Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 153 - JeepForum.com
 25Likes
post #2281 of 13379 Old 11-12-2010, 12:32 AM
mike_breaker_5
Originally Posted by MarkF View Post
Just wait until the colors come out. I know a bunch of us are holding out for them including me.
i only bought a gallon kit of black just to get my frame and underbody coated so i could get them back together b4 winter. i fully plan on getting od green to second coat the interior and get 2 good coats on the exterior of my yj. i have a buddy from this forum that is also a member of p4x4 he says it's a whole diff world over there. (in a whisper voice) they can swear over there.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #2282 of 13379 Old 11-12-2010, 08:34 AM
DINOCAVE
formerly CPT Jeep
DINOCAVE's Avatar
Originally Posted by magnetman View Post
What did those 2 quarts cost you?
I think about 50 bucks. But they will last me a long time and cover many projects.
TIP: Go to Lowe's and get some of those little plastic paint can lips that snap onto an open can. It really helps to keep things neat. You also don't get the primer dripped over the directions, which helps the next time you want to go back and use it again.
DINOCAVE is offline
post #2283 of 13379 Old 11-12-2010, 02:13 PM
jgrantmarshall
Looking to line 2 YJ tubs at the same time & share expenses. What do you guys recommend? I'm thinking 1 kit and buy extra rollers, etc. locally. How much extra Monstaliner should we pick up?
Or do you think we should just buy 2 kits?
jgrantmarshall is offline
post #2284 of 13379 Old 11-12-2010, 02:22 PM
FamillyCJ7
1983 CJ7
There is a post of how the Monstaliner comes out a little ways back using different rollers. The roller that comes with the kit works the best IMO. I'd stick with what works and not experiment or cut corners.
'83 CJ7 258I6 4-Speed Father Daughter Project - Using Monstaliner/Chassis Saver and Products from CrabTreeTool
NorthEastFL4x4.com - Local 4x4 Enthusiasts website, join up now!
FamillyCJ7 is offline
post #2285 of 13379 Old 11-12-2010, 03:09 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Do the math. Try a 2 gallon kit with some extra rollers and an extra roller handle.
2 x 1 gl kit = $268
1 x 2 gl kit + 3 rollers & extra handle = $251.86 (6 rollers total)
Manufacturers of CHASSIS SAVER™ Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #2286 of 13379 Old 11-13-2010, 11:54 AM
slafferty
how long does it take to get the smell out? Mines been airing out since sunday.
'00 TJ, 4.0, nv3550 spd, E-lockers Front and Rear, 4.88 gears. Homebuilt Bumpers/ tube doors.. Homebuilt Long Arm in the making... 35 inch MT-R's ordered
Originally Posted by RUBtjICON View Post
If you arent scratching it, you arent trying hard enough :tea:
MY BUILD THREAD
slafferty is offline
post #2287 of 13379 Old 11-13-2010, 01:21 PM
mike_breaker_5
mine spent about 2-3 weeks outside after coating it and after i brought it back inside i couldn't notice any smell unless i got right up close to the coating. it has been in my basement for about 2 weeks now and still hasn't accumulated any smell at all. maybe just leave it out in the elements for a couple weeks.
post #2288 of 13379 Old 11-13-2010, 03:42 PM
XJelvis
I had mine completely airing out for a month and then another month with doors off or windows open most of the time. You still smell the Monstaliner whenever you hop in. It's not as strong as the first day, but the scent is there.
94 YJ, 2.5L, 5sp Sold.
97 TJ, 4.0, 5sp Sold.
01 XJ, 4.0, Auto
XJelvis is offline
post #2289 of 13379 Old 11-13-2010, 03:48 PM
sandandson
I aired mine out for almost a week. And by airing it out, I mean I left everything pulled out of the way with zipties, no seats; just straight up pushed it outside for a good five days.
Even after I put the seats back in and let it air out for a few more days, it still had a smell for a few weeks. It's gone now, and I painted back this summer.
sandandson is offline
post #2290 of 13379 Old 11-13-2010, 06:03 PM
jgrantmarshall
2 x 1 gl kit = $268
Thanks for pointing me in the right direction, Guys! Placed my order... hopefully will have good weather for Thanksgiving!
post #2291 of 13379 Old 11-13-2010, 08:20 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
The solvent in Monstaliner evaporates very slowly compared to typical solvents used in automotive paints and other paint type bedliners.
The main reason we chose to use this solvent is because its flash point is high meaning that the flammability is very low compared
to other solvents. This is a safety feature of the product and it is much less dangerous to use considering the fact that people are using it in garages.
This slow evaporation rate is the main reason why the odor tends to linger for a longer period of time.
I need some feedback from you guys.
1) How much time did you wait between coats?
2) If you can recall, What was the approximate temperature on the day you installed the coating?
Connect with us on:
post #2292 of 13379 Old 11-13-2010, 09:54 PM
mike_breaker_5
as you know mine was sprayed on so i imagine my coats were slightly to moderately thinner than being rolled on. the air temp was about 65-70 very low humidity. i applied the coats about 3-4 hours apart, as soon as i could touch the coating and it didn't wanna stay attached to me as a permanent reminder of the color of the under side of my jeep. but like in my application it was completely open air, and completely exposed to all moving air.
i had it setting on block when it was painted but this is exactly where it was painted and how it was sitting. also if you remember magnet i did have to add alot of M.E.K. to the liner to get it to spray through my crappy coating gun, that could have had a huge impact on the speed of evaporation of the "factory" solvents originally in there. that's a good possibility why some of us have had faster "no smell" coatings than others. we added solvents for one reason or another in turn altering the end result slightly.
post #2293 of 13379 Old 11-13-2010, 11:13 PM
Tinga
I waited probably 45 minutes or so from the first coat to the second coat
HOT! It was roughly 89-90* outside with a relative humidity of about 75%
Girls like STROKIN too!
http://www.jeepforum.com/forum/f153/1971-jeepster-commando-1380633/
Tinga is offline
post #2294 of 13379 Old 11-14-2010, 10:13 AM
Made
1st and 2nd: 12 hours
2nd and 3rd: 6 hours
Approximately 75-80°
Made is offline
post #2295 of 13379 Old 11-14-2010, 08:08 PM
southernss
just ordered the 2 gallon kit to do my truck bed. i have a short bed pick up so if there is enough left over i will be doing the bed of the jeep.
southernss is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
