GenRight Rear Growler Bump Stop Kit - JeepForum.com
post #1 of 1 Old 11-01-2012, 10:55 AM Thread Starter
BROTHERS4X4
This is the GenRight REAR "GROWLER" bump stop kit. It is a simple and low cost solution for bump stops on a Jeep! This kit can be installed with our Urethane Bump Stops OR a KING 2" air bump. This allows you to "Upgrade" down the road to true air bumps when you can afford it!
Part# SUP1002
*Ideal for limiting up travel (preventing damage from bottoming out).
*Affordable and complete kit.
*Proven heavy duty construction.
*Laser cut pieces key together for easy assembly.
*(2) Axle side bump stop pads.
*(2) Frame gussets.
*Sold as a pair.
*Includes axle side bump pads.
*NOTES:
*Bump Stops and Cans sold separately.
*Requires cutting and welding to install this product.
*This product should be cycled before use to confirm the bump stop is mounted in the correct position for your vehicle build to prevent unexpected damage out on the trail.
*Air bumps usually requires a Nitrogen charge of 75 to 120 lbs after installation.
*WILL NOT work with the FOX type air bumps cans!!!
$120.00 Does not include shipping.
... WE DO REAR ENDS ...
BROTHERS4X4 is offline
bump stop , gen-right , jeep , offroad , rock crawler
You may not post new threads
