Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 191 - JeepForum.com
 29Likes
post #2851 of 13454 Old 03-29-2011, 01:18 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by xantasm View Post
Last June, I moved and didnt get to it last Fall and then got lazy
I can buy one if that was too long ago and they arent really spendy. You will just have to PM me details on how to order one.
Had nothing to do with the sticker.
Your rollers were from a faulty batch we had from some drug cartel factory in Mexico. Problem has been resolved since then. Sorry about the foam pieces
Manufacturers of CHASSIS SAVER™ Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #2852 of 13454 Old 03-29-2011, 01:26 PM
xantasm
Cool, it wasnt bad just annoying. Great to know you got it swapped out. I have already had a few people ask what brand of bedliner and I was more than happy to tell them Monstaliner
xantasm is offline
post #2853 of 13454 Old 03-29-2011, 02:39 PM
Deacon
Shining Adonis
Deacon's Avatar
I bought mine in March of last year. It'll probably be another month or two till I'll actually be able to apply it (long story). Will I have the same kind of problem with my rollers? I bought a 1 gallon kit for the TJ and a 2 gallon kit for my F250 bed.
Deacon is offline
post #2854 of 13454 Old 03-29-2011, 02:43 PM
GRUNT
Magnet Man,
How thick can you apply it? Does it soften under extreme heat? I live in arizona and often take trips out into the desert for days at a time. Things get quite hot in the summer with outside temps getting up around 110. I was looking for something that can be thicker than just paint as to help shield some of the heat from the drivetrain under the tub. In May I start my build-thread article for a website but I am looking for a liner for the project.
Thanks,
Grunt
-Allen
"No, but I did stay at a Holiday Inn Express..."
GRUNT is offline
post #2855 of 13454 Old 03-29-2011, 04:17 PM
The_Blacksmith
1993 XJ Cherokee
that looks amazing. I wont ever consider another liner again
Thanks Chris!
The_Blacksmith is offline
post #2856 of 13454 Old 03-29-2011, 04:24 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
it's possible man. I'm trying to forget about the bad rollers
PM me a shipping address, you're the proud recipient of 5 new problem free blue foam rollers
Connect with us on:
post #2857 of 13454 Old 03-29-2011, 04:32 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by GRUNT View Post
Magnet Man,
Thanks,
Grunt
Up to 1" thick but that would take 25 gallons for a jeep tub and cost just under $3000
sorry, doing tequilla shots again
2 coats is all you need, that's about thickness of a dime. you can do more if you want
we tested a cured panel with a bernzomatic torch on back side for 2 hours with surface temp of Monstaliner maintained between 185 - 200 deg F
coating softens slightly and returns to 100% normal on cooling
../..______..\..
....\______/....
...._/......\_....
Connect with us on:
post #2858 of 13454 Old 03-29-2011, 04:37 PM
LuckRider
LuckRider's Avatar
Magnet, about how hot did you have the torch on the backside? I can't remember, but I think they are about 600 degrees which is very hot for something that is being applied to automotive metal.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #2859 of 13454 Old 03-29-2011, 04:42 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
we propped up panel and directed torch to opposite side that Monstaliner was coated on (the metal side). we then shot an IR temp guage at the surface of coating and adjusted distance/position of torch until we had steady 185, 190, 200 readings
what is 600 degrees?
Connect with us on:
post #2860 of 13454 Old 03-29-2011, 04:46 PM
LuckRider
LuckRider's Avatar
I was wondering what the temp of the flame was. I thought they ran somewhere around 600 at a certain setting.
Support Our Troops!
JFI Member #7:
post #2861 of 13454 Old 03-29-2011, 04:51 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
that could be but no sense in cooking the coating if not a realistic test
we just pulled back the torch and/or lowered flame size to get temp stable
I got it on video. it's boring
Connect with us on:
post #2862 of 13454 Old 03-29-2011, 04:56 PM
LuckRider
LuckRider's Avatar
Yeah, it made more sense to me after you posted the part about stabilizing temps.
Support Our Troops!
JFI Member #7:
post #2863 of 13454 Old 03-30-2011, 12:42 AM
Deacon
Shining Adonis
Deacon's Avatar
Man, I can't seem to find it, but on the subject of gloss black Chassis Saver, I could've sworn I recently saw you mention that if the area covered in it will see sun, then you can put some sort of top coat over it, either within 24 hours or only after 24 hours, something along those lines. I don't know if it was rattle can clear or rattle can gloss black or what.
Any specific recommendations for that? I'm probably going to use it to coat my beefed up rear crossmember (no rear bumper), and I'd like to keep it looking sharp. I realize that unlike Monstaliner, the Chassis Saver is not UV permanent...
Deacon is offline
post #2864 of 13454 Old 03-30-2011, 12:54 AM
LuckRider
LuckRider's Avatar
Deacon, you are right, it is not UV stable. Here you go:
Dry Time @75°F . . Airdrytotouch:2to3hours–Tackfree:3to5hours–Marfree :
6to8hours–Fullcure:48to72hours
RecoatTime ..... 3 hrs minimum / 24 hrs maximum. For films cured over 24 hours,
scuff sanding is required using 400 grit sandpaper to dull gloss.
Support Our Troops!
JFI Member #7:
post #2865 of 13454 Old 03-30-2011, 01:09 AM
Deacon
Shining Adonis
Deacon's Avatar
Good info, thanks for sharing that. It sounds like you want to top coat it less than 24 hours after the final Chassis Saver coat goes on. Now the question is: with what?
Deacon is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
