Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 187 - JeepForum.com
 36Likes
post #2791 of 13514 Old 03-20-2011, 05:33 PM
TimV
Really liking how this stuff looks. I plan to do my Jeep tub and Metalcloak fenders with bedliner this summer, and have a few questions for you.
1-About how much would I need to do the tub and all 4 fenders/flares? Would the 2 gallon kit be sufficient?
2-Would I need to apply two coats, or would a single coat be sufficient for low traffic areas like the fenders? Obviously the floor of the tub would be getting two coats for sure.
3-Your directions mention that you can apply over light rust. Will this product keep the rust from spreading, or will the rust travel under the liner. I have some light rusting on my fenders, and would like to properly take care of it so it doesn't resurface.
4-My fenders have been spraypainted. Will I have to remove all of that before using your product, or can I apply over it? After removing all the flaking and loose paint of course.
5-Can I use a different roller to achieve a smoother finish? I would like a slightly smooth finish on the fenders if it is possible. If not, I am sure I will be ok with it anyway, as it does not look too rough to the touch.
Thanks for the answers! You may be recieving an order from me in the coming months. That is of course unless I win your contest tommorow.
It's not an addiction. It's a way of life.
TimV is offline
post #2792 of 13514 Old 03-20-2011, 05:54 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by ncreptile View Post
I am seriously having a hard time with this. Brand new red sports carabeu seats with red monsta liner... Or a new Glock 23, keep my current black seats and black monsta liner.
GOSH THIS IS TOUGH Someone help me make up my mind.
Hey ncreptile I fixed your avatar!
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #2793 of 13514 Old 03-20-2011, 06:08 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
1) Is that fenders and flares or fender flares?
1 Gal kit does the tub, just fender flares needs 1 quart (quart goes 15 sq ft for 2 coats)
2) 2 coats or it will not look the best it can and you not be happy
3) just wire brush and spot prime the rust first with silver Chassis Saver to be sure
4) Confirm this: Were your fender flares originally raw black plastic and they were spray painted or were they factory fiberglass with paint from the factory and then they got spray painted?
5) You can control the texture with application technique and adding (or even not adding) a small amount of reducer. I'll help you when you are ready.
Connect with us on:
post #2794 of 13514 Old 03-20-2011, 06:17 PM
ncreptile
Dont forget the horns and him eating poor farmers and children
Oh and the lazer beams from his eyes, I heard he can torture people just by looking at them.
I love you CM <3
What goes around comes around, thats why my weapon of choice is a boomrang.
ncreptile is offline
post #2795 of 13514 Old 03-20-2011, 06:20 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I need more time for that but if I do it you switch the photo?
Connect with us on:
post #2796 of 13514 Old 03-20-2011, 06:24 PM
TimV
I plan to do full front fenders and flares, as well as rear flares. Mine are not stock plastic. They are full steel replacement fenders. I figured one quart would probably be enough, but I will probably order two just to be sure.
TimV is offline
post #2797 of 13514 Old 03-20-2011, 06:28 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Double check all your square footage. With 1 gal kit + 2 extra quarts you're only about $20 away from a full 2 gal kit
Connect with us on:
post #2798 of 13514 Old 03-20-2011, 06:37 PM
TimV
I will just order the 2 gallon kit then. I can do my front bumper and winch plate with the extra while I am at it. I am sure I can find somewhere else to use it too.
Since you didn't get to it before, am I fine rolling over the spray paint on my steel fenders? Or should I strip that all off first? Thanks again!
TimV is offline
post #2799 of 13514 Old 03-20-2011, 08:08 PM
XJcruiser
Any word what our color choices will be yet? My paint is crap and I think Im going to coat my entire XJ. My MTR's throw rocks at the rockers all day. The sun ate my hood and roofs paint long ago. I just dont wanna do it all black. Thats the color it is now though. Would 2 gallons do the whole Jeep?
Friends dont let friends do DUBS.
XJcruiser is offline
post #2800 of 13514 Old 03-20-2011, 08:13 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Sorry, there's a slight risk that Monstaliner or any paint with a solvent stronger than mineral spirits may lift/wrinkle spray paint.
Your safest bet is to remove it. Was that spray paint applied direct to new metal fenders or was there a primer used?
Connect with us on:
post #2801 of 13514 Old 03-20-2011, 08:14 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I posted a short list of preliminary colors in this thread last Tuesday or Wed.
See if what you want is on that list.
Connect with us on:
post #2802 of 13514 Old 03-20-2011, 08:54 PM
TimV
I used Krylon bare metal primer, then Krylon semi-gloss black on top of that. Shouldn't be a problem to remove. It is already flaking now, so I think it should be pretty easy to take off.
TimV is offline
post #2803 of 13514 Old 03-20-2011, 09:05 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
When ready, see if it all dissolves if you rub into it with lacquer thinner on a rag
Connect with us on:
post #2804 of 13514 Old 03-20-2011, 11:23 PM
TheDirtyGeneral
soooo it's monday! who won the contest!?!?!?!?! lol
Chris. I miss driving my Jeep. Can't wait to get into another one.
TheDirtyGeneral is offline
post #2805 of 13514 Old 03-22-2011, 09:24 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Details on Next Monstaliner Giveaway on April 10th
NEXT MONSTALINER GIVEAWAY
Sunday April 10th will be the next giveaway.
We have 3 more commercials running before then.
I will begin posting daily stats this weekend so people can make more educated guesses.
I want to thank everyone for their participation!
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
