Outboard rear shock mount kit that is perfect for switching over to Coilover shocks. It is a VERY clean and simple design which "frenches" into the side of the frame.
It is also a great fit with EXT & COMP Stretch Kits to relocate the shock while moving the rear axle back. These mounts are universal and can be cut or trimmed to be mounted in any position. Lower mounts are welded onto the back of the housing near the brake caliper and do not hang down! Only offered in 1 size to fit all applications that can be trimmed to fit from 8" to 18" travel shocks and is perfect for most vehicles.
*(2) Upper shock mounts (frame side)
*(2) Lower shock mounts (axle side)
*Includes shock mounting hardware and spacers
*Detailed installation instructions
*Laser cut from 1/4" thick steel and CNC bent
*Laser cut gusset
*Super wide shock mount opening (1-3/4" wide) will not bind on long travel shocks
*Optimal shock position for maximum dampening control
*Allows you to run a long travel shock without intruding on the passenger compartment
*Allows for more exhaust routing options
*Can be used with Coilover or regular type shocks (that use a 1/2" bolt top & bottom)
*Can be used on standard coil spring and leaf spring type vehicles too!
$285.00 Not including shipping
*Laser cut gusset
