.com
 29Likes
post #3001 of 13469 Old 04-10-2011, 09:32 PM
Deacon
Shining Adonis
Deacon's Avatar
Originally Posted by ajf1994
Intense Blue
PB3- Factory paint code for intense blue pearlcoat (Or VB3???)
DT-8987 Factory paint desigation code
5357- PPG formula number
Nice! Thanks!
Deacon is offline
post #3002 of 13469 Old 04-10-2011, 09:48 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by mike_breaker_5 View Post
from my experience with monsta, i would not want to do the liner indoors anyway, unless you have a separate garage with no ignition sources or great ventilation available.
Mike please allow me to correct and elaborate on this.
Regarding flammability: Monstaliner has a flash point over 100 Deg F which means it is no more dangerous to work with than an oil base
enamel in a regular paint can (something containing mineral spirits)
Monstaliner will not cause a flash fire. It will burn if you put a flame directly to the liquid but the solvent fumes will not flash from the air.
Odor is a different story. It smells a bit but not nearly as bad as automotive paint or most of the competitive DIY liners out there.
I strongly advise working inside a garage with the garage door wide open. This should be good enough ventilation.
Reason for this is that when working outside, sun and air movement will force Monstaliner to tack up faster which will make rolling more difficult.
Also you must not coat hot surfaces sitting in the sun. Working outside you also risk getting bugs and dirt blown into the wet coating.
The MEK used for wiping is highly flammable and should not be used in your garage. Do your scuffing and roll vehicle outside to
work with MEK then bring it back inside in 30 minutes or as soon as MEK has evaporated.
Also, never leave your MEK rags balled up in a corner. Hang them to dry outside.
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #3003 of 13469 Old 04-10-2011, 11:58 PM
mike_breaker_5
sorry, i should have been more specific. this is the part i was referring to with flammability. thanks for the clarification though.
my project is pretty unique as far as the condition of the tub being coated is concerned. i forget that 99.99% of the people are coating their tubs while still attached to the jeep, and are rolling it on instead of spraying.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #3004 of 13469 Old 04-11-2011, 10:43 AM
tractor1
1979 CJ5
OVER TWO HUNDRED PAGES and THREE THOUSAND POST!
tractor1 is offline
post #3005 of 13469 Old 04-11-2011, 11:13 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Pretty impressive but intimidating at the same time for someone new coming along and not knowing where to start reading.
Is there a way to create a table of contents to a thread with links to specific posts?
Connect with us on:
post #3006 of 13469 Old 04-11-2011, 04:09 PM
RedlegWJ
Are you referring to Chassis Saver or Monstaliner?
Oops, I guess my question would be for both. I've got black and silver CS, so Idon't see uses it all up right away, plus a bunch of small projects for the liner, bumpers, suspension etc., so the liner wouldn't be used up at once either. May order a color later anyway, but wouldn't be til summer sometime.
RedlegWJ is offline
post #3007 of 13469 Old 04-11-2011, 04:10 PM
RedlegWJ
How much is company stock going for right now?
RedlegWJ is offline
post #3008 of 13469 Old 04-11-2011, 04:25 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Michigan has a hotbed of Chassis Saver dealers (auto paint stores).
Just go find some S8 Reducer
Put your zip in here and make some calls to make sure they have it
http://www.magnetpaints.com/distributors.asp
Connect with us on:
post #3009 of 13469 Old 04-13-2011, 07:39 AM
RedlegWJ
That helps, thanks.
RedlegWJ is offline
post #3010 of 13469 Old 04-13-2011, 07:52 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Monstaliner White
Is anyone following this thread
looking for Monstaliner in
WHITE?
Connect with us on:
post #3011 of 13469 Old 04-13-2011, 08:33 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by badmood View Post
Hey magnetman, in anticipation of the kits getting here, one thing I realized would be nice would be to do the inside of the rear wheel wells (to protect the painted metal there from the tires and the rocks and such kicked up there. Would I need to do anything special to make that work? Should I thin and brush like in those picture sequence you just posted? Or just scuff paint and try to roll it on just like everywhere else?
If the surface is just painted metal inside the wells you want to make sure it's clean from grease, oil, road tar etc and then you need to scuff sand just like it was in the tub. (Degreaser, solvent wipe, scuff sand and solvent again)
Did you order from us shipping to U.K. or you waiting for a color?
Connect with us on:
post #3012 of 13469 Old 04-14-2011, 07:57 AM
nnosu
1980 CJ5
I am looking for white for my 1980 CJ5.
nnosu is offline
post #3013 of 13469 Old 04-14-2011, 08:49 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Is the surface you will be coating white right now (old oem paint?)
Connect with us on:
post #3014 of 13469 Old 04-14-2011, 09:22 AM
nnosu
1980 CJ5
Yes it is the original white paint.
nnosu is offline
post #3015 of 13469 Old 04-14-2011, 09:59 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
OK, thanks!
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
