GenRight Front Rock Stomper Bump Stop Kit - JeepForum.com
post #1 of 1 Old 10-31-2012, 01:27 PM Thread Starter
BROTHERS4X4
This is the GenRight FRONT "Rock Stomper" bump stop kit. It is a simple and low cost solution for bump stops on a Jeep! This kit can be installed with our Urethane Bump Stops OR a KING 2" air bump. This allows you to "Upgrade" down the road to true air bumps when you can afford it! Ideal for limiting up travel (preventing damage from bottoming out).
Part# SUP1001
*Affordable and complete kit.
*Proven heavy duty construction.
*Laser cut pieces key together for easy assembly.
*(2) Lower control arm mounts/bump stop pads (2-5/8" wide and 9/16" bolt hole).
*(2) Sets of gussets.
*Sold ar a pair.
*Includes axle side bump pads.
NOTE...
*Bump Stops and Cans sold Separately.
*Requires cutting and welding to install this product.
*This product should be cycled before use to confirm the bump stop is mounted in the correct position for your vehicle build to prevent unexpected damage out on the trail.
*Air bumps usually requires a Nitrogen charge of 75 to 120 lbs after installation.
*WILL NOT work with the FOX type air bumps cans!!!
$195.00
Call for more info. (909) 730-9956 or (909) 445-8220
... WE DO REAR ENDS ...
BROTHERS4X4 is offline
bump stops , genright , jeep , offroad , rock crawler
You may not post new threads
