Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 116 - JeepForum.com
 29Likes
post #1726 of 13469 Old 06-23-2010, 09:48 PM
Jay12
Ok, thanks. It's been mid 90s this week here and I plan to put it on next Saturday. If it's too hot I'll roll it on outside and then push the Jeep into the garage if I can do that without messing the liner up lol.
Jay12 is offline
post #1727 of 13469 Old 06-24-2010, 12:21 AM
Deacon
Shining Adonis
Deacon's Avatar
It's summer in South Texas. It's never going to be not sunny and humid.
Deacon is offline
post #1728 of 13469 Old 06-24-2010, 12:25 AM
LuckRider
LuckRider's Avatar
You guys really get Humidity? I remember my Uncle was complaining about the humidity here the last time he visited (a few years ago). I don't know if he was in SA, Houston, or El Paso at the time though.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #1729 of 13469 Old 06-24-2010, 08:18 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Please stay out of the sun if at all possible.
2 things will cause the coating to dry too fast and make rolling difficult.
Excessive heat and air movement which forces the solvent to evaporate and will make it tack up too quickly.
Do your surface prep the day or evening before you plan to roll.
Try to get up at sunrise and roll before it gets too hot outside.
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #1730 of 13469 Old 06-24-2010, 08:37 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Force Drying
Another point of info on heat.
It is not necessary to try and force dry by putting vehicle back in sun after rolling.
The heat can also cause solvent to get trapped in the coating which will cause delayed through dry and also can cause solvent odors to linger in a closed up vehicle longer than necessary
Connect with us on:
post #1731 of 13469 Old 06-24-2010, 11:14 AM
LuckRider
LuckRider's Avatar
Sounds like the skin over effect that you get in the can.
Also MagnetMan, I am going to help you out with that profile a little.
Transmission: Auto is the 42RLE 4-Speed Manual is the NSG370 6-Speed
Rear Axle: Next Generation Dana 44 (with electric locker if it is a Rubicon).
Front Axle: 2wd: N/A (shame on you :thumbsdown 4wd Non-Rubi: Next Gen Dana 30 Rubicon: Dana 44 with Electric Locker and sway bar disconnect.
Suspension: Stock
Transfer Case: NP231, Rubi: NV241
Tires and wheel you would have to take a look for.
Future Mods: Monstaliner
Support Our Troops!
JFI Member #7:
post #1732 of 13469 Old 06-24-2010, 11:42 AM
Deacon
Shining Adonis
Deacon's Avatar
You don't need to put stuff like "Next generation" or whatever. If it's a JK it's a JK30 and JK44. We already know that. Just put "Dana 30" and "Dana 44". If you haven't touched the suspension, leave it blank. "Stock" isn't a valid value.
PS It'd be an NV231, actually, though NP231 would be close enough that most wouldn't know the difference.
Deacon is offline
post #1733 of 13469 Old 06-24-2010, 11:49 AM
LuckRider
LuckRider's Avatar
They stopped using New Process? JK tech doesn't have a stock spec thread like TJ tech so I was kind of going with the flow there.
Support Our Troops!
JFI Member #7:
post #1734 of 13469 Old 06-24-2010, 12:18 PM
Deacon
Shining Adonis
Deacon's Avatar
See here for the convoluted story: New Venture Gear - Wikipedia, the free encyclopedia
Deacon is offline
post #1735 of 13469 Old 06-24-2010, 02:03 PM
Tinga
Starting our tub lining today. Got everything out and vacuumed.
Starting on the scrubbing and scuffing next.
I really didn't think it would be that DIRTY. especially around the cup holder area.
I think the PO was a soda drinker cause boy is it sticky!
Girls like STROKIN too!
http://www.jeepforum.com/forum/f153/1971-jeepster-commando-1380633/
Tinga is offline
post #1736 of 13469 Old 06-24-2010, 02:13 PM
LuckRider
LuckRider's Avatar
I know what you are saying. Mine looked like someone spilled soda, tar, and coffee in my Jeep (by tar I mean cigarette tar). I had to pressure wash the Jeep and hand wash it before I could even start sanding.
Support Our Troops!
JFI Member #7:
post #1737 of 13469 Old 06-24-2010, 02:27 PM
Tinga
What precautions did you take for the electronics and wiring on the floor when you pressure washed it?
Tinga is offline
post #1738 of 13469 Old 06-24-2010, 02:48 PM
LuckRider
LuckRider's Avatar
I pulled the things that hold them to the floor and just hung them over the steering wheel.
Support Our Troops!
JFI Member #7:
post #1739 of 13469 Old 06-25-2010, 07:27 AM
NxtGenCowboy
1989 XJ Cherokee
Thanks for the Fast Shipping!!
This weekends project!!!
NxtGenCowboy is offline
post #1740 of 13469 Old 06-25-2010, 08:12 AM
monkeyhouse
Originally Posted by magnetman View Post
I got it, I thought you were referring to a particular brand of accessories. I like that stuff. Gets expensive I see. Gotta sell more Monstaliner now
I've seen that stuff before and like it. My Wrangler is white and as long as I have enough, I was planning on using Monstaliner on those locations.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
