The Alloy USA® JK H/D ball joints have been designed with a low profile (grease) zerk fitting for regular maintenance, a feature not offered on factory replacement parts. Inner insert has been replaced with a high strength steel socket. (Replaces factory plastic nylon insert). This steel insert greatly increases ball joint strength and durability. This is a "Must" for lifted vehicles running any tire larger than stock applications. Ball and socket are assembled using an exclusive threaded preload system that insure precise tolerances for prolonged joint life and precise steering. Ball & shaft are constructed from industry leading SAE 4140 Chromoly steel. combined with steel insert insures that these ball joints are an industry leader in durability and strength.
Looking at these and the synergy ones. What is your warranty on them? I hear very good reviews on the synergy, tell me why I should buy your product. thanks for the help!
The Alloy USA Ball Joints come with a Three Year Warranty. These Ball Joints are considerably stronger than the OE style. They replace the inner nylon insert with a steel insert and use a 4140 chromoly ball and shaft.
This Ball Joint will perform flawlessly on your JK Wrangler or 99-04 Grand Cherokee in any driving condition.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
