Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 200 - JeepForum.com
 43Likes
post #2986 of 13541 Old 04-10-2011, 01:19 PM
Hylke
Hylke's Avatar
1978 CJ7
I was just reading this: http://www.monstaliner.com/monstalin...s_techdata.htm
It's at the bottom of the screen, "1 Gallon for a 2 door Wrangler Jeep tub or 6 foot pickup bed."
Eric, I yet have to test the paint that's currently in my tub with mineral spirits. I did however had the chance to try it with a rag with thinner.
How would you say thinner is compared to mineral spirits? As you said I used some thinner and rubbed the paint. That became dull but the rag did not get really black, just slighty gray. Mineral spirits should be less aggressive then, right?
And I don't mind rubbing that old layer of paint with thinner, it's going to get covered up anyway...
Hylke is offline
post #2987 of 13541 Old 04-10-2011, 01:25 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
All "Paint Thinner" sold in stores is mineral spirits. You should have no issues.
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #2988 of 13541 Old 04-10-2011, 02:25 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Stock Jeep Colors
Anyone know of an online listing of past interior/exterior Jeep colors offered by Chrysler
Connect with us on:
post #2989 of 13541 Old 04-10-2011, 03:18 PM
Deacon
Shining Adonis
Deacon's Avatar
I'd like to know that myself. A buddy is looking for the paint code for the TJ "Intense Blue" to redo his whole CJ.
Deacon is offline
post #2990 of 13541 Old 04-10-2011, 03:27 PM
mike_breaker_5
http://moparattitude.com/cgi-bin/col...l=Jeep&rows=50
this is the best i could find. it jumps from 91 all the way to 06, and i don't see an intense blue . hope it helps.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #2991 of 13541 Old 04-10-2011, 03:32 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
What year is friends TJ?
Sorry I misread that. Do you know what year the code is from he is looking for?
Connect with us on:
post #2992 of 13541 Old 04-10-2011, 06:17 PM
ajf1994
Intense Blue
PB3- Factory paint code for intense blue pearlcoat (Or VB3???)
DT-8987 Factory paint desigation code
5357- PPG formula number
-SupportOurTroops-
High School Jeepers #361
Parrothead Jeep Club #46
37,xxx Miles
Originally Posted by XJ-Tim View Post
my welds look like popcorn with sprinkles.
Originally Posted by Benjamin Franklin
Beer is proof that God loves us and wants us to be happy.
ajf1994 is offline
post #2993 of 13541 Old 04-10-2011, 07:39 PM
ajf1994
Originally Posted by magnetman View Post
Not sure about that. Smooth with no texture is likely to resist algae and barnicles better.
Why don't I send you some coated panels with a hole in them to hang in the water.
That would work well, the only issue is whether or not the material it is on will dissolve? I guess it doesn't matter much. You should still have my information from an order/previous request, if not PM me.
On another note, has anyone removed the TJ roll bar padding and Monstalined the cage? I searched for pictures and found none... I might end up ordering an extra quart for that; I plan on doing my tub next week.
-SupportOurTroops-
37,xxx Miles
ajf1994 is offline
post #2994 of 13541 Old 04-10-2011, 07:45 PM
TheDirtyGeneral
No one has MONSTA'ed the roll bar from what I know, but I have seen people raptor line it or have it line-xed no reason you wouldnt be able to unbolt your cage from the Heep and do it.
Chris. I miss driving my Jeep. Can't wait to get into another one.
TheDirtyGeneral is offline
post #2995 of 13541 Old 04-10-2011, 07:49 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
For this purpose we would use metal panels either steel or aluminum.
Please Confirm: This is fresh water you are talking about testing in???
If you decide to do the roll bar get the small roller kit we have now. Comes with 2" wide rollers and foam sponge block, very handy for a small price
Connect with us on:
post #2996 of 13541 Old 04-10-2011, 07:56 PM
mike_breaker_5
why unbolt it? if it's not rusted around the base or on the underside i would just liner over the whole mess. tape the torx slots of course, but imo i see no need to go through the extra hassle. i plan to just chassis saver the cage and put the pads back on, but that's just me.
post #2997 of 13541 Old 04-10-2011, 08:04 PM
ajf1994
Yes, it is freshwater. Thanks for the advice on the small kit, I will look into it when I make up my mind.
-SupportOurTroops-
37,xxx Miles
ajf1994 is offline
post #2998 of 13541 Old 04-10-2011, 08:12 PM
TheDirtyGeneral
I figure it would be easier to get at and store while its being rolled, and would create space for you to do the inside of your tub too. I wouldn't want to stand on my wet monstaliner in the tub to get to the roll bars.... just saying
post #2999 of 13541 Old 04-10-2011, 08:28 PM
mike_breaker_5
do the cage first problem solved
from my experience with monsta, i would not want to do the liner indoors anyway, unless you have a separate garage with no ignition sources or great ventilation available.
post #3000 of 13541 Old 04-10-2011, 09:24 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by badmood View Post
Sorry if this has been asked already, what about adherence to fiberglas? specifically gelcoat and unfinished sides... thanks
Previously painted fiberglass where coating is in good condition needs just scuff sanding same as if it was painted metal
Uncoated/new fiberglass must be primed using 2K epoxy primer before installing Monstaliner
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
