Great Deals on Zone Offroad Lift kits Now at JEEPHUT - JeepForum.com
post #1 of 3 Old 09-11-2013, 09:55 PM Thread Starter
JeepHut
That's right we picked up this line of lift kits by request from our customers. PM us or give us a call on some killer deals on Zone Offroad products at JeepHut
Let us become your number one source for offroad products for your Jeep.
706-692-5488
JeepHut is offline
post #2 of 3 Old 09-15-2013, 08:23 AM Thread Starter
JeepHut
Thank you for the orders.
706-692-5488
JeepHut is offline
post #3 of 3 Old 09-18-2013, 06:06 PM Thread Starter
JeepHut
4.5" Jeep Comanche MJ Suspension Lift Kit
The Zone Offroad 4.5" 86-92 Jeep Comanche MJ lift includes new front coil springs capable of handling anything. Since we design our coil springs for off road use, there is only a 2" bump stop extension supplied to drastically increase wheel travel. Our coils can be smashed to the bottom and will always come back! No, that doesn't mean they are stiff. The key is using the correct size wire with the correct spring rate to offer the perfect ride and still hold up over time. Unlike many inexpensive kits on the market, our springs are made in the USA.
This system also comes with extended sway bar links to maintain the sway bar angle and control body roll. Brake line relocation brackets make the job easy to do at home. New heavy duty lower control arms are supplied to correct alignment as well as axle location. The lower control arms are made from 1-3/4" OD x 1/4" thick wall D.O.M. tubing. The greasable urethane ends are dual fluted to allow for proper lubrication and long term performance.
The rear is lifted via a new long add-a-leaf that will hold up without creating a harsh ride. In addition to the add-a-leaf kit, a new greasable extended shackle is supplied to gain additional lift and allow your springs to really flex.
Zone shocks are included in the kit that are valved to perform both on and off road.
706-692-5488
JeepHut is offline
You may not post new threads
