Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 149 - JeepForum.com
 32Likes
post #2221 of 13493 Old 11-02-2010, 10:51 PM
Tinga
Yeah.. You can solve any problem with a cupcake.. :P
Girls like STROKIN too!
http://www.jeepforum.com/forum/f153/1971-jeepster-commando-1380633/
Tinga is offline
post #2222 of 13493 Old 11-02-2010, 10:59 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I wish I woulda had some cupcakes when I was ripping my hair out over making Monstaliner colors >:-o(
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #2223 of 13493 Old 11-02-2010, 11:31 PM
mike_breaker_5
another great idea for partial kits would be a measuring device of some kind that has graduations to proportion liner to catalyst from the gallon kits. maybe as simple as providing common measurement sizes in your .pdf guide. starting as small as a pint or even a few ounces of raw unmixed liner to ??? catalyst. that way you could still purchase a gallon and make it last for multiple projects. i will be doing my fenders, hood, grille, dash panel, seat frames, and any other piece of steel i can think of. however i don't plan on doing them all at the same time. with an estimate of how much coverage you get per volume joined with the mixing chart someone doing smaller projects from the gallon size would be as easy as a little measuring. you could even offer the gallon kit to come with 4 of the quart sized catalyst pouches.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #2224 of 13493 Old 11-02-2010, 11:45 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Now you're brainstorming. I like it ALOT! If you keep coming up with ideas like this I may have to hire you as a consultant
The measuring cups sold by auto paint dealers would work. They come in different sizes. I'm looking into this. Thanks!
Connect with us on:
post #2225 of 13493 Old 11-02-2010, 11:51 PM
mike_breaker_5
here's where i need a cardboard sign that reads
"will work for MONSTALINER!" lol
post #2226 of 13493 Old 11-02-2010, 11:57 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by CPT Jeep View Post
Can you apply this stuff directly onto powdercoat? I assume you would first have to scuff it up with the red scuff pad you sent with the kit. I ask because I plan to buy a front bumper and rocker guards round about springtime. I can use my last 2 quarts on those parts as well as my already installed rear bumper. Hmmm, I need to do my grill too so I'll have to supplement what I already have. We'll talk in the spring.
Yes, you should have no problem applying Monstaliner over powdercoat. You will want to scuff it well first and you may even want to apply that epoxy primer you have just to ensure the best bond. I would probably scuff a little better than that red pad will do. Maybe 120 or 180 grit. Sandpaper will just give a better scratching to surfaces. Maybe test small area with chosen grit first.
Connect with us on:
post #2227 of 13493 Old 11-03-2010, 12:05 AM
LuckRider
LuckRider's Avatar
What about a kit for when colors come out that includes a one gallon color kit with 1 or two quarts of black for trim. So basically a package deal for the outside. Color for the body and all of that, and say you have tube fenders, black for the tubes of the fenders.... Like this:
See how there is black for the edges of the flares and the outer most part of the rocker guards?
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #2228 of 13493 Old 11-03-2010, 12:14 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
that would make a good bumper sticker
Connect with us on:
post #2229 of 13493 Old 11-03-2010, 12:17 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
That's a great idea too. Need to get colors on the market and we'll see what people want to buy. Maybe just offer a discount on black quarts if ordered at same time with color kit.
Connect with us on:
post #2230 of 13493 Old 11-03-2010, 12:22 AM
mike_breaker_5
why are you up and on JF at 2:30am? i'm slaving away at work, what's your excuse? lol
post #2231 of 13493 Old 11-03-2010, 01:17 AM
LuckRider
LuckRider's Avatar
Sounds like me I am set for now though... I still have that Chassis Saver in the garage. I was hoping to get that done this summer in prep for the winter, but that obviously didn't work out.
Sounds like a good idea.
He seems to be on at the weirdest times. I remember him saying something about working from home a lot, and he only works with a desktop which means he is not in the comfort of his bed like I am.
Support Our Troops!
JFI Member #7:
post #2232 of 13493 Old 11-03-2010, 03:27 AM
FamillyCJ7
1983 CJ7
The parts I need to finish fixing the frame should be shipping this week then I'll be coating the frame with Chassis Saver finally! Any idea when the Red Monstaliner will be ready. I'm going to start body work soon and already have some stuff that could be coated.
'83 CJ7 258I6 4-Speed Father Daughter Project - Using Monstaliner/Chassis Saver and Products from CrabTreeTool
NorthEastFL4x4.com - Local 4x4 Enthusiasts website, join up now!
FamillyCJ7 is offline
post #2233 of 13493 Old 11-03-2010, 06:51 AM
skey
LuckRider or Magnetman,
Any issues ya'll can think of for applying Monsta over a chrome bumper? I have already put a palm sander to it with 80 grit and wiped clean with MEK. Do I need to put chassis saver on it for a primer or just go with the sanding? Thanks for all your input...Scott
skey is offline
post #2234 of 13493 Old 11-03-2010, 06:57 AM
FamillyCJ7
1983 CJ7
You could get Metal Ready or any other metal etcher to help the paint stick. When I painted my headlight rings and rock guards that were chrome I sanded with 80 grit and then soaked them in Metal Ready for 24hrs. The Chassis Saver stuck great.
post #2235 of 13493 Old 11-03-2010, 09:18 AM
LuckRider
LuckRider's Avatar
Magnet told me when I asked him the question that a scuff to 80 would suffice, but I thought about sandblasting. I ended up skipping all of that, but you could also use a 2k primer on it to ensure good adhesion. I have heard of some issues with bubbling from basic rattle can primers in this thread.
Support Our Troops!
JFI Member #7:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
